Welding exhaust manifold?
Results 1 to 23 of 23
    Sep 2007
    I have a 97 Jeep Grand Cherokee. I believe the manifold has a crack in it. I am assuming it is cast iron? Am I right you have to use a high nickel rod? Any recommendations on rod and any different technique with this rod? Thank You as always!!! I have a Lincoln AC225.
    Re: Welding exhaust manifold?
    I've had 100% success with Ni99 filler, running stringers....no preheat of postheat. I bevel out the crack, and weld it up.
    Feb 2007
    West By Golly Shelby NY
    Nickel 99 is what works best for me. Bevel, heat red, then weld with low amps and stick in a bucket of Speedi dri so it cools slow.
    David
    Real world weldin.
    Feb 2006
    Could be cast SS. If it is, I would still follow the info Engloid and David gave you. Can't go wrong with good prep work.
    Sep 2007
    How do you tell if it is cast iron or steel? Where do you get the Speedi dri? I wonder if TSC carries those rods? I know they have a good variety of Hobart rods.
    Feb 2007
    1) If its an exhaust manifold, its cast iron.
    2) Speedi dri is available in any auto parts store about $8.00 a bag.
    3) Yes Tractor supply carries Nickel 99.
    Go for it, show us pictures
    David
    Real world weldin.
    Feb 2006
    David, I had an old 1985 chevy 3/4 ton for a hundred or so years. It had cast SS exhaust manifolds. They had a lot of surface rust on them. I wonder if many other cars/ trucks have these??
    Feb 2007
    Quote Originally Posted by Rojodiablo View Post
    I don't think I have ever seen a stainless steel manifold on a "regular" car or truck unless it was aftermarket or on a vette or something like that. I also was told by my weling instructor that once stainless is red hot, its not stainless any more. But I DO see a lot of stainless exhaust systems and they work great.
    Back to the question. Cast Iron makes small orange sparks that don't go but a foot from the work. Steel makes yellow sparks that go a long ways like 7 feet. Tool steel or hardened steel have tails on the sparks.
    I don't have a clue what stainless sparks look like from a grinder.
    David
    Real world weldin.
    Cassville, Missouri
    speedi dry, floor dry, grease sweep, ground clay, cheap kitty litter . if it's made from clay it's all the same. there's dozens of brand names
    Sep 2007
    I don't suppose a small propane torch is gonna get it hot enough? DON"T LAUGH!!!
    Nov 2007
    Yucaipa, CA 92399
    Hey, any preheat is better than none, IMO!
    Western PA
    Stick it in the oven for pre-heat.
    Oct 2007
    Odessa, TX
    Or you can braze it and avoid pre heat, post heat and slow cooling. I've had 100% success with it on exhaust manifolds for many years. Including the stick welded ones that later cracked or were just a mess to begin with.
    The difference between art and craft is the quality of the workmanship. I am an artist.
    Feb 2006
    Quote Originally Posted by David R View Post
    David
    They were stock manifolds, 1985 ChevyC20/ 30 chassis. 454 motor, auto tranny. O2 bungs in the manifolds for smog. The manifolds were a drop down stlye, almost like a header design. When I got the truck, they were dusted with rust, but after years of driving, they were coated in a skin of light rust. No cracks ever, very heavy pieces. I only found out they were SS when I was looking up parts. The only series trucks that had my particular smog pumps was one with 13" rear drums, and SS exhaust manifolds. Pretty uncommon from what the parts guy said at the dealership.
    Sep 2007
    Kook, got to get some rods from TSC and when I get started I will get some pics ofcourse. We all love pics LOL.
    Jun 2008
    Central California
    Vermiculite, the type used for packing things in (and which is often thrown away by labs which get chemical bottles delivered in it), is an ideal material to bury items in when slow cooling is needed.
    It is both an excellent insulator, is very light, and is capable of withstanding very high temperatures.
    It is actually a mineral which is mined and then expanded by heating.
    Vermiculite is also sold by gardening stores for addition to potting mixes, but may be somewhat wet when sold for this purpose . Obviously, the wet material won't work as well, but it can be dried out first.
    Sep 2007
    Do I need any different technique burning this rod? Any guess on settings to get me close. Lincoln AC225 machine.
    Sep 2007
    NI99 can be welded with AC.
    SA200,Ranger8,Trailblazer251NT,MM250,Dayton225AC,T D-XL75,SpoolMate3545
    SGA100C,HF-15-1 RFCS-14
    When I stick it, it stays stuck!
    Sep 2007
    O.K. thanks I appreciate the info.
    Apr 2008
    Canada,Ontario
    I agree with Jolly Roger on this one, I have always had better outcomes by brazing cast iron with a large V-prep rather then using the Ni99 rod.
    Sep 2007
    Well, I got a chance to look at it today and it actually looks like regular steel tubing. The flange might be cast but the manifild tubing looks like steel. Anyway to tell for sure? I think I see the crack (not sure). If it is just regular tubing I can just bust out the HH187 and mig it up.
    Oct 2007
    Odessa, TX
    If you braze it you won't have to worry if it's cast or not. It works well on both. Make sure you have it good and clean. Cast iron is porous and soaks up the carbon from the exhaust as well as oils and such. After I clean and grind I flash it with my cutting torch with the cutting air kicked in. Brazing rods are cheaper than nickel rods.
    Jan 2008
    Fond du Lac, Wi
    David
    Wow,
    Hope that guy isnt teaching anymore....yikes.
