Lincoln Invertec V300 pro on Ebay
Results 1 to 25 of 47
    There is a lincoln invertec v 300 pro n ebay. if this a good buy?
    http://cgi.ebay.com/ws/eBayISAPI.dll...MESE:IT&ih=019
    May 2006
    Re: Lincoln Invertec V300 pro on Ebay
    It is a good buy and cheap because it is a 3 phase machine. You will find plenty of 3 phase machines on eBay at a good price because not alot of people can use them. See the plug on the back? That is a 3 phase plug.
    John
    - bleeding Miller blue!
    http://www.weldfabzone.com
    Sorry about that Micro...
    I am trying to find which model a welder is that i am going to buy. It is a Lincoln Invertec V300 Pro... i was told to find the product number, but all i can find is the Code number, and serial number how do i tell if it the advanced process welder?
    May 2006
    No problem, I just like to keep things organized.
    Do you have 3 phase power?
    I'm not sure how you can find a product number on a welder you don't have?
    The Invertec V300 is a Multi-Process welder. I believe they are similar to Miller Shopmates? Someone correct me if I'm wrong.
    John
    This welder is a single phase and a 3 phase machine.. there is a switch on side of machine behind a cover where u can switch it between the 2. but yes, my shop has 3 phase..i have a mill and a lathe
    May 2006
    I know the Lincoln Invertec V350-PRO and V450-PRO are both advanced process welders. Why not give a call to Lincoln and ask?
    I would be careful on that unit, he states, "This unit is in great shape all looks good." Unless I've misread, he never states it works good.
    John
    I sent the guy a message and he said it had been tested and works
    Mar 2005
    Carrollton GA
    The one in the picture is NOT a single phase machine. What see on the back is a 3~ no 1~ . He says that the current type is "either" but I bet he is referring to the voltage, not the phase. Look very closely at the picture of the back of the welder. If you don't have three phase power available to you, you will not want this machine.
    Smithboy...
    Feb 2007
    West By Golly Shelby NY
    This is a quote from the AD
    Lincoln Invertec v300-pro, inverter style welder, works on a wide range of input power either single or three phase, this
    That is a nice machine.
    David
    Real world weldin.
    Jul 2007
    Cape Cod MA
    The plug is a twist-lock can be single OR three phase can't tell from that distance.
    Me!
    Apr 2007
    Midwest
    It's plainly marked;
    3-
    60HZ
    and he's already stated he knows it's 3 phase and has that in his shop.
    On the back data plate, what is the stamped number immediately following V300-PRO ?? I can't make out what that number is supposed to be. There aren't any other numbers visible in the pictures.
    Anything worth doing is worth doing RIGHT
    Feb 2007
    I asked the guy for the code #. If its single phase, it will go for about $1200.
    I bid on a bunch of these. I ended up buying a brand new V350. I don't regret it a bit.
    David
    Real world weldin.
    Mar 2005
    Carrollton GA
    Here is a blown up shot of the back. It's clear enough to see that there is no mention of single phase...only three phase. I think the guy doesn't know or is trying to misrepresent it...however, if you expect to use this in single phase, I believe you will be greatly disappointed.
    Smithboy...
    Feb 2007
    I just looked through the operators manuals. All but one is listed as single or 3 phase. They make a 575volt ONLY 3 phase machine.
    Not trying to get into any kind of contest, but thats the glory of an inverter, it can use any electricity because it chops it up into smaller pieces that are easier to handle.
    David
    Real world weldin.
    Feb 2007
    I emailed the guy and got the code # 10256. There is the 575 Volt 3 phase only model. The regular model is single or 3 phase.
    Here is the instruction manual
    http://www.mylincolnelectric.com/Cat...nualsearch.asp
    David.
    Real world weldin.
    If you look at the plate, below where it says V-300 Pro you can see it states 3phase, AND 1phase..unless im wrong and 1~ and 3~ does not mean 1 and 3 phase power...correct me if im wrong though please.
    This is the switch from behind the side cover where you can switch it from 200-230V and from 380-460V....So this IS the SINGLE AND 3 PHASE Machine. Not trying to bash anyone especially the moderators, but just clarifying what this machine is.
    Wichita Falls, TX
    You know I find it kina odd that you live in Ft. Gibson OK and the welder is for sales on Ebay from Ft. Gibson OK. I think Ft. Gibson only has a population of 4,000. Is this an attempt to run up the price of a welder that you own?
    Feb 2007
    I was thinking of buying it. If this is your machine..........I thought you were bidding on it.
    David
    Real world weldin.
    May 2006
    So, ftgokie - what is going on here?
    I've traced your IP address, so an explanation might be in order for these folks that were trying to help and you're misdirecting.
    If you simply wanted to sell it, this post will be re-directed to the for sale section.
    John
    May 2006
    Quote Originally Posted by ftgokie
    Can you copy and paste this correspondance, complete with e-mail headers? Thanks.
    John
    Mar 2005
    Carrollton GA
    David, FtGokie,
    I am convinced. It's both single~ and three~...I didn't see the single to three phase thingie in the top of the id plate. I am glad you were both persistant, when I was wrong. Furthermore, I do not have any direct experience with these machines, so, I probably should have simply deferred to yours. No contest...when you are right, you are right. You have my appreciation.
    I have however, had experience with three phase machines being claimed to be capable of single phase operation...I still have one...When I saw the three phase voltage listings with no mention of single phase, alarm bells went off in my head. I am feeling better now.
    Smithboy...
    Aug 2006
    St. Paul Park MN
    I think the alarm bells are ringing in MicroZones head now.
    Feb 2007
    I have the V350 and its the nicest welder I have used.
    After looking at the Lincoln website, the V450 is three phase only. Whattamachine. 575 Amps, 293 lbs.
    David
    Real world weldin.
    Sep 2006
    Philadelphia
    Looking at the rating plate, if you look at the lower right corner of it, it says "see operating manual for 1 phase operation."
    Just sayin . . . .
    Favorite right now is a Miller Syncro 200.
    Tons of tools and I blame at least one of them when things don't go right.
