What size breaker for my syncrowave 200
Results 1 to 13 of 13
    Jan 2013
    Waupaca, Wi
    I just got a 2006 syncrowave 200 with 6 hours on it. i have it hooked up with 230v with an 80 amp breaker and when welding aluminum it will trip the breaker. idk whats up with it. it recomends 80 amp. I was only welding at 175 amps also.
    Sep 2006
    Marlborough, The Peoples Republik of MA
    Re: What size breaker for my syncrowave 200
    When running a Syncrowave at full tilt on AC they really pull some amps. I just checked the book and it says you only pull 54 amps, give or take. Your breaker might be weak, try swapping it out to start. If that dosent do the trick get your hands on an amp meter and see what it is actually pulling.
    Jan 2013
    Waupaca, Wi
    ok il try that. thanks!
    Mar 2009
    Iowa
    Mine is running off a 50 amp breaker and only trips if run wide open for maybe 5 minutes+.
    My name's not Jim....
    Jan 2008
    Richmond, Virginia
    We've tripped a 70A breaker with a Sync 250 on cold startup. Doesn't seem to be a problem running at maybe 200A with a water cooler on the same circuit.
    Syncrowave 250 w/ Coolmate 3
    Dialarc 250, Idealarc 250
    SP-175 +
    Lincwelder AC180C (1952)
    Victor & Smith O/A torches
    Miller spot welder
    city of Four Flags
    S/W 200 is supposed to pull 54 amps on either 208/230 single phase.
    Feb 2013
    NW Atlantic Ocean, MA
    This is how you determine the input requirements for your Syncrowave 200:
    http://www.millerwelds.com/service/locate_om.php
    Syncrowave 300
    Maxtron 450, S-52E, 30A
    Jan 2013
    Waupaca, Wi
    Could the machine be set up wrong?
    Feb 2013
    Could be. The manual (found in the link above) is the best place to start.
    Syncrowave 300
    Jan 2013
    Waupaca, Wi
    ok thanks
    Los Angeles
    Quote Originally Posted by TozziWelding View Post
    That is 54amps at the RATED 150 amps welding.
    The electrical specs call for a CB of 60amp or an 80amp FUSE.
    The CB is lower because they have a Time delay built in that should work/cover the short duration over the rating.
    If the OP has an 80amp CB and it is tripping then, as you mentioned, something is off fer sure.
    MM211 (Sold)
    Miller 125c Plasma 120v
    Delaware
    I must be lucky then. I have mine on a 50 amp braker with 8 feet of #6 cable and have never triped it even runing 200 amps tig welding 1/2 aluminum
    HF 95136 Plasma Cutter
    2015 AHP 200X
    Tec.Mo. Wholesale Distributor and Dealer
    Consumables for the PT and IPT torch's.
    Feb 2013
    I use a syncrowave 350 at work and I put a 90 amp breaker in (didn't have a 100 amp on hand) it stopped tripping. You need to be careful about arbitrarly putting a larger breaker in. It really depends on the size of the service wires. Too large and you take a chance of burning the wires up fire and so on. If you don't know much about electricity or the size of the wires to and from your breaker box you might want to consider hiring an electrician.
