measuring angles on smaller pipe
Results 1 to 8 of 8
    Jul 2012
    central nj.
    So i am looking for a way to measure angles on smaller pipe,say 1 1/4".they can range from 30 to 130 degrees and they never seem to fit clean and tight.new to doing rails and the chop saw doesnt cut it(no pun intended) she only does a 90 without modifing her.Any help?
    May 2009
    San Luis Obispo, CA
    Re: measuring angles on smaller pipe
    Huh? Not sure what the problem is. Are you trying to cut miters with 1 1/4" pipe for handrails?
    Ian Tanner
    Kawasaki KX450f and many other fine tools
    Sep 2005
    Cave Creek AZ
    most pipe rails are done with fittings and fishmouths.
    Dec 2009
    Las Vegas, Nevada, USA
    Quote Originally Posted by mnydvr View Post
    if you are doing new construction,you might try a paper template system link here.
    If you are trying to measure the angle between two existing tubes, place the joint upright and use a digital or lead weight style protractor. Measure the angle of each tube relative to the ground. Then subtract the smaller angle from the larger to accurately measure the angle between the two tubes.
    Zip.
    May 2010
    mine sites mostly and workshops of varying notoriety
    cut a pocket in a bench and fit your saw down in the hole securely, get rid of the original clamp and you can tack weld angle iron to whatever angle you like and clamp the pipe or tack it......you can do some tricky angles this way.
    Pacific Northwest
    Lincoln SA200's... at least 15 - 20. They come and go. Growing partial to the "Short Hoods" in my old age. Last count on Short Hoods was 13 in possession.
    Jan 2011
    Tx
    Doesn't the contour marker only work 1 1/2" and larger pipe
    Miller Bobcat
    Harris cutting outfit
    Miller spectrum 625 plasma
    Variety of shopmade tools
    Nov 2012
    ga
    degree finder, wrap around and a metabo
