Invertec V155-S Review
Results 1 to 25 of 45
    Feb 2007
    West By Golly Shelby NY
    It finally came today. Double boxed, shipped UPS from Lincolns Kalafornia warehouse. (they didn't have any in Ohio). It takes a good knife and some time to get the machine out of the boxes. It came with 3 instructions in different languages.
    First things first. I plugged it into a 30 amp 110 v outlet in my shop. Started out with Hobart 3/32 7018 right out of the oven. Arc force on smooth and 85 amps which is where I run the stuff and had my way with it. First rod stuck to the plate. After that it was a little too hot, so I turned it down to 80, then 75 and the slag started curling up on the 1/4" plate I was playing with.
    Next I plugged it into a 220 outlet and set it at 140 amps and ran some of lincoln's best 7018 again right out of the oven. The first strike stuck to the plate. After that, it too was a little too hot, so I turned it down to 135 and ran a few sticks. Nice welds more slag curling. Life is good so far. Then for fun, I ran one stick of 5/32 lincoln 7018 to see if it would do it. I turned it all the way up. It ran it, just a little cold. As I burned up the one rod when I got towards the end of the bead, I put the arc out twice. So far all good except the rod sticking on the first strike.
    Next I put it back into the 110 30 amp outlet and ran stick after stick of 3/32 7018 for almost 15 minutes. I didn't even stop to chip the slag. 13 rods total. No problems, no overheating, no temp light, just pretty beads.
    This is good! NOW for the same test on 220 with 7018. I set it on 140 and ran 7 rods in just under 15 minutes. No over heating of the machine. The air coming out of the front was 75* f according to my infrared thermometer. The cables were another story. They are #4 and were 94*f in my 60* shop. So much for the claimed duty cycle. I think I could have welded all day with it.
    First up grade will be #2 cables.
    I then plugged it into a 15 amp 110 volt outlet and ran 3/32 rod at 75 amps. I got ONE INCH and the breaker popped. Turned it down to 65 amps and tried again. Got two inches and it got dark in the shop again.
    Tonight I have another metal box to make out of 16 guage bottom and 1/8" sides. I am going to tig it to see how it works. This has no plug for a remote, but I have done more tig welding with out a remote than with.
    No pictures today, I left the camera at work. I will post them tomorrow.
    Machine weighs less than 15 lbs and comes with a shoulder strap. It has one knob for amps and a switch for smooth or crisp smaw and touch start tig. That is all....simple like me.
    All in all, it does more than I expected and more than the manual says it can as far as duty cycle.
    I'm gonna go tig with it for a while
    David
    Real world weldin.
    Feb 2006
    Re: Invertec V155-S Review
    I found the same with my little miller maxstar 150. I could tig until I could not touch the torch, or anything around me it got stuff so hot. And I never hit the duty cycle on it. I wish I had kept the little bugger!!!
    Aug 2005
    Georgia on the GA/AL line
    That's good to know David. I've been keeping my eye on that machine myself. sounds like I need to go ahead and put an order in.
    Feb 2008
    Camillus, NY
    David,
    How did you make out with the V155-S, I bought one this morning at 10:00 am and had to return it at 12:30 pm, It kept tripping the breaker, I have a 110 vac outlet at the breaker panel, fed with a 30 amp breaker, originally set up for my original Hougen mag drill, and the welder was plugged directly into the outlet. When welding with 3/32" 6011C at 75 amps, the unit was drawing 38 amps, after about 2-3 minutes the breaker would trip, to get the amp draw down below 30 amps, I had to run the unit at 60 amp output. I tried to run some 3/32" Lincoln Excaliber 7018, couldn't get it to flow, so I turned the amps up to 80-85 amps, it would run for about 45 seconds, then trip the breaker, real nice bead, but was drawing 40+ amps. Switched over to 230 volt supply, made all kind of stranges clinking and buzzing noises, with no weld output, shut the unit off waited 5 minutes, turned it back, on lots of clicking and flashing lights still no output, at this point gave up and returned the unit. Hopefully you will have better luck, I guess at this point I wll stick with my Miller Maxstar 200SD. I'm very interested in your continued review of the welder.
    Jack
    Feb 2007
    Jack,
    For now, I can tell you I ran 1/8" 7018 at 130 amps on 110 volt 30 amp breaker for about 2 sticks before the breaker tripped.
    It seems the only duty cycle I have to contend with is the breaker. Sounds like you got a bad one, sorry to hear it. This thing rocks. PICS later tonight.
    Today I made #2 gauge stinger and ground for it. I will be running it more tonight. I have a hall effect inductive DC pick up and will see what I can get out of it for Max amps and to see if the dial is accurate like I do with every machine I get.
    If there is anything some one wants me to do, go ahead and ask.
    3 year warranty. That is why I ran it hard the first day, if its going back, it would be now. I have some work for it and want to see how fast I can make it pay for its self.
    David
    Real world weldin.
    Feb 2007
    Here come the pics.
    First is the 1/8" 7018 at 135 amps 220 outlet. Set on Smoooth.
    This is the 5/32 7018 machine turned all the way up. See any spatter?
    Here is where I put the arc out twice.
    3/32 7018 110 volt 30 amp outlet. 13 rods, 15 minutes continuous welding 80 amps.
    Slag off same welds
    Real world weldin.
    Feb 2007
    1/8" 7018 110 amps, 220 outlet vertical up
    I tigged another box, this one is 4X6, bottom is 1/16", sides are 1/8" X 1". No filler
    This was done flat, but I couldn't get a good pic, so I turned it sideways.
    Tig up, machine turned all the way up
    More UP
    Real world weldin.
    Feb 2007
    Here is a weave over the stringer up. I kept switching between S2 and S6 filler, so I don't remember which. sorry.
    Vertical up profile
    Real world weldin.
    Feb 2007
    Inductive pick up. The dial is spot on.
    settings and set up.
    Here you can see the hot start in the beginning.
    The dotted line would be 100 amps, it was set on 80. You have to ignore the average since it includes the time I wasn't welding. I checked it through out all the ranges on the dial. 1mv=1amp. Machine was on "crisp". When its on smoooth, the line is flatter and hot start is less.
    I was running 1/8" 6013 DCEN, my son turned the machine all the way down to 5 amps and I kept the arc going. It was small, but..... then he turned it back up.
    The only bad thing is inital strike can stick if I am not gentle. Once one rod has been run, it doesn't do it any more. Must be the automatic self adjusting hot start.
    I LIKE IT!
    David
    Real world weldin.
    Jan 2006
    In A Nice Comfy Chair
    Welds look good David..
    Getting the weave down pretty good!
    ...zap!
    I am not completely insane..
    Some parts are missing
    Do not attempt.
    Feb 2007
    Thank you Zap
    David
    Real world weldin.
    David glad to see you like you new welder. Monday I purchased a Esab 150 miniarc. The v-150 Lincoln was my first choice, however the stick only unit was back ordered until July. I didn't need the tig accessories.
    Try some stick welded Aluminum. The Esab welds Al. wonderfully. It is like welding with 6011.
    My miller 150s didn't weld Al as well. My thermal arc 80 did better than the miller but start up was difficult. Curious how the lincoln will do.
    Feb 2007
    Tapwelder, I never stick welded aluminum. I would try it to see how it does, I have some scrap to give it a shot. Next time at the LWS, I will pick up some.
    David
    Real world weldin.
    Apr 2008
    David i thought you were getting the V160.How would you compare arc quality to your Lincoln engine drive?Thanks for the review.
    Feb 2007
    brh1969,
    So, ya didn't get the story.....
    I wanted a V160-S. Went to my LWS, they told me the -S was discontinued. The V155-S replaced it. Duty cycle was lower, and no plug for a remote on the 155. THEY recommended the V160-T. It has the exact same electrical specs and the 160-S, but Pulse, a gas valve, and High Freq start or Touch start tig. NO adjustable arc force. With tax, $500 more. I ordered it and waited.... and waited.... Finally I made them call and see if it was shipped. Ship tomorrow.... I went back in a few days they called again, no ship for another 2 weeks. Back order. Went home, spotted a V250-S used on Ebone for a good price so I bought it.
    THEN I ordered the V155-S off the internet for $670.00 to my door. After buying both, I still didn't spend as much as the V160-T would have been.
    I stopped at the LWS this week and made sure there were no hard feelings either way.
    No plug for the remote on the V155-S,The tig is in post #7.
    The V155-S and V250-s both have soft and crisp arc.
    For the quality of the arc compared to my Ranger 250, I can get a smoother arc from the ranger than either one of those inverters. Not by a lot.
    I am still playing with the 155. I found if I touch the rod to the work straight in, then rock it in the direction it should be, the arc starts right up. The rod does stick the first time after being turned on. Its a quirk of the machine. I can start it by touching the rod gently. If I bang the rod on the plate it just sticks. Once an arc is established, then next time and all after that the rod doesn't stick.
    That and the slightly small cables are the only two things I can find fault with. I paid $1.56 a foot for #2 cable, even got red and black.
    David
    Real world weldin.
    Aug 2005
    Sounds Good, David. Looks Like I'm gonna have to order me one now. I've been looking for a small inverter stick machine That looks like it will fit the bill just right.
    Feb 2007
    I ran the Ranger 250, V250-S and V155-S All with 3/32 7018. I got the machine set best as I could and ran one flat and one horizontal bead with out changing the settings. All of em run sweet.
    The rod has been out of the oven for a week or so and shows it. Sometimes it sticks. The ranger 250 will start welding from an idle. My last machine would not do that.
    Be back with the pics.
    David
    Real world weldin.
    Feb 2007
    Here are the beads.
    Ranger 250 on smooth, 85 amps flat
    Ranger 250 horizontal
    V250-S just over 85 amps, hot start 4 arc force 4 set on smooth flat.
    Same as above horizantal
    Real world weldin.
    Feb 2007
    V155-S smooth, 80 amps flat.
    Horizontal
    A practice bead same settings.
    3/32 Hobart 7018 not right out of the drier.
    As you can see, the V155 seems to run a little hotter.
    David
    Real world weldin.
    Apr 2008
    Guess i didnt get the story sorry David.Thanks for the info.
    Nov 2008
    Florida
    Thanks for the write up, I have been considering a V155 and I think you made up my mind for me. Now if I can just get my salesman back off vacation I will get this thing on order.
    Jamie Webb
    Welder & Inspector
    Business and Hobby
    Lincoln Pro-Mig 180 with Spool Gun and Lincoln AC225
    Newbie looking for advice:
    Is the V155-S suitable for a novice to tig weld aluminum? Suggestions appreciated. Thanks
    Jan 2009
    Ohio
    its dc only but dcep will weld thinner aluminum. ive done it with mine with outstanding results. a very amazing little machine.
    Forgive my ignorance: what is DCEP?
    Is there a better entry level (cheap) welder for a novice to TIG weld aluminum?
    Steve
    Mar 2008
    Colorado
    Quote Originally Posted by Huskydoggg View Post
    Steve
    DC electrode positive, which I'm thinking will blow the tungsten right off at the collet, unless you want to weld foil. There is no (cheap) welder for a novice to TIG weld aluminum. You don't just get to wake up thinking "I want to weld aluminum." It isn't that simple, and it's expensive. The entry level Miller Diversion 165 has an msrp of $1617 (and that doesn't include the argon bottle). You really need AC to learn to TIG alum and that's where the money goes.
    9-11-2001......We Will Never Forget
    Retired desk jockey.
    Hobby weldor with a little training.
    Craftsman O/A---Flat, Vert, Ovhd, Horz.
    Miller Syncrowave 250
