hay spear build
Results 1 to 23 of 23
Thread: hay spear build
    Jan 2007
    knoxville, tn
    hay spear build
    Needed to make another hay spear for the Allis Chalmers 6080 so that I could put the smaller one back on the IH 354.
    the victim....3 x 3 x 3/16 mild steel square tubing marked for cutting.
    the sword of choice set at 40 amps, wide open
    squared up and tacked on all four corners
    next post
    miller... 225g, s32p, 250x, 304, 12vs, MSW41
    victor o/a
    thermal dynamics cutmaster 50
    lenco panel spotter
    hobart hf-box
    G3 Farms.....raising cattle, hay, kids and hell, ...oh yeah I'm a fire sprinkler contractor by trade.
    Jan 2007
    knoxville, tn
    Re: hay spear build
    after square and tack time to weld solid
    all welded up
    now to put short pieces of 1.25" sch. 40 pipe sleeves inside for the short spears that I will fab out of 1" sch. 40.
    next post
    victor o/a
    lenco panel spotter
    hobart hf-box
    Jan 2007
    knoxville, tn
    Re: hay spear build
    well the last pic in the prev. post was a little early, here is the hole lay out and cut outs for the 1.25" pipe sleeves.
    Got the sleeves cut out with the bandsaw and welded in but dark got me so will have to take more pics tomorrow.
    Also got the end pieces cut out for the hitch pins and a square piece to fill in the top of the tubing, will still have to cut out pieces for the top link to hook to.
    fire away
    G3
    victor o/a
    lenco panel spotter
    hobart hf-box
    Nov 2006
    texas
    Re: hay spear build
    wow how have you not caught te leaves on fire yet??lol great job so far
    Sep 2007
    Mesick Michigan
    Re: hay spear build
    LOL are those all dried leaves. I would hate to see some sparks make them go up in flames.
    --Gol'
    May 2006
    Re: hay spear build
    Looks good G ! Well, if he sparks them, at least he won't have to rake 'em after!
    John
    - bleeding Miller blue!
    http://www.weldfabzone.com
    Jan 2007
    knoxville, tn
    Re: hay spear build
    it rained alllllll day yesterday the leaves are soaking wet. just have to be careful, have done the leaf dance before (you know, stomping around putting them out).
    ordered the spear off egay this morning.
    G3
    victor o/a
    lenco panel spotter
    hobart hf-box
    Nov 2006
    Truro Nova Scotia Canada
    Re: hay spear build
    Good work George.
    Miller DVI2
    Lincoln Precision Tig 225
    Thermodynamics Cutmaster 38
    Everything else needed.
    Jun 2007
    Tampa Bay Area
    Re: hay spear build
    No the leaves are used to preheat
    Great job and I'm glad I'm not the only one that has his work area outside
    People are more violently opposed to fur than leather because it's safer to harass rich women than motorcycle gangs. Unknown
    Pro Mig 175
    Hyphertherm 600
    Lots of toys at work
    Nov 2007
    Pittsburgh Pennsylvania
    Re: hay spear build
    nice work
    Jan 2007
    knoxville, tn
    Re: hay spear build
    well got a chance to work on the spear again today
    these are the 1.25" sleeves that were welded in the other day
    today I cut out the stabilizers from 1" sch. 40 pipe
    a quick trip to the drill press and we have holes for lynch pins, I like to be able to pull the stabilizers out.
    this is how the will fit in the 1.25" sleeves, I also cut out stop collars to go on the other side, pics later
    next post
    victor o/a
    lenco panel spotter
    hobart hf-box
    Jan 2007
    knoxville, tn
    Re: hay spear build
    stop collars welded on
    finished stabilizers
    top post cap welded on
    next post
    victor o/a
    lenco panel spotter
    hobart hf-box
    Jan 2007
    knoxville, tn
    Re: hay spear build
    cut out the end plates and cut 1 3/16" holes for the cat. 2 lift pins, bevel for welding
    prep the end of the tubing for the end plate
    in place squared and tacked
    all welded up
    next post
    victor o/a
    lenco panel spotter
    hobart hf-box
    Jan 2007
    knoxville, tn
    Re: hay spear build
    putting in the cat. 2 lift pins
    the almost finished spear
    the long spear should be here tomorrow and have already cut out the pieces for the top link to attach to.
    G3
    victor o/a
    lenco panel spotter
    hobart hf-box
    Mar 2006
    Yuma, Arizona
    Re: hay spear build
    I couldn't figure out what the hell you were doing until maybe the last two pics. Is this for a 3point hitch setup on the rear of a tractor? I am not knowledgeable at all on those, but my next door neighbor installs laser leveling systems on tractors and I have seen them. Is that the type of setup you are using (3point)?
    Lincoln Precision TIG 275,Undercart cooler,Foot/Finger Amptrollers
    Lincoln Hobby-Weld 110v
    Lincoln SP-200 MIG and Hi-Freq Tig
    Jan 2007
    knoxville, tn
    Re: hay spear build
    yeah just a simple three point hitch hay spear for the farm tractor.
    G3
    victor o/a
    lenco panel spotter
    hobart hf-box
    Jan 2007
    knoxville, tn
    Re: hay spear build
    got the long spear in today by ups, so lets finish this thing up, will try it out tomorrow to feed the cows.
    new spear (red part), weld in tapered sleeve, nut
    lay out hole and plasma torch it out
    well now its all welded up, two plates on the right are for the top link.
    another view
    next post
    victor o/a
    lenco panel spotter
    hobart hf-box
    Jan 2007
    knoxville, tn
    Re: hay spear build
    new spear installed and the nut tightened
    installed on the tractor ready to feed tomorrow.
    thats all folks.
    wanna see pics of the cows??
    G3
    victor o/a
    lenco panel spotter
    hobart hf-box
    Mar 2005
    Carrollton GA
    Re: hay spear build
    Good start-to-finish project.
    Smithboy...
    Mar 2006
    Yuma, Arizona
    Re: hay spear build
    Show me a pic of you spearing a cow! Instant BBQ rotisserie! That would be graphic!
    hehe Ok, sick, dark Humor. I was just kidding. Keep PETA away from my PC!!!
    Way cool project. Thanks for the lesson.
    Mar 2005
    Carrollton GA
    Re: hay spear build
    When I was in college, as a joke I put up a few fliers announcing a PETA fundraising Bar-b-que, and I put the phone number of a professor that DID NOT have a sense of humor as the contact for more info...needless to say, he didn't get the joke...neither did the ACTUAL PETA members.
    Smithboy...
    Re: hay spear build
    looks great! let's see some pics of the cattle!
    May 2007
    fortlauderdale fl.
    Re: hay spear build
    What you call the spear looks like what i call a Johnson bar.About 17 dollars at home depot.Am i missing something? Johnson bar is used for busting up packed dirt or road rock so you can shovel it up.Anyway great job!! I like making my own tools also
    Victor SuperRanger O/A
    Solar mig
    Lincoln Powermig 140
    Southbend 9in lathe
    350# kohlswa anvil
    Miller Maxstar 150 stl etc....
