Lincoln Electric Idealarc Sp-100 Code 9284
Results 1 to 6 of 6
    Cool Lincoln Electric Idealarc Sp-100 Code 9284
    I recently obtained an older Lincoln Electric Idealarc Sp-100 Code 9284-811. It is missing the PC Board. Can anyone tell me the board number I need to purchase? Is it the L6685 or the L6685-1?
    May 2008
    Orange, TX
    Re: Lincoln Electric Idealarc Sp-100 Code 9284
    G1842-[ ] per the parts break-down for the unit with code# 9284. The "-[ ]" is for any revision number the board was built to which there appears to be three (-1, -2 & -3).
    http://www.lincolnelectric.com/asset...coln1/p180.pdf
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save 2nd Base!
    Talking Re: Lincoln Electric Idealarc Sp-100 Code 9284
    Thanks Duaneb55! I know its going to be hard to find!
    May 2008
    Orange, TX
    You can search with these guys http://www.3eservicesinc.com/Manufac...LINCOLN/G18421
    Check with Lincoln customer service on whether there are any issues using a -1, -2 or -3 revision board.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save 2nd Base!
    Ceres, California
    Lincoln no longer supports that pcb. You are going to have to do a web search and see if anybody has one they are willing to sell. Try all the pcb repair sites and see if they have an extra one. In most cases a higher dash number replaces the lower one.
    Pc boards only, In other parts the dash number could be a completely different part or a different size part. all diodes and potentiometers all start with the same type of number. The dash number tells what size.
    Duaneb55 look up the part number in the list price list you have. drop the dash number and it will show you all the changes.
    Vintage parts has sold all the ones they had.
    mine is a 9284-902 and the board in it is a G1842-1 haven't had much luck finding it did find a place that says they repair them rzonk@netscape.com
