Settle a question does a mig weld is strong as a stick weld?
Results 1 to 23 of 23
    Feb 2010
    the people I have talked to communicate that a stick weld joint/seam is stronger then a mig weld.
    Is this so?
    Comparable amperage welders welding same material, which is stronger weld.
    Mig is easy and looks good, but does it penetrate the steel being welded like the stick weld?
    Any comments or explanations?
    Los Angeles
    Re: Settle a question does a mig weld is strong as a stick weld?
    A properly executed Mig weld is just as strong as a properly executed stick weld.
    MM211 (Sold)
    Miller 125c Plasma 120v
    Sep 2006
    Marlborough, The Peoples Republik of MA
    If you know what your doing, by all means yes. If you are some ham fisted monkey with a 110 MIG trying to repair a D9 hell no.
    May 2012
    Australia
    I would say they are both equal in strength if the welds are both equally well done, but an arc welder needs less amps than a Mig to produce the same result.
    Cheers Andrew
    Jan 2006
    MIG welds should compare to any other low-hyrdogen weld. They tend to be much tougher than many of the stick welding practices, 6010, 6011, 6013, 7014, etc... I always hate dealing with dual-shield tacks because they are very hard to break if you get them wrong.
    We run a lot of dual-shield wire where I work but our welders always complain when we make them do it on pipe. Dual-shield wire is a low hydrogen process and compares to 7018 with a finished weld. The difference is that stick gives you better control over blowing through so its easier to produce a proper full penetration weld with no porosity using stick welding. This is very advantageous for pipe welding where the inside of the pipe is not accessible. But... if the backside is accessible, wire feed is preferred for speed reasons. The process typically involves one pass on the backside, a back gouge on the front side, then 2-3 passes on the front. This gives full penetration with much less skill and time involved. There is no difference in strength.
    Dec 2009
    Stevens Point, WI
    Any weld from any machine in the end should be as strong if not stronger than the base metal. If its not your doing it wrong.
    Jan 2008
    Richmond, Virginia
    Quote Originally Posted by TozziWelding View Post
    Then why do they have settings all the way up to D-10?
    Syncrowave 250 w/ Coolmate 3
    Dialarc 250, Idealarc 250
    SP-175 +
    Lincwelder AC180C (1952)
    Victor & Smith O/A torches
    Miller spot welder
    Jan 2013
    Florida
    Jul 2011
    Bossier Parish La.
    I think he was reffering to a D-9 Caterpillar Dozer, not the settings on that little MIG machine. You could set it(the little MIG) to D9 or 10 and it still wouldn't be up to snuff to weld anything on one of those dozers.
    Oct 2011
    Jacksonville Florida
    Quote Originally Posted by Bistineau View Post
    I think that was one of those joke things.
    Airco Ac/Dc 300 Heliwelder
    MillerMatic 200
    Miller Maxstar 150STL
    May 2010
    Port Orchard, WA.
    Awhile back I did some fillet weld break tests with different rods, and Lincoln's L-56 Mig wire.
    6013 broke with only 3-blows of a 4-pound hammer.
    6011 = 8-blows.
    7014 = 10-blows.
    6010 5P-Plus = 10-blows.
    7018 cold never seen the inside of an oven = 18-blows.
    7018 right out of the oven = 23-blows.
    L-56 = 29-blows.
    Don’t pay any attention to me
    I’m just a hobbyist!
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Oct 2012
    interesting, Thanks CEP
    You can always wash your hands.
    Jul 2011
    Utah
    Quote Originally Posted by burntside bob View Post
    Yes the mig process does is as strong as stick.
    Aug 2008
    Sudbury, Ontario
    Yes and no.
    Yes they can both produce an equal strength weld when done properly.
    No in that a mig is capable of making a nice appearing weld with no penetration/strength if not done properly while a poor stick weld is more obvious when not done properly.
    SA 200
    Idealarc TM 300 300
    MM 200
    MM 251
    30a Spoolgun
    Precision Tig 375
    Invertec V350 Pro
    SC-32 CS 12 Wire Feeder
    Oxweld/Purox O/A
    ArcAir
    Hypertherm Powermax 85
    LN25
    May 2011
    It all comes down to filler material. Technically speaking both er-70 (GMAW filler) and 7018 (SMAW filler) have the same tensile strength rating, so in theory if the weld were executed for optimal penetration and weld size were the same in both processes then they should, again in theory, be equal.
    Again in theory not accounting for weldor error (experience), situation, time of day, air temp, ect., ect.
    Some blue machines
    Some red machines
    lots of heavy steel
    Dec 2012
    Utah
    I assume that was just a joke, as that was my first welder. The higher wire feed speeds are pretty much just for loading wire. If I remember right, at the "D" power setting, recommended wire feed speed is 1.5, with .035 flux core. My little weldpack 100 never liked that "D" setting, always seemed to struggle with it. Did fine on "C".
    To the OP, I think the problem with MIG welders is that it is easy to run them a little cold, or with your wire speed too high, and get "proud" welds that look thick, and big, but don't penetrate deeply.
    If I am welding a new material, I will weld a few scraps, and check my penetration.
    Check out my channel
    https://www.youtube.com/channel/UCkz...bZg8AYNXGqBjZQ
    "Both oligarch and tyrant mistrust the people, and therefore deprive them of arms." - Aristotle
    Sep 2009
    Quote Originally Posted by norite View Post
    Yes and no.
    I agree. I think its way to easy to run a bead with MIG that looks good but lacks penetration. With stick it stands out like a sore thumb if you don't have penetration. I think with stick the machine does more of the work and with MIG the operator can make the weld look good (different technic) with the settings too cold. My 2 cents.
    Dec 2012
    Tracy, CA
    6011 = 8-blows.
    7014 = 10-blows.
    L-56 = 29-blows.
    That's a lot of blowin'. :-)
    Lincoln Vantage 400
    Trailblazer® 302 Air Pak™
    Miller Dynasty® 350
    Millermatic® 252
    Millermatic 350P Aluminum
    Syncrowave 351
    LN-25 Pro (Two)
    Multimatic 200 (Two)
    Diversion™ 180
    Spectrum® 625 X-TREME™
    Thermal Dynamics ‑ Cutmaster 52
    Feb 2008
    NH no mo - MA now.
    Depends on what part of the D9. How about cab sheet metal?
    - Mondo
    Member, AWS
    Lincoln ProMIG 140
    Lincoln AC Tombstone
    Craftsman Lathe 12 x 24 c1935
    Atlas MFC Horizontal Mill
    I'll just keep on keepin' on.
    Feb 2008
    NH no mo - MA now.
    See AWS Presentation (PowerPoint) slide show here:
    http://www.aws.org/educators/Library/0000/000506.ppt#1
    Slide # 14 shows a MIG machine set for 215 amps. Is this "hot" enough for repairing a D9?
    - Mondo
    Member, AWS
    Lincoln ProMIG 140
    Apr 2012
    On a farm, north of Scranton, PA
    Looks to me like 215 inches per minute at 20.1 volts.
    May 2009
    Wyoming US
    Don't seem to have power point on this computer ,but 20.1 volts would only be about 120 amps.
    Northern Cal., Shasta County
    Yeh the little amber light was lit up by the 'IPM' designation. So you'd have to know the size of the wire and it's apx burn off rates to get an idea of the amps.
