Welding a grade 8 bolt
Results 1 to 25 of 28
    Oct 2007
    I am making a bracket and wanting to weld a grade 8 bolt to it and was wondering if this is going to weaken it.
    I am making an adapter for a power brake booster that will go from the brake booster to the brake master cylinder. I will be using two 3/8" grade 8 bolts that will pass through a 1/2" plate of C1018. The bolt heads would be welded to keep them from turning.
    Is this okay to do?
    Jan 2008
    Covington, LA
    Re: Welding a grade 8 bolt
    Yes, welding just about any bolt will tend to weaken it. I think if you use very small tacks you'll be ok though. Use the least amount of heat possible. Just enough to keep it from turning with the amount of tourque you're gonna put on it. Better yet, put the bolt in and mark where the head will be. Weld a small tab or two to the plate that will keep the head from turning.
    Anything can be fabricated on-site. Truth is fabricated online.
    Grade 8 is way more than you need for that application anyway. It'll be fine.
    May 2007
    SoCal
    Put a wrench on the bolt, then weld the wrench.
    "Where's my 9/16'ths?"
    Job 28:1,2
    Danny
    Jan 2006
    western pennsylvania
    I would tack it with silicon bronze. Grade 8 bolts don't take kindly to welding in general from my experience.
    MILLER 330 AB/P
    MILLER GOLD STAR 130
    KUBOTA BX24
    CASE MINI HAY PRESS
    BENCH MILL
    HYPERTHERM 45
    BABY HOSSFELD
    Ca, USA
    I would tack weld it and not think twice about it. Like Turboblown said, grade 8 is way overkill for that application anyways.
    MM350P/Python/Q300
    MM175/Q300
    DialarcHF
    HTP MIG200
    PowCon300SM
    Hypertherm380
    ThermalArc185
    Purox oa
    F350CrewCab4x4
    LoadNGo utilitybed
    Bobcat250
    XMT304/Optima/Spoolmatic
    Suitcase12RC/Q300
    Suitcase8RC/Q400
    Passport/Q300
    Smith op
    Oct 2007
    Thanks for answering. I was looking at my factory service manual and it shows the torque specs as being 9-15 lb pounds so I guess it is overkill. I just don't want to chance it.
    Mar 2006
    Oklahoma
    use grade 5 if thats all the torque grade 5 will stretch before it brakes grade 8 will snap before it stretches
    Western PA
    I've welded grade 8 bolts and nuts, and torqued them enough to stretch the threads ( read ruin them) without failures otherwise. Go for it.
    Jul 2007
    Cape Cod MA
    Quote Originally Posted by prop-doctor View Post
    Correct, higher grade is not always a good thing.
    Other thoughts:
    thread the plate the bolt is going through and use thread lock.
    or
    Use wire locks.
    Me!
    Sep 2007
    Lower mainland, British Columbia
    I've used literally hundreds of grade 8 bolts for weld in place studs...never heard of one breaking. I like them for studs because the threads will take a lot more abuse than grade 5 and also they weld nicer because they're not plated.
    I'm sure grade 5 is more than sufficient for your application....Whatever you weld in you only need a 1/4 inch of weld to hold it.
    Jan 2008
    Sun Valley, Ca.
    I personally like Scott9116 solution of welding a couple of tabs on the plate next to the bolt.
    After that, welding any bolt becomes a moot point.
    Northern Cal., Shasta County
    He's only wanting to weld on the head of the bolt, not the bolt shaft itself. If he gets it hot enough to damage it to the point of pulling the head off it'll be a first and should be put on record.
    By the way, what are typical torques for a 3/8ths bolt??
    Jun 2005
    As far as I know, welding and or tacking a heat threated bolt will weaken it.
    Tacking also melts metal, and when you achieve the melting point of a metal the heat threatment is lost.
    My Babies:
    HF Drill press
    HF Pipe Bender
    3 4.5" Black and Decker angle grinders
    Lincoln Electric PROMIG 175
    that´s it!
    Jan 2008
    Covington, LA
    About, ten years ago I had the bolt that was holding the master cylinder's push rod to the clutch pedal wear through and fail. I ended up with a steel rod in my leg. Granted this was an old truck that required over 90lbs of force on the pedal to engage the clutch and have no idea what grade the bolt was (due to the fact it was welded to the top of the pedal). my thinking is that if it were grade 8 it would have worn through the eye of the rod first and deflected the rod from my calf. My thinking is that welding heat drew out what ever temper the bolt had. Heck, it may have been oxy welded with a coathanger for filller for all I know. But, I do know that I only weld bolts as a last resort now.
    Oct 2007
    Thanks for all the replys so far. I can't really weld a tab because the bolt head has to stay flush with the top of the 1018 plate. It will be countersunk. I may just have my machinist mill out the 1018 to the size of the bolt head since he has a CNC machine then there would be no welding. The reason is because the 1018 plate will be sandwiched in between the brake booster and the master cylinder. Once I get this done I will post a pic or two. Will visit him in a couple weeks.
    Feb 2007
    West By Golly Shelby NY
    You are only welding the head of the bolt, I would just make 2 passes on one side of the hex. The second pass will add more heat to the first one and should keep it from cracking.
    David
    Real world weldin.
    Sep 2006
    Central Illinois
    The grade 8 bolt may be slightly weaker after you weld it than it was new, but it will still be stronger than a grade 5 bolt is when new. Grade 8 bolts get their strength from the steel alloy, not from heat treatment.
    If they were heat treated, they would have ground threads- rolled threads wouldn't work due to warpage from the heat treatment process.
    Hobart Stickmate LX AC/DC, Millermatic 252 & 30A spoolgun, Thermal Arc 185 TIG, Miller BWE
    Smith Oxy-Ac
    Bridgeport 2J , South Bend 42" 9A
    Husky 7.5 HP 22.3 CFM 80 gal compressor
    Western PA
    This is an improvised clamp that I made in the field. One inch grade 8 nuts welded to scrap channel with 7018. I used a 3' bar to spin it with about all the strength I could muster without a trip to the hospital. It took longer to find the parts than it did to build it and it worked great. Ugly, but got the job done.Unless you will have stresses near the design limit of the fasteners I doubt that any weakening is all that significant.
    Nov 2007
    If grade 8 bolts don't break after being welded on these days it is probably because these Chinese made bolts are not true grade 8. Back in the days when bolts were made in America I worked at a shop that was rigging up a truck with a side boom winch. The guys working on it mounted the winch late one afternoon and welded the bolt heads so you wouldn't need a backup if you had to pull the winch to work on it. Imagine everyone's suprise the next morning when we came to work and the winch was laying on the ground. All the bolts had snapped off at the heads where they were welded.
    Western PA
    Interesting...
    Western PA
    This question got me thinking, so I did a bit of looking and found this:http://www.portlandbolt.com/faqs/wel...h-anchor-bolts
    In another topic they say that ASE grade 8 is equivalent to ASTM A490.
    I'll probably still weld to them until it bites me in the a$$, but figured I'd pass this along.
    Nov 2007
    Stoon, Sask, Canada
    Quote Originally Posted by Oldtimer View Post
    I had a very similar experience last week. Tig welded 3 1/2" Grade 8 bolts to a 1/4" plate and mounted a vice on it. Tightened them with an impact, one broke immediately, the bolt not the weld! It looked crystalized, the other two bolts were holding so I didn't worry about it right away just did what I had to do. The next day all that was holding the vice on the plate was gravity!
    home:
    2007 302 Trailblazer-Robin
    2008 Suitcase 12RC
    Spoolmatic 30A
    2009 Dynasty 200DX
    2000 XMT 304
    2008 TD Cutmaster 52
    Sold:
    MM130XP
    MM 251
    CST 280
    work:
    Invision 350MP
    Dynasty 350
    Millermatic 350P
    Retired:Shopmaster 300 with a HF-251
    Apr 2004
    SW Lincoln County, TN
    A short dissertation as to why that statement is not true:
    http://www.pirate4x4.com/tech/billav...lts/index.html
    Enjoy.
    America's enemies best ally,
    the Democratic Party!
    Oct 2007
    East Meadow New York
    Quote Originally Posted by riley mcmillan View Post
    You are right.
    Almost any material that is to be machined into a bolt. Will tend to weld poorly. The harder the bolt the worse it will weld.
    Just like most of us know not to weld leaf springs, drill bits, or screw drivers. We should know not to weld hardened bolts.
    The steel I believe is a medium carbon steel made to harden. You should avoid welding such a material, hardened or not.
    It can literally fall off when done welding it well.
    Sincerely,
    William McCormick
