Miller syncrowave 351 worth it?
Results 1 to 11 of 11
    Apr 2012
    Bradenton FL
    I've been looking for a good deal on a tig welder lately and i found a miller syncrowave 351 with torch and leads and also a miller cooler for $1500 or trade. looks to be in good shape just havent heard alot about the 351. is it a good welder for aluminum and stainless tig?
    http://orlando.craigslist.org/tls/2973388958.html
    Chicks Dig Body Damage
    Miller Dynasty 200dx
    Hobart Handler 187
    Lincoln AC 225
    Sep 2008
    SF bay area, CA
    Re: Miller syncrowave 351 worth it?
    its an older unit but if you run it through its paces and it welds good see if he will take $1250 cash for it.
    Oct 2010
    Indianapolis Indiana
    For $1500 id snatch that up quick...
    351 is a workhorse with a soft hand when needed.
    Miller Dynasty 200DX
    Miller Spectrum 250D
    Miller Millermatic 200
    Bunch of old blue dinosaurs....
    Jan 2010
    it's even got a foot pedal. i recently sold a 350 lx, ten years old for 3k. it came with nothing. deal looks good, i wouldn't try beating him up too much.
    Apr 2012
    Bradenton FL
    I'm going to offer an old chevy 4x4 truck and some cash. I really havent been able to find much info on this welder. Does anyone have experience with this machine or know what kind of adjustments it has?
    Hobart Handler 187
    Lincoln AC 225
    SoCal-LA
    That unit looks to be made between Jan1998 and July1998.
    I also does not look to be PowerFactorCorrected. A retrofit can be had, but will cost more than the $1500 asking price. I would defininately ask about that.
    They are solid machines even though a bit power hungry.
    Miller Dynasty700DX, Dynasty350DX 2ea., Dynasty200DX, ThermalArc 400 GTSW, LincolnSW200 2ea., MillerMatic350P, MillerMatic200 with spoolgun, MKCobraMig260, Lincoln SP-170T,PlasmaCam/Hypertherm 1250
    Oct 2008
    NorCal
    Here is a link to the manual:
    http://www.millerwelds.com/om/o354g_mil.pdf
    I used a Syncrowave 351 in a spar shop welding mostly aluminum. It was a beast of a welder, lot's of power.
    Shovelon is right about the power consumption. If you have the input power, it would be a great deal.
    -Ian
    Miller Dynasty 350
    Miller XMT 304
    Sep 2006
    Marlborough, The Peoples Republik of MA
    We have one in the plant, a good machine. Make sure the HF works, ours toasted a board and it was $$$ to replace.
    Maryland
    I'd grab it at that price. Power Factor will help a bit on overall current draw, but personally I wouldn't care. I'd ask around to see if it will even run off a 50 Amp plug (yeah, maybe not full power, but who actually TIGs at 400Amps?).
    Personally I think the 350 class Syncrowaves are a better deal than the 250class because the 350s usually had all the bells and whisles built in (timers, pulse, meters etc).
    As for the age of the machine, if its in good working condition now, it might just outlast you.
    With the cooler, torch, pedal etc. This one is a no brainer. Just bring a hoist to load it on your truck. 500lbs easy. (get Miller's manual to double check the weight).
    Con Fuse!
    Miller Dynasty 350
    Millermatic 350P
    -Spoolmatic 30A
    Miller Multimatic 200
    Hypertherm PowerMax 1000G3
    Miller Maxstar 200DX
    Ceres, California
    Final test date was 1-28-98 shipped with in a week or two from miller.
    This one is new enough it already has the all metal switch. The first ones came out with a white plastic switch. After a while they melt and the and the welder losses output.
    Miller has a pricey kit to upgrade the older welders. Your doesn't need it.
    just find a way to make sure it all works before buying it. Take gas with you if you have to.
    Apr 2012
    Bradenton FL
    sent the guy some pics on what i have to trade but no reply yet. If i had the cash i'd have bought it but we'll see.
    Hobart Handler 187
    Lincoln AC 225
