removable leads for Lincoln tombstone
Results 1 to 14 of 14
    Sep 2010
    southwest VA
    Thanks to Nathan for the idea ( http://weldingweb.com/showthread.php?t=90691#12 ) . I decided to go with size 50 Dinse instead of Twecos and used the factory hole locations. Paint is currently drying where I went back and touched up the cut edges (original holes were .680" - new ones are 1.194" plus the little anti-rotation keyway). Receptacles are Lenco LDPM-50 and the plugs are LDP-50M. Going to reassemble tomorrow.
    May 2007
    SoCal
    Re: removable leads for Lincoln tombstone
    That'll be nice, you can come and do ours too!!
    Job 28:1,2
    Danny
    Apr 2008
    Yuma AZ
    Looks factory made, nice job.
    Mark
    Craftsman 12"x36" Lathe
    Enco G-30B Mill
    Hobart Handler 175
    Lincoln WeldandPower 225 AC/DC G-7 CV/CC
    Add a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG
    PapaLion's Gate Build
    May 2010
    ct.
    Nice job.I wanted to do the same to my T-bolt.
    Couldn't get those connectors at my lws.
    I ended up cutting leads off short and putting
    Lenco female inline connectors on.
    Maybe when I take cover off to clean and lube
    I'll add panel mount connectors.
    Miller a/c-d/c Thunderbolt XL
    Millermatic 180
    Purox O/A
    Smith Littletorch O/A
    Vintage-
    -South Bend 9in. lathe
    -South Bend 7in. shaper
    -Craftsman power hacksaw
    -FibreMetal 710
    -B&D mag drill
    Jul 2011
    GREAT job.
    What paint color/code?
    TA Arcmaster 300
    CM3
    XMT 304
    S22P12 suitcase feeder
    X-Treme 12VS
    Optima pulser
    TA161S
    Maxstar 150STL
    Hypertherm PM45
    OP setup
    Stihl 020AVP, 039, 066 Magnum
    Feb 2009
    SE Washington State--Wine Country TriCities Area
    dbotos--nice job! It's really cool to take someone like that and customize. I would like to do soothing similar with my MIG and TIG machines. Do you happen to know of the DIN 50 female connector part no? I have the exact same male connectors now. Thanks for posting it.
    Hellinois
    Very nice, but why Dinse vs. Tweco? Around here Tweco's are the most popular, on the larger machines.
    "Stick-man"
    Jan 2008
    Richmond, Virginia
    Quote Originally Posted by 200mphbusa View Post
    ... Do you happen to know of the DIN 50 female connector part no? ...
    LENCO part number for the receptacles is in the first post.
    Syncrowave 250 w/ Coolmate 3
    Dialarc 250, Idealarc 250
    SP-175 +
    Lincwelder AC180C (1952)
    Victor & Smith O/A torches
    Miller spot welder
    Sep 2010
    southwest VA
    Thanks for the compliments. I got her put back together this morning. I went with the Dinse standard since I've got two other machines that have them. Machine code is 10426. Not sure what the correct paint for it is - I just sprayed some Banner Red Gloss Krylon in a cup and brushed it on the raw edges. It's not a perfect match, but the body of the receptacle covers it up anyway. Going to go test it out in the hot sun now...
    Sep 2010
    southwest VA
    One last finishing touch - color coded the work clamp connection. Also put it on a little dolly to wheel it around (i.e. 12 x 18" piece of 3/4" MDF with four casters screwed to the bottom). I'll have to make a proper cart for it one of these days with storage for electrodes and other goodies.
    Very Impressive... Nice post.. Really shocked to see this pis..Look like made any expert...
    Aug 2009
    Santa Cruz, CA
    Nice clean install. It looks way better this way.
    Miller Dynasty 200 DX
    Miller MP-10 & Jackson Nexgen EQC
    Jet 414457 Mitering Bandsaw
    20 Ton Press & Swag HD Press Brake
    Jan 2006
    Inkster, Mi
    Looks like you pulled it out of a box that way from the store. Good job.
    Will Supports Autism Awareness
    My Toys
    BobCat 225 PLus
    Millermatic 130
    Miller Spectrum 300 Cutmate
    Everlast Power Tig 185 Micro
    April is Autism Month .
    Sep 2010
    southwest VA
    Thanks. I would say it'd be cool if they came this way from the factory, but with these being lower cost / entry level machines, it'd probably add too much to the cost. Fortunately, though, it's a pretty straightforward DIY. Plus you can make whatever lead lengths you want.
