Regulator settings ?
Results 1 to 10 of 10
    john pen Guest
    What do you guys set your oxy accet regulators at...and what would you recomend ? Probably pretty general question..Im mostly heating and welding/brazing...cutting occasionaly..
    Oct 2003
    Oregon wine country.
    Check out my site: http://www.brainfarth.com/bone.html for the victor welding and cutting charts.
    Common sense in an uncommon degree is what the world calls wisdom.
    Feb 2004
    Hey Brainfarth, on the gas pressure columns, what does the 1/2 or 8/18 mean?
    Is that 1-2 or 8-18?
    Oct 2003
    You know, I never looked at it that way before. It's supposed to mean 1 to 2 or 8 to 18 for the pressures.
    Andalusia AL.
    I set mine @ 5 and 20 should do the job for most of ur cutting!!5 being accet and 20 the ox!
    Mar 2004
    Browns Valley, CA
    Kinda depends on your torch. I cut 3/8" with my Victor J100 at 3# acetelyne and 20# O2 with good travel speed and little or no slag on the underside.
    I've found that my cuts are cleaner using the least amount of fuel gas that will get the steel hot enough to burn. It's kinda trial and error, dontcha think?
    Be well.
    hankj
    canada
    for welding tips the correct ratio is 1:1.1 . meaning if you are running a number 3 you should have 3 psi of acet. and 3.3 of 02- knowing how to balance a torch properly is probably the most important thing you should learn in this trade.
    Keep your stick on the ice
    john pen Guest
    Thanks for all the replys...
    Las Vegas, NV
    Hmmm, then where should I set my 000? Seriously...
    You know, my dad always taught me that the O2 is supposed to be about 4x the C2H2 because of the combustion formula. And in doing the stoichiometry, it does give a ratio of 2:5 if I remember right.
    But I see a lot of "experts" and technical manuals that say you should have the pressures the same or, like Dob's formula would give, have the O2 just SLIGHTLY higher than C2H2. And my Victor chart agrees with that. (And yes, it gives me acceptable values for my 000, which I recently welded some 24-ga. with.)
    So, yes, getting your torch balanced is the sign of being a professional. But then again, professionals will differ on the definition of "balanced," as in pressure or moles of gas.
    Wichita Falls, TX
    Hey guys, along this same line. If you are using a cutting tip to heat metal for bending do you use the same pressures as you would for cutting that thickness of metal but stay off the cutting lever?
    The other day I had a bow in a sheet of 1/4 plate and was trying to heat it and bend it back, and this question came up.
