My SA 200 Red Face... the resto begins
Page 1 of 6 123 ... LastLast
Results 1 to 25 of 138
    Sep 2012
    On an Island somewhere in Puget Sound
    Talking My SA 200 Red Face... the resto begins
    in 1971 my dad bought this old pipeliner for a whopping $20 it had a "dead" spot on the selector dial, other than that it ran and welded like a champ. I learned how to weld on this machine when I was about 8 years old. We used it on and off over the years but it mostly just sat in a pole building at my grandpas house.
    Recently I discovered my old welding mentor CEP was collecting and restoring SA 200's, I had thought about dragging ours out of the shed and going thru it but hadn't done anything about it. once I saw what CEP had done with his I was hooked and so begins my resto project. I have restored 20+ hit and miss engines and a few motorcycles but never a welder... looks pretty straightforward but I am sure that I will have plenty of questions as I go thru it this winter.
    1963 SA 200 Redface, rebuilt by me, bodywork by CEP
    Miller 330 A/BP
    Ranger 9
    Miller 212 Autoset
    Miller Xtreme 375
    Bridgeport Mill
    South Bend 9" Lathe
    Sep 2012
    Re: My SA 200 Red Face... the resto begins
    A few more pictures....
    Miller 330 A/BP
    Ranger 9
    Miller 212 Autoset
    Miller Xtreme 375
    Bridgeport Mill
    South Bend 9" Lathe
    Oct 2007
    San Antonio
    She will probably fire right up and weld. Still almost a new welder.
    http://www.facebook.com/groups/sa200welders
    Current machines:
    Hobart G600 Powered by 1967 Chrysler LH-318 (Project)
    Hobart GF-250(Traded)
    68 Redface
    81 Blackface
    Sep 2012
    Probably, she always has in the past!
    Miller 330 A/BP
    Ranger 9
    Miller 212 Autoset
    Miller Xtreme 375
    Bridgeport Mill
    South Bend 9" Lathe
    Feb 2009
    Lafayette, Louisiana
    Looks like a good candidate for a rebuild, an old welder that's been in the family for 40+ years. Good luck with your project & keep us up to date with the progress!
    Only when the last tree has died and the last river has been poisoned and the last fish has been caught will we realize we cannot eat money.
    -Cree Indian Proverb
    SA 200 Lincoln
    Victor Torches
    Sep 2012
    Oh yeah, it is part of the family...
    Miller 330 A/BP
    Ranger 9
    Miller 212 Autoset
    Miller Xtreme 375
    Bridgeport Mill
    South Bend 9" Lathe
    May 2010
    Port Orchard, WA.
    Quote Originally Posted by JAS View Post
    Tell Tom I'll give him $25.00 for it.
    Don’t pay any attention to me
    I’m just a hobbyist!
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Sep 2012
    No!!!! He already gave it too me....
    Miller 330 A/BP
    Ranger 9
    Miller 212 Autoset
    Miller Xtreme 375
    Bridgeport Mill
    South Bend 9" Lathe
    May 2010
    Port Orchard, WA.
    We'll see about that, PM me his phone number!
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    southeast texas
    welderpartswarhouse.net sells those main selectors for 75 dollars
    1960 Redface SA-200 F 162
    1973 Black face SA-200 F 163 with 5" chop
    2013 Miller Trailblazer 275
    2013 GMC 3500 welding car
    Thats going to be a nice resto. The cabinetry is in fine shape. Looking forward to your build pics
    Thermal Arc Fabricator 210
    1970 Lincoln Redface
    Miller 150 STL
    Still need a Syncrowave and a plasma and a milling machine and a lathe and a bigger shop and a....
    Sep 2012
    Down boy, down....
    Miller 330 A/BP
    Ranger 9
    Miller 212 Autoset
    Miller Xtreme 375
    Bridgeport Mill
    South Bend 9" Lathe
    May 2012
    Cleveland Tx
    Not a bad looking machine, how does everything ohm out?
    1950 SA-200 Shorthood
    1961 SA-200 Red Face X2
    Sep 2012
    Quote Originally Posted by circlecranch View Post
    Have not "ohmed it out" just getting it torn apart now. I did however just determine that the engine is free which is a bonus.
    Miller 330 A/BP
    Ranger 9
    Miller 212 Autoset
    Miller Xtreme 375
    Bridgeport Mill
    South Bend 9" Lathe
    Sep 2012
    Pulled the radiator last night, I plan on having it hot tanked and pressure tested. I don't plan on tearing down the whole engine since it has such low hours on it. One thing I need to do is figure out where the oil leak is coming from, the pattern of oil flung onto the radiator leads me to believe it might be coming from the governor area rather than the front seal.
    Miller 330 A/BP
    Ranger 9
    Miller 212 Autoset
    Miller Xtreme 375
    Bridgeport Mill
    South Bend 9" Lathe
    May 2012
    Cleveland Tx
    Usually its the bottom hole where the bolt goes through to the mag, The top does it too, its just not as common, and every once in a while the push in seal where the linkage goes into the governor housing goes bad.
    Sep 2012
    Thanks! I think that bottom mag bolt and maybe even the mag gasket could be the culprit.
    Miller 330 A/BP
    Ranger 9
    Miller 212 Autoset
    Miller Xtreme 375
    Bridgeport Mill
    South Bend 9" Lathe
    May 2010
    Port Orchard, WA.
    See that rectangular plate on the top bolt in the governor? There should be a piece of sheet rubber gasket behind that plate, bottom one too. I just stopped about 98% of an oil leak in my 1954 by replacing that rubber gasket.
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Sep 2012
    Thanks Carl, I think that is where the issue is.
    Miller 330 A/BP
    Ranger 9
    Miller 212 Autoset
    Miller Xtreme 375
    Bridgeport Mill
    South Bend 9" Lathe
    May 2008
    Orange, TX
    You may want to consider doing so soon as the results would determine the difference between a reasonable. moderate or expensive restoration cost. Just a thought.
    And CEP, factoring in inflation the unit is worth all of $50 now so let's be fair.
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    May 2010
    Port Orchard, WA.
    Hey not a problem duaneb55, in fact being as I respect your knowledge of welding machines so much I'll go as high as $75.00!!!!!!!!!
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Sep 2012
    I think I am going to need a "Dummies guide" to checking the ohms on this machine..... I am not sure how to go about doing it, can it be done without removing the coils?
    Miller 330 A/BP
    Ranger 9
    Miller 212 Autoset
    Miller Xtreme 375
    Bridgeport Mill
    South Bend 9" Lathe
    May 2008
    Orange, TX
    Well I'm not going to type what has been typed by the masses already other than to tell you if you're going to own an SA-200, you need to go to Weldmart http://weldmart.com/index2.htm and request their free CD packed with probably all the information you'll need to know. While you're waiting you can go to their troubleshooting section and get the information you need.
    Another site to visit is http://www.billswelderrepair.com/home.html.
    If you still have questions, just ask.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Sep 2012
    Thanks duane55, I sent for that free CD today! I Went to their troubleshooting page and downloaded the info too so I should be set for now, just need some "shop time"
    Thanks,
    Jim
    Miller 330 A/BP
    Ranger 9
    Miller 212 Autoset
    Miller Xtreme 375
    Bridgeport Mill
    South Bend 9" Lathe
    Sep 2012
    well I was able to check out the shunts on the exciter, not sure how to check the mains but I would think they're likely okay as it welded fine in the past when we've used it, but who knows.... if it's not too difficult I may see if I can figure out how to test them too.
    from what I could find I am supposed to be around 46 ohms, is 49.6 ohms okay on the exciter shunts?
    Miller 330 A/BP
    Ranger 9
    Miller 212 Autoset
    Miller Xtreme 375
    Bridgeport Mill
    South Bend 9" Lathe
