Esab 350 MPI
Results 1 to 4 of 4
Thread: Esab 350 MPI
    Jul 2011
    Esab 350 MPI
    Theres one of these for sale with a wire feeder locally for a good price. It is apparently a working unit.
    Seems like ESAB's version of an XMT.
    Does anyone have a review on this machine? What are your opinions on buying one?
    There's not much in the search function regarding this machine. I don't want to buy it and then find out its more like an XMT300.
    Thanks.
    TA Arcmaster 300
    CM3
    XMT 304
    S22P12 suitcase feeder
    X-Treme 12VS
    Optima pulser
    TA161S
    Maxstar 150STL
    Hypertherm PM45
    OP setup
    Stihl 020AVP, 039, 066 Magnum
    Jan 2005
    Re: Esab 350 MPI
    Quote Originally Posted by Drf255 View Post
    Thanks.
    It's limited more in single phase output then a XMT 304. 250 amps single phase. Tons of voltage, and not limited there. Much more adjustable short arc, then any XMT series machine. Very loud fan too. As far as reliablity, and weldabilty top notch.. You can make it weld like a XMT or a Lincoln Powerwave C-300 in the short-arc by changing the slope around. CO2 setting makes very similar to a Miller, and the C-25 makes like a Lincoln. That's running C-25 in both settings. Slope for Aluminum is very nice too.Slope adjustment for spray-arc/etc.. too. You well find it wets the puddle out great, and really only need very limited inductance settings to make big changes in the arc. It will support Lincoln's 42 volt feeders with a cable (LF-72) or Hobart 19 pin feeders by moving a few pins around. Pulse can be had by using a 4hd feeder, and the 350 pulse box. Also a 4-30 4-48 feeder, and the optional built in feeder pulse setup..
    Esab 2200i-TA34
    Esab 160i caddymig
    Hypertherm 45XP
    Thermal Arc LM-200 Lincoln feeders
    Thermal Arc Pee-Wee 85s
    Thermal Dynamics 38XL-SL-40
    If I agreed with you, we'd both be wrong!
    Jul 2011
    Re: Esab 350 MPI
    Sounds like a good unit. Thank you.
    TA Arcmaster 300
    CM3
    XMT 304
    X-Treme 12VS
    Optima pulser
    TA161S
    Maxstar 150STL
    Hypertherm PM45
    OP setup
    Jul 2011
    Re: Esab 350 MPI
    Well I missed out on the machine by one day.
    It was a 350 mpi with a 2e feeder and cables with an asking price of $600. It was misclassified on CL.
    For that price, I thought it was a steal.
    TA Arcmaster 300
    CM3
    XMT 304
    X-Treme 12VS
    Optima pulser
    TA161S
    Maxstar 150STL
    Hypertherm PM45
    OP setup
