Weldcraft WP-17 Tig Torch
Results 1 to 7 of 7
    Feb 2008
    Camillus, NY
    I just bought a new 25' Weldcraft WP-17 tig torch, to do a stainless steel weld job. The torch is a single combination power/gas hose with the Miller twist connect, with the 12" pigtail for the shielding gas hook up. The torch design has been change to make is very similar to the Miller Diamondback tig torch line, not really surprising as both companies are owned by ITW, with finger grooves for better control with gloves on and hand comfort. A job done for the company and a new torch for my Miller Maxstar 200.
    Jack
    http://www.weldcraft.com/
    Nov 2007
    New Hampshire
    Re: Weldcraft WP-17 Tig Torch
    Quote Originally Posted by platypus20 View Post
    Jack
    What is the amp rating ? Is it 150?
    http://www.PlasmaMetalCutter.com
    GiantTech Cut40D
    GiantTech Cut50D
    GiantTech CT520D
    GiantTech Tig200s
    GiantTech Arc200
    GiantTech Tig200PACDC
    Miller MM210
    No Brand Chinese Chop Saw
    No Brand Chinese 4" Angle Grinder
    Feb 2008
    Camillus, NY
    Yes, 150 amps
    jack
    Jul 2007
    Cape Cod MA
    It will do 200A (that is what Miller sends with the sync 200s) but she gets hot fast!
    Me!
    Sep 2007
    Houston, Texas
    Do you have a problem with the 17 torch? John
    SMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFC
    and Shielding Gases. There all here.
    So Calif
    I do a lot of 16ga stainless. Before I got a water cooled I used a #9 air cooled they are 125 amp. Then if you go up to a water cooled #20 all the cups, collets and holders from the 9 will fit the #20 And besides the 9 is lightweight. and a lot more compact than a 17.
    mm135
    HTP Invertig 201 With water cooler
    9" Southbend Lathe
    Lots of hand tools.
    Oct 2007
    Odessa, TX
    The 17 and 225 share the same consumables as well.
    The difference between art and craft is the quality of the workmanship. I am an artist.
