Brazing Aluminized Steel
Results 1 to 10 of 10
    I came across some aluminized steel pipes and was wondering if it's possible to braze them to, say, regular aluminum pipes. The aluminized steel has a aluminum coating which apparently needs to be ground off before welding, so I'm thinking it would be possible given the right brazing rod (like silver solder?? ).
    Sep 2006
    Philadelphia
    Re: Brazing Aluminized Steel
    Here we go again.
    Cronatron offers a couple types of wire that allow soldering/brazing aluminum to steel.
    In thin sections such as tubing wall, and subject to vibration, IMHO, it will crack in your application (I'm assuming it's either intake or exhaust for automotive).
    Still working on a way to do this but I'm also starting to give up. The more I learn about it the more I realize that people who know way more than I ever will have tried to come up with a suitable method and/or tried to make a suitable filler alloy and pretty much failed miserably. It does seem to be getting closer though so maybe soon enough someone will figure it out.
    How about weld an aluminum flange on the aluminum and a steel flange on the (cleaned of al cladding) steel and bolt it up tight. Bingo, a strong steel to aluminum joint.
    Favorite right now is a Miller Syncro 200.
    Tons of tools and I blame at least one of them when things don't go right.
    Aug 2007
    Or just weld it? I've welded aluminized steel before and I don't recall ever grinding off the aluminum to weld it? maybe I'm missing something here?
    Aug 2006
    San Dimas, CA
    Quote Originally Posted by mpower
    You've welded aluminized steel tubing to aluminum tubing?
    Got any pics?
    - Paul
    http://all-a-cart.com
    Welding Cart Kits and accessories
    Jan 2006
    In A Nice Comfy Chair
    Quote Originally Posted by ZTFab
    Got any pics?
    - Paul
    X2
    This I gotta see..
    ...zap!
    I am not completely insane..
    Some parts are missing
    Do not attempt.
    May 2006
    mpower - he's asking if you can weld Aluminized Mild Steel tubing to Aluminum tubing...not Aluminized to aluminized.
    Paul and Zap - I think he didn't read the entire question.
    John
    - bleeding Miller blue!
    http://www.weldfabzone.com
    Aug 2006
    San Dimas, CA
    Quote Originally Posted by MicroZone
    I know...I was just giving him a hard time for not reading the post.
    - Paul
    Jan 2006
    It has been rather slow in here today...
    ...zap!
    Do not attempt.
    May 2006
    Ah - you guys are ball busterzzzz!
    On a side note, if you're bored, I'm in the chat...all alone.
    John
    Aug 2007
    =) i read it completely alright, I must have left out some parts that I didn't want to read because I was so eager to reply- bored at work syndrome lol.
