Starter Ear Repair..
Results 1 to 8 of 8
    Jan 2006
    In A Nice Comfy Chair
    Well it was prettymuch a straight forward fix..
    I used the broken piece and just welded it back on..It was plenty thick enough..
    Started by beveling the ends where the weld was going on the piece with the belt sander and the die grinder on the block..
    Put the piece in place then ran the tap onto the hole then clamped the piece with the tap in place..
    Tacked the piece on..
    Ran the tap thru...
    Removed the tap..
    Welded the backside..
    Ran the tap thru..
    Removed it..
    Welded the front and side..
    Ran the tap thru..
    Removed it..
    Ground off the welds and rewelded over that..
    Made sure it was done all the way around...
    Then ground and filed the flat areas flat again..
    Ron installed the starter and it's not going anywhere!
    Some pics below of the installation but it was pretty easy all in all..
    When asked "How Much?" I just said "Merry Christmas!"
    BTW In the last pic that is NOT a crack..
    1/16" 5356 Filler..
    3/32" Red End..
    180? Amps..
    Gas Mix..
    Engine was done in place on the bench..
    I picked it up in the air with the hoist to do the bottom welds upside down..
    It was too low to the bench...
    I do all the stuff nobody wants to touch..
    ...zap!
    I am not completely insane..
    Some parts are missing
    Do not attempt.
    Feb 2008
    Indiana
    Re: Starter Ear Repair..
    Looks like a good job, not much fun I bet.
    Tim Beeker.
    Aug 2008
    Pretty neat.
    http://www.farmersamm.com/
    Nov 2006
    Nice fix.
    Oh oh, where's the dime?
    You were just one bead away from a perma-mount starter!
    I wonder if anyone has ever welded a starter on?
    Nov 2008
    Denrep,
    You must have never worked on old tractors
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    Smith Oxy Fuel setup
    Everlast PowerPlasma 80
    Everlast Power iMIG 160
    Everlast Power iMIG 205
    Everlast Power iMIG 140E
    Everlast PowerARC 300
    Everlast PowerARC 140ST
    Everlast PowerTIG 255EXT
    Feb 2006
    Nice Job Zap!! BTW, thank you for the post.
    Soda springs,Id
    Good job,Zap. It's good to see ya back,don't be a stranger.
    Mike
    Ol' Stonebreaker
    Miller 175 mig
    Victor O/A setup
    Makita chop saw
    Aug 2008
    Dansville NY
    Of course that piece had to crack in one of the worse spots to try to weld. Especially given that you did not want to fill in the treads on that hole.
    Nice work and a wonderful present to someone.
    Hope you had a Happy Turkey Day,
    Tom
