AC Stick welder why/why not?
Results 1 to 25 of 47
    22 years ago I welded in a fabrication shop. Mig and Stick. Went to school etc.
    I'm starting to do some small scale mild steel stuff. Making some bbq pits and the like. I've been borrowing a friends Lincoln 140 w/fluxcore and its done everything I need so far but it is borrowed.
    I was thinking I would get a buzz box to start and as I make some money on what I make, I'll buy a larger Mig, read 220v.
    Any reason an AC buzz box would be bad? Other than welding out of position ofcourse.
    Thanks for any thoughts.
    May 2007
    SoCal
    Re: AC Stick welder why/why not?
    They are the most bang for your buck.
    Out of position welds are a matter of technique. The machine will not limit out of position welds.
    Job 28:1,2
    Danny
    Nov 2008
    Texas Near Dallas
    Pros:
    It's the cheapest way to start welding
    Welds thicker material than the little wire feed machine.
    Cons:
    Not as nice as a DC stick welder.
    Requires more skill than the wire feed.
    Requires post-weld cleanup of flux (as compared to gas shielded wire feed).
    Requires more post-weld grinding if the beads need to look as nice as mig (can get close with 7018 and just chipping the flux)
    Requires heavier electrical power than the little wire feed (not really a bad thing)
    You can do plenty of good work with one, and it's a lot of bang for the buck (in the $250 range new, $100 range for good used).
    I have a buzzbox sitting around as an emergency backup machine, but I'd never use it until all my other options have failed.
    Out of position is not any more of a problem than on DC. 6011, 7018AC or any other fast-freeze rod should get you there.
    Edit: another thought. The buzzbox may not turn down enough to weld thin stuff like the little wirefeed can. Using the smallest rod you can find will help.
    Dynasty200DX w/coolmate1
    MM Vintage
    ESAB miniarc161lts
    Lincoln AC225
    Victor O/A, Smith AW1A
    Cutmaster 81
    IR 2475N7.5FP
    Rage3
    Jancy USA101
    9" SB
    AEAD-200LE
    Jun 2011
    I have to say I like welding with my Lincoln 225 but it's not as fast as my wire welders. When I need to burn (really burn) some metal together I reach for my old AC buzz box. I can do everything with that old welder including out of position welding.
    By the way, I paid $15.00 for my buzz box at a garage sale and I've got my money out of it plus more.
    A AC/ DC should not cost much more and you will notice the difference in rod burning.. DC
    will be smoother . Depending on how much you want to invest, you could get a stick/ tig machine that will give you another option.
    May 2010
    Democratic People's Republic of North Koreafornia
    I'm NOT an expert or professional welder but........
    I agree with the first 5 posters here with my own opinion as a hobbiest welder. I really like what Tanglediver and AndyA have to say about the matter, again this is my "hobbiest" view point only.
    I personally LOVE mig welding. However, I LOOOOOVE stick welding! Even though I suck at it many times and would NEVER weld something critical with it, It's so much frick'n fun!!!!!
    I did make a BBQ, steel shooting targets, and a couple work benches to name only a few projects since I've owned one. I think it should be part of everyone's "tool box" for certain welding proceedures that can't be done with a mig or tig welder.
    For instance, welding in a really tight area where a mig or tig cup (torch) cant get into, the nice slim stick electrode fits just fine. Also, I'm a weird guy, because I've only met a handful of folks here on this forum that like me, prefer to weld with AC instead of DC. Don't ask me why, by my welds turn out much nicer with AC.
    I'll post a picture of some of my AC stick welds when i get home tonight and post them here so you can judge for yourself. I say, if you can afford a "buzz box," then get one. Yes, having the DC option is apprently "better," but that all depends on the "judge." I'm my own judge for my own welds. Do what makes you happy and also, learn from the pros and more experienced welders here on this forum.
    That's just my .02cents worth of opinion on the subject.
    Lincoln Power Mig 216
    Lincoln AC/DC-225/125
    Miller 625 X-Treme Plasma
    Forney 95FI-A 301
    HF 91110
    Victor Journeyman O/P
    Milwaukee
    Dayton
    Makita
    Baileigh
    NRA Life Member
    Apr 2012
    the newer 7018ac rods have gotten very good.I figure if you can burn a 1/8 7018 you can weld up the world,check craiglist for a good used one and weld away.
    Feb 2010
    Goochland, Va.
    I chose to start with oxy-acetylene to build my skill and help me learn how the metal behaves during welding. After that was under my belt I did a pile of research on electric processes and settled on stick for the following reasons:
    1. I build and repair tractor implements more than anything else - lots of plate and often messy conditions. Stick excels at a quick repair on heavy steel.
    2. I don't do production work, I can't afford a high duty cycle machine so the argument that MIG lets you run uninterrupted for long periods isn't relevant, swapping electrodes doesn't hurt my productivity.
    3. Consumables for stick are as cheap as it gets for the weekend welder. No gas, buy the rods in 5lb boxes at less than $15 each, no cups, tips, etc. to worry about.
    4. Access for the electrode - I can bend the rod and get it into corners that no other process can reach. Really nice when you need to repair an awkward join on a box grader without tearing the whole thing apart.
    I use DC almost exclusively - just like the way it works but the list above is still relevant if you are using AC.
    The only weakness I have found with stick is that I have a hard time making clean joints on this sheet metal - but the OA torch works magic in those cases so I can still get the job done just fine.
    I don't see myself ever getting a wire welder - I just haven't found anything that I can't do with the SMAW or OA gear that I already have. I am not saying that GMAW isn't more efficient - the guys who do this for a living seem to like it and that's fine - for my occasional welding needs I just don't see a fit for the MIG machine.
    Hobart LX235
    Victor 250 Oxy-Acetylene Rig (welding and cutting)
    Bobcat 773
    F-350, 1999, 4x4, 16' 10K# trailer
    Outdoor Wood Burner - 10 cords/year
    Jan 2006
    My first welder was an o/a and an ac thunderbolt. I owned/operated a residential construction business that I welded up everything I needed with that thunderbolt. 6011, 6013, and 7018, were the three goto rods and I saved alot of money fixing dump bodies, trailers, scafolding and other equipment I had. It also allowed me to do rails and steps as well. I can tell you that with practice you can make ac work for you. i also welded up a bunch of farm and ranch implements and fences.
    Apr 2010
    AC/DC Buzz boxes are probably the most used units out there
    Almost every farm-ranch-home shop has one for repair work because of there versatility and ease of use
    and low maintenance cost and purchase price
    And a verity of rods are available for all types of welding at a low cost
    What would SATAN do ??
    Miller Trailblazer 302 AirPak
    Miller Digital Elite
    Optrel Welding Hat
    Arcair K4000
    Suitcase 12RC / 12 VS
    Hypertherm PM-45
    Rage 3 saw
    Rusty old Truck
    Mar 2012
    Quote Originally Posted by killdozerd11 View Post
    Most used or just the most common unit? There is a difference.
    Ken
    Apr 2010
    And that difference would be ???
    They are very common and used more than any other welders
    Not everybody has a portable welder for doing repair work
    Optrel Welding Hat
    Arcair K4000
    Hypertherm PM-45
    Rage 3 saw
    Rusty old Truck
    Mar 2012
    You don't understand the obvious difference between something being common but rarely used?
    Sure, I'll agree that many farms have them, but probably average using them once or twice a year. Compare that to weld shops that use MIG units every day, for several hours each day? Or commercial production facilities that use MIG or TIG every day, all day long?
    I would expect that MIG is the most commonly USED and that AC stick welders and O/A setups are the most common dust collectors.
    Nothing wrong with that, it just speaks to that idea that those who use a machine for hours every day are more likely to buy something more expensive than a low cost AC stick welder.
    Ken
    Jan 2006
    Quote Originally Posted by k45 View Post
    Ken
    You haven't been on a farm much have ya? They may be dust collectors cause everything is covered in dust, but they are used regularly due to the harsh environments. It is far easier to drag a set of leads out, over and under than it is to be tethered to a mig unit with a limited reach.
    Dec 2011
    Idaho
    Il probably get yelled at, but here it goes anyway....
    Would it be safe to maybe assume that for farms, a stick machine is the more common type of welder in use for "occassional" repair? Yet for the professional weld shop, mig has replaced the stick machines as the most commonly used piece of equipment for "daily" projects?
    "Hey I didn't come to look and learn, I came to turn and burn.... If I can't light up, I'm gonna light out!"
    -Jody
    Idealarc 250 "Fatman"
    MM 252
    MM 211 "Little boy"
    Victor Torches
    Mar 2012
    Quote Originally Posted by Scott Young View Post
    I live on a farm.
    Jun 2008
    Central California
    I think it's pretty silly to try to compare what is most common in an automated production shop, e.g. an auto factory with its robotic equipment, or even a full time large welding shop, with what is used as maintenance equipment in small auto repair places, in home shops or on farms.
    Stick welding is the most versatile of the electrical systems; I'm not sure if it or OA would be the Number 1 of all methods. Another couple tasks that stick welders can do are hard facing, cutting and gouging, and heat treating. Almost forgot...cooking hot dogs better than MIG and with less prior modification or afterward cleanup needed if done with TIG!
    Nov 2011
    Hamilton NJ
    A buzz box and 7018AC rods make for some damn good welds. Plus they're built like tanks, and are so simple to fix, a caveman could do it.
    Pros: Tough, Easy to use, Capable of thick welds, easy to fix, cheap.
    cons: Hard to weld thin metal, heavy, not very portable, slow process.
    Just go for it, you won 't be disappointed. A Lincoln ac-225 runs $250 new. For something like $400 they sell an AC/DC model, but it's not as popular.
    -Alex
    Sears/Craftsman 230A Buzzy Box
    Sears/Craftsman 180A Buzzy Box
    Chicago Electric 80A Inverter
    ALL STICK...ALL THE TIME!
    I spent a lot of time with the square peg and round hole.
    Jan 2006
    I live on a farm.
    How did I know that was coming? I get to foot in mouth disease quite abit. I still contend from being around farms, doing the welding, helping, and watching that the buzz box is used more than many of the mig unit out there. That is not to say there are mig units out there and being used, I can only say from my experiences stick is still king.
    The more there are concrete shops and barns with slabs in them I would think there would be more mig units but even then I don't think they will ever be king.
    ANVIL, Yes mig reigns in a shop environment. Stick is king out in the field.
    Aug 2008
    Ken
    But Name:  meme.gif
Size:  10.0 KB ............but Name:  meme.gif
Size:  10.0 KB ..........but Name:  meme.gif
Size:  10.0 KB ...................
    I build most everything with my crackerbox
    http://www.farmersamm.com/
    Apr 2010
    In my younger years small migs were not available like they are now and i don't see them as having the versatility that is needed for general repair work
    When most of the welding i was doing consisted of broken tractor hitches/implements and off road trailers and trucks were the material is going to be 1/4" to 1" thick a 110 mig/fcaw is to small to the job right
    And the next thing i might get to weld maybe cast iron or ss or doing a hard facing job and back to mild steel
    The only people who had 220 mig/fcaw machines were shops that did production work mostly
    And a tig on the farm ha ha the only people who had tig machines were machine shops and specialty shops that charged high rates for there services back then....
    Maybe on your farm you might have a big enough mig/fcaw machine but there are those who don't
    And a lot of them didn't have a portable welder either and that's how i made money because i had an old 180 amp hand crank Lincoln welder and i could to work in the field on a broken machine that could not be moved until fixed
    And i really hate to tell you this but stick is still the king when it comes to versatility
    This is based on my 40 + years of experience doing repair welding
    Maybe i'm wrong but i doubt it
    Optrel Welding Hat
    Arcair K4000
    Hypertherm PM-45
    Rage 3 saw
    Rusty old Truck
    Jan 2008
    when you gotta get in the honey spreader to patch a pissrusted gusset, its nice to use tig because that pointy thing in the torch is good for scraping off dried cowturds to expose the metal...just kidding, do they make 6011 in a tig rod?
    Aug 2009
    For a LONG time AC stick welding was a big deal because the only way to get DC was a motor-generator welder (more expensive than a transformer) or an engine drive.
    You can still find some LARGE, serious AC industrial transformer machines for sale now and then. Many are single phase so be alert for that.
    Just grab an old Thunderbolt or Lincoln buzzbox and have at it.
    The most critical part of a welding system is the "nut holding the stinger".
    Sep 2011
    West Tennessee
    Quote Originally Posted by farmall View Post
    Get an older Blue or Red machine with copper windings and it will probably outlive it's owner.
    1970 AC 225 and 1965 Md300s AC/DC.
