sa 200 magneto timing
Results 1 to 6 of 6
    how do i set up the magneto to the engine timing ?
    Sep 2006
    Dallas, Tx
    Re: sa 200 magneto timing
    Unless you have moved the governor, there is no need to consider timing. Put the mag into its mounting hole, gas on, crank engine with #1 plug wire in each hole until engine fires. At that point, put in rest of wires, order 1342 (don't forget mag rotates clockwise from either end), job done. weldersales
    Mar 2007
    #1.Take #1 plug out and hold thumb over hole and bump engine until it blows your thumb off by compression.#1 and #4 will be at Top Dead Center on compression stroke.
    #2.If the govenor is on it with the magneto off look into the hole and make sure the govenor punch mark is in-between the two punch marks on the cam gear or vise-a-versa.Some govenors have two punch marks on the gear then you would want the cam gear punch mark between them.
    #3.The govenor gear has a cup with a female type trench like below.
    ________
    ________
    You want it looking horizontal and the mag has a square key stock male type trench that goes into the female when its stabbed onto the govenor.
    #4.Before stabbing the mag put a plug wire into the #4 position with a plug and lay it on top of the head and turn the male type trench until it fires off from the #4 plug.As soon as it fires turn a little counter clock wise where it will be running horizontal with the mag in the up-right position.It is ready to stab.Be careful or you can be grounded out and when the mag fires you will not like it a bit.
    Take the two screws out of the mag and pull the plug wire cap off and adjust the mag where the rotor cap lines up with the #4 position plug wire and tighten the two mag bolts down and it will be timed correctly.It wires clock-wise 1342.Dont get 3 and 4 swapped or it will sound like a two cylinder.
    The plugs set on 30 thousandths-points 20-Valve lash 14.
    Good welding.
    God bless.
    Steven.
    Good welding is between the shoulder and the holder.
    I also like the decal logo that says: MILLER
    KILLER
    Pacific Northwest
    Step by step.... From the BEST!
    http://billswelderrepair.com/magneto-timing.html
    Lincoln SA200's... at least 15 - 20. They come and go. Growing partial to the "Short Hoods" in my old age. Last count on Short Hoods was 13 in possession.
    I have a 73 black face sa 200. The only mark on the flywheel is a trench like on a small block chevy balancer. I cannot find any other marks. I have cleaned the flywheel and checked it several times. I put that line in the keyhole and stabbed the mag. It cranks fine but with a timing light i can't find that mark.
    The problem with the machine was after I had a mechanic work on it for a mag tooth broken the machine ran fine but bogged way down under load. I was told that the bearing in the governor probably had too much slack. I pulled the governor and it is fine. Looks like it has been rebuilt before. When I run the machine now it won't idle down like the timing is too far advanced. Any help would be appreciated.
    Pacific Northwest
    Quote Originally Posted by WINGMAN74 View Post
    Photos of the mark your looking for.
