Airco welder
Results 1 to 23 of 23
Thread: Airco welder
    Airco welder
    Heres a little more info on this old airco welder that i just cant seem to figure out.Has gas flow, has water flow, but can't get it to arc. The model number is 3A/DDR 24 HPA. It lookes to have a RFC 23A Foot pedal. Looked up diagram to make sure we wired it right. It was wired wrong so we wired it to the diagram and it didn't make a difference.Any more help would be great. Thanks.Here are some pics.
    Bemidji MN
    Re: Airco welder
    I have an Airco as well.
    I noticed you are set for AC welding (aluminum), but your high freq is set to "start" instead of "continuous."
    DC set to "start"
    AC set to "continuous"
    Airco 300 - Syncro 350
    Oct 2011
    Jacksonville Florida
    Re: Airco welder
    Are you able to stick weld with it? (no remote)
    Airco Ac/Dc 300 Heliwelder
    MillerMatic 200
    Miller Maxstar 150STL
    Bemidji MN
    Re: Airco welder
    Along the same line as SquirmyPug, can you tig with the foot control unhooked, switches to standard, and high freq on?
    EDIT: This is wrong, you will see SquirmyPug corrects me below.
    Oct 2011
    Re: Airco welder
    I don't think you can use the HF or argon solenoid without the pedal, thats why I asked about stick welding. It might just fry the tungsten. (I could be wrong)
    MillerMatic 200
    Bemidji MN
    Re: Airco welder
    Excellent point - I was basically thinking along the lines of scratch start like my old rig. You are likely right and it would not work.
    Ceres, California
    Re: Airco welder
    Your Airco was made by Miller and it is a 320 or 330 ABP. You can go to miller's web site and get an owner's manual. Post the serial number and a clear picture of the relay panel on the right side.
    I might have the diagram If you need it. To get HF and weld current the main contactor must pull in.
    The main weld contactor is controlled by the panel switch or the foot control. On a lot of these units the HF will come on with the panel switch. Gas should only come on with the foot control. although it may run with the post flow timer when you turn the welder on or switch to panel on.
    With HF turned off, What voltage to you get at the weld terminals in panel on and in remote on foot control on. If no voltage, did main weld contactor pull in? Are all levers in the correct places?
    Re: Airco welder
    I checked all the fuses and they are good. In the pics o sent the welder was on the wrong setting. the reason was i tried it in all different settings to see if it would make a difference. i checked the volts going to the 3 prong plug and they all read 50 volts. No matter what possision they were in remote or standard. Even when I push down on the pedal it doesn't change. I checked the bottom 2 prong plug and it pulls 10 volts on either one.one thing I did notice is if I set the start circuit in instead of out I get a very small arc every once in a while. This machine is very complicated for a guy not experienced at all with a tig welder. I appreciate all the help fellas.
    Re: Airco welder
    Also I checked the to see if I was getting power were the torch hooks up and it doesn't show anything
    Bemidji MN
    Re: Airco welder
    If you need one, I have a miller manual PDF that is likely the one you need.
    PM me an email and I'll send it.
    Re: Airco welder
    My email is dustinbum21@yahoo.com thanks
    May 2010
    Andover, MN
    Re: Airco welder
    I should have looked at the first pic a little closer. The knife switch on the left sideframe behind the HF component door has to be closed for tig (inert) and open (metallic) for stick welding. IT will NOT tig with it open. I know because I forgot to change mine back once.
    Bemidji MN
    Re: Airco welder
    Quote Originally Posted by millrat View Post
    You are correct for some, but it depends on the year and model - some are up, some are down.
    May 2010
    Andover, MN
    Re: Airco welder
    Thanks. Good to know. I thought the 320 and 330's all had the same setup.
    Bemidji MN
    Re: Airco welder
    One of my manuals at home showed when the change happened. I will see if I can locate the info when I get home. Could help someone
    May 2010
    Andover, MN
    Re: Airco welder
    Yeah, my bad. I should've looked at the schematic before opening yap. Inert opens the circuit.
    Bemidji MN
    Re: Airco welder
    Here is the manual listing for the change on the balancing resistor switch.
    Got my #1 son to load it on the computer instead of typing
    May 2010
    Andover, MN
    Re: Airco welder
    That's why I should've looked at the schematic. Mine is slightly younger than I. It has a flat bar positioner. Nut/bolt affair both ways, ergo my confusion. Learn a lot here.
    My apologies for any confusion I may have caused
    BTW, how do you get a PDF into a pic?????
    Bemidji MN
    Re: Airco welder
    My Airco is older than me. It's a 1963 model, I'm a 1970 vintage. Your bolted style switch must be even older.
    I'm a fan of "older" equipment - most new stuff is just a fancy, breakage prone way of imitating the results of the old stuff.
    I had my kiddo scan parts of the hard copy into a pic file. The one I sent the OP was an older manual that was digital already.
    I also have a "snip" tool on my computer that lets me capture any part of the screen and save as a picture.
    May 2010
    Andover, MN
    Re: Airco welder
    I'm a late '53 vintage. The machine is (CRS) '56 or '58.
    I agree, new ones hickup or burp, it's like one of the latest commercials "customer, how much you got" ?
    I do understand why some of the technology needed to change, but we built tanks and battleships with the "old" tech. Several of which are still around today. Go figure.
    Ahhhh. I need to change some settings on the scanner. The site won't accept PDF files.
    Sooooo. Tell an "old guy" what a snip tool is. Better yet, PM me so I don't feel like I'm hijacking the thread.
