Grouser Re-build
Results 1 to 13 of 13
    Dec 2011
    Fayetteville, NC 28305
    Grouser Re-build
    Hey, I 'am thinking of building up the triple grousers on the track loader, they are 14'' wide
    and need 3 bars of steel about 1/2 x 1/2 on each, 36 on each side. I'am new to welding
    and have a harris torch. Has anyone ever done this or know what would be the best type
    of welding machine to use, thanks, sam.
    May 2010
    Sparks, NV
    Re: Grouser Re-build
    This is something you should pay a pro to do. due to the extreme shear forces exerted on the tracks you will just peel the bars you weld on right off the track. They probably need to be some type of special high wear/ hardened steel. You will need at least a 250 amp mig machine or a good stick welder and then hundreds of hours of stick welding practice before you can expect to get good welds on those tracks. Put too much heat into the tracks and you will ruin the hardening or temper that they have.... The manufacturer will be able to tell you what material the tracks are made of and also the WPS for building them up if they have an approved process for that
    The fact that you mentioned you have an OA set tells me you will not be successful at your endeavor if you try to do this project.
    AHP200x; AHP 160ST; MM350P, Spoolmatic 30A; Everlast PowerTig 185; ESAB 875 plasma;Evo 355. OA
    Dec 2011
    Thanks, soutthpaw, I have seen guys weld on re-bar, but i want it done correct, the loader
    is the small cat but still weights about 8 tons. I''ll look for a por to get a bid, and see what
    new ones cost. Thanks, wosama.
    May 2010
    Sparks, NV
    You might want to ask here too. I think there may be some pros on this site in your area. I don't have any experience with that kind of stuff. biggest I got is a Bobcat. maybe able to have them hardfaced too.
    Feb 2008
    North of Philly
    By the time our old 941 needed the tracks reworked, it needed a whole new under carriage. They spray welded the idlers IIRC but I'm pretty sure it simply got a new set of tracks installed. It's been more than 10 years so I can't remember at this point. If anything my guess is the grousers are built up and then hardfaced. OA is definitely not the right process and to do this right you will most likely need a fairly powerful machine to run the welds.
    Ronald Reagan
    Apr 2010
    They make Grouser bar that you buy cut to length or buy the proper size and weld on
    One edge is wedge shaped the other flat
    Put the wedge side mating flush to the old grouser and get fitted up tack in place and weld
    We do it with FCAW but it can be done with smaw just slower
    What would SATAN do ??
    Miller Trailblazer 302 AirPak
    Miller Digital Elite
    Optrel Welding Hat
    Arcair K4000
    Suitcase 12RC / 12 VS
    Hypertherm PM-45
    Rage 3 saw
    Rusty old Truck
    Apr 2009
    La / Ga
    You can order the grousers as killdozerd has mentioned , it is not a hard job to complete. I have some that i redone on mine from a D7 down to a D-20 Komatsu , never had one break or come off for any reason. Have welded with 7018 and also fluxcore , the fluxcore is a lot faster and will hold just as well.
    If your pads are wore real bad you may need to trim the top of the grouser with a torch to have a flat area to weld the new grouser bars on to.
    Myself and one man recently did one of my John deere 850 C pads , if possible pick the machine off the ground and block it up or else be able to move with the machine as the tracks are turned. We tacked all the pads on then weld one side of the front pad that is flat and then move to the back and weld the one flat, then turned till next one was level. Took 7 hrs with two of us - but we wasnt in a huge rush either. If i remember correctly had 42 pads per track.
    Pacific Northwest
    Buy the pre-cut / beveled pieces, run a 300 amp diesel Lincoln with something like a LN-25 with big flux core wire.
    One welder on each side.
    One man in the operators seat.
    Run the blade down and the rippers to get the machine off the ground.
    With some practice you can put a couple of nice tacks on the piece and it will "draw" up to the correct angle. Tack all the pieces and let them draw. This is done running the weld flat (downhand position).
    Next, reposition your wire feeder and weld out the side you did not tack. Again, run the bead in the flat position.
    Last, reposition and weld out the side you first tacked.
    It can be a blow and go operation with two good welders and the right equipment.
    On the other hand.... done wrong, it's a nightmare.
    Thanks,
    Hobo
    Lincoln SA200's... at least 15 - 20. They come and go. Growing partial to the "Short Hoods" in my old age. Last count on Short Hoods was 13 in possession.
    Aug 2008
    Sudbury, Ontario
    Local cat and jd dealers tell me it is not worth welding grouser bars anymore if you are paying to have it done, they say you can buy new non oem pads for the same money. JD dealer sent me over to cat when I was looking for grouser bar stock. They both said welding grouser bars is not very popular anymore, jd had none in stock and cat had only a couple of pieces and needed to order the rest. And this is for single grouser bars on a dozer, it would be that much worse on a triple grouser street pad for a loader. Also be aware that the grouser bar stock commonly stocked is for single grouser dozer pads, they are much higher than those for a loader.
    As for me it is worth doing, saves some cash but that was with my welding it for free.
    SA 200
    Idealarc TM 300 300
    MM 200
    MM 251
    30a Spoolgun
    Precision Tig 375
    Invertec V350 Pro
    SC-32 CS 12 Wire Feeder
    Oxweld/Purox O/A
    ArcAir
    Hypertherm Powermax 85
    LN25
    Dec 2011
    Thanks for the advice, Right now i'am taking off the grousers to get ready for new track, pins worn out
    on both sides, i though i would save some $$ by welding on the bars on before i re-install them.
    The grousers are about even with the bolt head, and i would like a little more traction. The cost of
    a good welder is perty high, but it may pay for its self if i could do the work, still not sure what i will do.
    Oct 2011
    Elkhorn, WI
    I worked in the Pennsylvania oil patch in my younger days. A couple of old timers had a crawler with funny looking grousers. I asked them what the deal was, they said one winter we took some old buckets of bolts and our stick welder and welded them on. It was cold outside and warm in the shop, we took turns and had it done by spring.
    Sep 2012
    Bellingham, Wa.
    Here are some links to compare, I have had customers do it both ways, rebuild or replace, kind of depends on cost of labor.
    http://www.dura-tuff.com/SavingsDataSheet.pdf
    http://www.lincolnelectric.com/asset...reBU/c7710.pdf
    Oct 2012
    You are not going to save money by repaing track pads. You stated that you were putting new rails on the machine. If you calculate the cost of new pad bolts and nuts the cost of labor and materials to repair worn out pads you will pay more. If the pads have been in use long enough to be worn out some or a lot of them have been run with loose bolts and the holes will be worn as well as the back of the pad making it impossible to keep them tight. Don't forget to check the sprokets, idlers and the bottom and carrier rollers. There is a ton of good parts out there oem and after market. Too many people trip over a dollar to pick up a dime when doing u/c on track machines. Do it right the first time and you won't be taking it apart again
