Tungsten for TIG aluminum?
Results 1 to 25 of 32
    Nov 2011
    Bastrop, Texas
    Is there a good tungsten for aluminum that is best?
    I just tried on my new square wave 175 with 2% thoriated and it basically immediately balled up my sharp point and then melted it back into the cup.....
    I can do steel just fine on DCEN but when I flip to AC for aluminum everything went straight to hell......
    Any ideas?
    Precision TIG 185 and MP 210
    Bobcat 225NT
    Cutmaster 42
    O/A tanks.... 2 Argon tanks...... 2 C25 Tanks
    Facebook...... F2 Metal Works
    ETSY....... https://www.etsy.com/shop/F2MetalWorks
    F2MetalWorks.com....... http://www.f2metalworks.com/
    Feb 2009
    Chicago
    Is that an inverter ? My guess is yes because it balls up. If its not an inverter try green (pure) but it will still ball up on a transformer machine and from what I have read its normal. Green isn't recommended on an inverter, not sure why but that is what the manual says on mine.
    Hypertherm Powermax45
    2015 AHP Tig
    Razorweld 195 Mig/stick
    Everlast 160STH
    Razorweld 200ac/dc Digital Tig
    ViperMig 180
    Razorweld, SSC Foot Pedal & MK Products & Atlas Positioner Dealer
    Jan 2011
    Central Texas
    Re: Tungsten for TIG aluminum?
    I know nothing about welding..so just ignore what I am about to say...
    but the 30 minutes of instruction I got with my Miller Heliarc machine from the seller... in 1972 ....
    indicated that for aluminum I would WANT a ball on the end... (???)
    which may be reinforced by some of this search...
    https://www.google.com/search?q=ball...=hp&channel=np
    and I might have missed the question... so I am covered in all directions... I have told you I know nothing...and have admitted I might not even have understood the question...
    LOL
    Weldandpower Lincoln 225 AC,DC with Briggs 16hp gas engine.
    WW2 era Miller TIG.
    Apr 2011
    Ceriated ( orange band ) sharpened to a point with small flat on the end.
    Feb 2010
    BA, AR
    I use a only green tungsten at my PrecisionTig 275, transformer based machine.
    But in my Invertec V205 I can change the frequency, and working at high frequency, more than 100 Hz, works better 2% thoriated, to focus the arc, and maintain the tungsten sharp with a small ball at the end
    Mauricio
    Nov 2011
    Bastrop, Texas
    Maybe my Tungsten is just to small...... 1/16th is what I have..... Maybe it won't take the amps....
    I'll still get some Ceriated though and try again.....
    Bobcat 225NT
    Cutmaster 42
    Mar 2007
    Deltaville, VA
    Fexal,
    Not trying to sound like an azz, but have you even done a search on tungsten selection.
    Just a couple threads down from your's is a poster complaining about his thoriated tungsten and aluminum.
    It's been stated/discussed many times that thoriated is probably NOT the best tungsten for welding in AC. For the transformer based machines (like your's) many swear by the older pure which forms a ball. If you prefer the ball, the zirconated tungsten will handle the heat a little better than the pure, but will still form the ball.
    On both my transformer and inverter, I've gone exclusively to the 2% Lanthanated for AC welding.
    For me, the thoriated tends to split and form small balls around the perimeter of the tungsten when welding in AC. I do use it for DC welding.
    Syncro 250 DX
    Dynasty 200 DX
    MM 251 w/30A SG
    HH187
    Dialarc 250 AC/DC
    Hypertherm PM 1250
    Smith, Harris, Victor O/A
    Smith and Thermco Gas Mixers
    Nov 2011
    Bastrop, Texas
    Nope I didn't search..... Just fired off a question......
    I'll do that search tonight after my one garage welding day per week is over.....
    Bobcat 225NT
    Cutmaster 42
    SoCal-LA
    I tried the 2% lanthanated on Sundown's advise and found it to be very good. Takes a while to land the ball after pointing, but hold's well without spitting.
    Miller Dynasty700DX, Dynasty350DX 2ea., Dynasty200DX, ThermalArc 400 GTSW, LincolnSW200 2ea., MillerMatic350P, MillerMatic200 with spoolgun, MKCobraMig260, Lincoln SP-170T,PlasmaCam/Hypertherm 1250
    Jul 2009
    SW Washington State
    Hello Fexal, here is a link to some very good information on tungsten selection. Take a look and do a bit of reading. You'll get a lot of explanation for specific uses. Best regards, Allan
    http://www.weldcraft.com/parts-acces...en-electrodes/
    aevald
    Feb 2011
    Tennessee
    33 years in this business and all I've ever used is 2% thoriated tungsten. Haven't had a problem that wasn't my own fault yet.
    Two turn tables and a microphone.
    Mar 2007
    Deltaville, VA
    Fexal,
    In reality, you didn't really need to reply.
    It was obvious that you hadn't done a search as many of our newer posters don't seem to want to put forth any effort. Why would you be any different.
    If new guys did a little research on their own, there would be little need for the same dang basic questions being asked time and time again. Do they really think that "their question" is so unique that something similar hasn't come up in the past.
    It's amazing how much information is out there if you just do a little work.
    This particular question was expecially glaring since there had just been 2+ pages of comments/recommendations that would have provided the OP information if he had just looked for it, all on the front page of the forum.
    A little work by a new poster will go a long ways. Some of us get a little tired of "spoon feeding" the new guys.
    Syncro 250 DX
    Dynasty 200 DX
    MM 251 w/30A SG
    HH187
    Dialarc 250 AC/DC
    Hypertherm PM 1250
    Mar 2007
    Deltaville, VA
    Pangea,
    LMAO
    33 years ago they didn't even make Lanthanated tungsten.
    Are you still driving a 1980 Ford F100 pickup, with no power and getting 12 MPG?
    "That's the way we've ALWAYS done it." Sound familar?
    Wonder why there are some "rather informed people", to include the tungsten manufacturers and builders of welding machines (Miller, Lincoln, etc) that tend to disagree with you.
    Syncro 250 DX
    Dynasty 200 DX
    MM 251 w/30A SG
    HH187
    Dialarc 250 AC/DC
    Hypertherm PM 1250
    Jan 2008
    Hayward, CA
    Here is a good video on tungsten selection for an inverter:
    [ame]http://www.youtube.com/watch?v=7O07lSG5_hg[/ame]
    LONGEVITY
    Phone: 877-566-4462
    Aug 2009
    Pangea has done enough aerospace work he could probably get decent results with a sharpened (thoriated) dog turd.
    Feb 2011
    Tennessee
    SundownIII, you cranky old phart! Just because they invent some new whizbang doodad that they claim does better than the old stuff, I aint falling for it! Humph, next thing you know they will be selling pre-sliced bread! And why did they get rid of the hand crank on the front of the automobile?
    Dec 2011
    Quote Originally Posted by Fexal View Post
    Any ideas?
    Might be because you didn't give it some time to purge all the air out of the line, first.
    Jul 2011
    Utah
    Thoriated tungsten works very well on AC. Believe it or not the problem is something you're doing (or not doing).
    The more positive you set your wave balance, the more heat the tungsten has to deal with.
    If you are using a 1-1/6" tungsten, it will only handle something like 80-100amps (less than the DC rating when running AC). If you're trying to blast limitless current through it and wondering why it's melting then all I can say is RTFM.
    Jul 2011
    Fexal,
    As Mike said above, the wave balance is gonna have something to do with it. Watch Jodi's video from Welding Tips and Tricks.com on tungsten selection also. He does a quick blast at 200 amps with various types of tungstens. Lanthanated holds up the best.
    As most said above, get some 2% Lanthanated and don't look back. It even holds up better than Ceriated on AC, at least for me. Works great in DC too. I recently welded aluminum from .060 up to 3/16" with a 3/32" Lanthanted and it kept a tiny ball on the end of a sharp point the whole time, even with full pedal at 200 amps.
    TA Arcmaster 300
    CM3
    XMT 304
    S22P12 suitcase feeder
    X-Treme 12VS
    Optima pulser
    TA161S
    Maxstar 150STL
    Hypertherm PM45
    OP setup
    Stihl 020AVP, 039, 066 Magnum
    Nov 2011
    Bastrop, Texas
    Thanks for the advise Drf....
    This machine doesn't have any controls other than TIG/STICK, amp dial and pedal, and AC....... I don't get to set anything else.........
    I also downloaded the manual from the Lincoln site....... will try again tomorrow and Wednesday........ I hope to report back that i got it figured out.......
    Bobcat 225NT
    Cutmaster 42
    Dec 2011
    Milford NY
    On a transformerb I typically use 2% thoriated, some times pure, but not typical, because I have a boat load of 2% (rEd band) on an inverter, I use 2% thoriated and 2% ceriated. I do find though with the. Thoriated if you go a little to far with the amperage it will spit and contaminate the puddle. I have yet to try pure but I doubt it will hold up.
    Nov 2011
    Bastrop, Texas
    Jodie shows that 2% Lanthanated holds up to amps on AC really well...... which is what others here have said too......
    I'll be getting some of that this week........
    Bobcat 225NT
    Cutmaster 42
    Dec 2011
    Milford NY
    The synchro and square wave machines, unless you have a ex model with all the little knobs, are typically set at a wave balance of 60. So your tungsten is gonna see a good deal of heat from the dcep side of the ac waveform. Step up your tungsten, 16th is too small. I typically like to run 1/8 and 5/32 for aluminum unless it something really thin.
    Feb 2009
    Chicago
    Try 3/32, seems to be an all around good size. I only use thoritated or lanthanated. I tried ceriated and didn't like it.
    2015 AHP Tig
    Everlast 160STH
    ViperMig 180
    Aug 2010
    Columbus, OH
    I have an SW175 and it welds steel with nearly "anything" I stick in the torch (don't use pure) and any issues are caused by me (operator error). For aluminum I've run pure, lanthanated, and ceriated and had good results with all of them. I didn't have much luck running thoriated on aluminum. I find that the end splits and causes me issues. I found that it would weld aluminum, but the others did it much better in my hands. Honestly I find that I can use ceriated or lanthanated for everything and it works great. I used to switch between thoriated and pure (steel and aluminum) when I got the machine, but not anymore.
    Also, I run 3/32 on almost everything. If it's particularly thin stuff I'll go back to 1/16 or .040, but those times are really rare.
    Kevin
    Hobart Handler 210
    Tweco Fabricator 181i
    Lincoln Squarewave Tig 175
