Welding Tin Cans...
Page 1 of 19 12311 ... LastLast
Results 1 to 25 of 462
    Nov 2008
    Seguin, Texas
    Welding Tin Cans...
    Hi...
    I'm one of those old guys that believes that practice is the best way to learn something; so I've been practicing on Tin Cans in the hope that I can learn how to weld sheet metal at some point down the road. (Don't have any scrap sheet metal to practice on just now.)
    I took a bunch of cans, and tack-welded them end to end using 3/32" 6013 rods at 30/40 AMPS with my Lincoln 225/125 AC/DC welder.
    The cans held together well when I took the entire column and beat it against my Railroad Baseplate Work Bench; so I guess I did something right; but I'd like to know if any experts/old timers out there have any advice on a better rod, etc.
    I did have several spots where the arc burnt through the cans; but for the most part, the job came out pretty well had I wanted to make myself a smoke stack.
    Thank You !
    Ed VA
    Feb 2008
    NH no mo - MA now.
    Re: Welding Tin Cans...
    When you say "tin cans" I presume you are referring to food cans - canned vegetables, soup, dog food, etc. We all call 'em "tin cans" because a century ago or more they were made from tin. Today most are steel except for aluminum beverage cans. Most are plastic coated inside and out except for those in which the contents are especially acidic like sliced or diced pinapple. Those cans are galvanized inside. In either case you will get best results if you clean the coatings off the inside and outside of the metal before welding.
    With the thin metal you will also get best results to use GMAW or preferred GTAW processes.
    Can you post some photos?
    -Mondo
    Member, AWS
    Lincoln ProMIG 140
    Lincoln AC Tombstone
    Craftsman Lathe 12 x 24 c1935
    Atlas MFC Horizontal Mill
    I'll just keep on keepin' on.
    Nov 2008
    Seguin, Texas
    Hi Mondo; and Thanks for your quick reply.
    I can't post any pix due to my camera having been... "Lost" by my grandaughter. Sorry !
    I didn't clean anything off these cans; but there was a pretty good mix of all types. All I have to work with is my Lincoln, and a small Clarke 95E Crackerbox welder that isn't much good except for lighting the coal in my forge.
    What is GMAW and GTAW by the way ???
    Thanks !
    Ed VA
    Jan 2009
    Atlanta, GA
    Quote Originally Posted by edv7028 View Post
    I'm sure this has been discussed over 1000 times here, but here goes:
    GMAW= Gas Metal Arc Welding
    GTAW= Gas Tungsten Arc Welding
    or on other words
    GMAW=MIG (metal inert gas) welding; I feel should be called MAG (Metal Active Gas) since most of time you use CO2 in a mix with argon when MIG welding.
    GTAW= TIG (tungsten inert gas) welding
    Aug 2008
    Dansville NY
    A smoke stack??!! What is it going to be used on?
    As already said a MIG unit would be best for welding those together. You'll find that the cans you described make a lousy smoke stack. Sure it will work for awhile but you'll find that they will rust out within a year especially at the weld points.
    If your looking for some good metal to practice your stick welding on drive around on trash day and see if anyone is throwing our some steel bed frames. Its great steel to practice your stick on. You'll also find that the steel also makes good framework for work/welding carts.
    Nov 2008
    Seguin, Texas
    Hi Specter... (Gunships from Vietnam days ???)
    Anyway, I done rebar, T-Posts, and Railroad Baseplates because they're free/cheap; but wanted to practice on something thin and light, therefore the tin cans.
    I've made a Tractor Beer/Tool Carrier, Back Porch Frame, Forge Stand, and Tool Box stand all out of Rebar, and T-Posts. I've also made my Work Bench out of Railroad Baseplates.
    Thanks for all the advice you guys have given me; but I still need to get more practice on something thin & light.
    The smokestack will be used on a Barrel Heater/Stove for use under my work awning in the winter; and possibly over the forge. It's okay if it has to be replaced every few months or so because the cans are always in the trash here.
    Thanks !
    Ed VA
    Aug 2008
    If you haven't already, give it a go DCEN with the DC side of the machine. It seems to have less of a tendancy to burn thru.
    AND GO LIKE HELL. LIKE SOMEONE WAS COMIN' AFTER YOU WITH A GUN
    And maybe a pretty wide wash bead to keep the heat away from the thin edges
    Now ya got me thinkin' I might dig some dog food cans out of the trash
    I have a feeling I'll wind up makin' em look like swiss cheese
    http://www.farmersamm.com/
    Nov 2008
    Seguin, Texas
    Hi FarmerSamm...
    It's not really fun, because it takes a really light touch to keep from burning through the tin; but practice makes perfect, so I've got a LONG Way to go ! Have fun !
    Oh yeah... I was using DC+ on this practice run; and it worked pretty well.
    Regards, & Happy New Year !
    Ed VA
    Aug 2008
    Hey ED, I got the cans Found some old 5/64 6013 to try with. I'm gonna let it warm up a little more outside first.
    SWISS CHEESE BY AFTERNOON
    Aug 2008
    forgot the pics
    Aug 2008
    ED, YOU'RE AN ANIMAL How do you do it??
    I never had such a disappointing experience in my life. There ain't enough of my can to take a picture of
    The only thing that worked was a fast drag at 30amps DCEN, but if you missed starting the arc it was all over. Either side of the lid ring and it was all over.
    I need more cans. I need more cans
    Edit... And screw that wash crap, you have to stay on the lid ring
    Dec 2008
    Battle Ground, WA
    FarmerSam,
    What did you spill on that Keyboard?? I am amazed it still works! By the way I think we got the same table! (I would give you some more Dog food cans but my stupid little rat dogs won't eat anything but fast food from the fridge!!! My newest one now thinks he owns the shop too! came out, jumped on the welding table and peed on my scrap aluminum (what is a guy to do)
    Tim
    A rich man is not the one who has the most but instead one who needs the
    least
    Retired IUEC local 19
    AK Bush pilot,
    Chaplain CMA Chapt 26
    victor torches
    Miller110v mig
    Dynasty 200dx (new in Dec 08)
    Hypertherm PM-45
    MM-252 (new 2/09)
    Nov 2008
    Seguin, Texas
    Hi FarmerSamm...
    ME ??? An animal ??? I wouldn't even THINK about eating Canned Tamales ! He-he Even when I was in Vietnam, I only ate a minimum of those I cooked for Christmas Dinner in an old Ritz Can.
    As I mentioned... I only "Tack Welded" my cans in about 6 to 8 spots around the perimeter, and it wasn't easy in the beginning. I did manage to hold an arc for about 3 to 5 seconds though without burning through the rims. I had those Hobart 3/32" 6013's and set my Lincoln 225/125 AC/DC on 30 to 40 Amps... Lowest Possible Range. Maybe it's the machine !
    Even when i tried my old Clarke 95E down around 20 to 30 Amps, it would stick most of the time, or burn a hole through anything I touched with the rods.
    Hey... I'm retired ! I have all the time in the world to mess around with these silly little projects of mine so long as the weather permits; and the family isn't asking me to BBQ or take them somewhere.
    Keep at it Farmer. If nothing else, it just provides an outlet for any cussing you might feel like letting out ! He-he
    Regards,
    Ed VA
    P.S.
    That IS a "Used" looking keyboard you have there Farmer. I'm guessing that you do your welding right in front of it ! He-he
    Western PA
    edv7028, see if you can find some 1/16" 6013, and give it a shot on DCEN
    Aug 2008
    I'm gonna do this if it kills me
    Nov 2008
    Seguin, Texas
    Hey Farmer...
    Remember your sign-off phrase.... Any day above ground is a good day ! Don't over stress yourself ! He-he
    Ed VA
    Mar 2008
    Colorado
    Quote Originally Posted by Ultrachop View Post
    Tim
    Dog soup.
    9-11-2001......We Will Never Forget
    Retired desk jockey.
    Hobby weldor with a little training.
    Craftsman O/A---Flat, Vert, Ovhd, Horz.
    Miller Syncrowave 250
    Northern Cal., Shasta County
    Pedigree and Tamales, that had to be one he11 of a supper. Kinda like chili??
    Aug 2008
    It's up to y'all to figure who ate which
    Quote Originally Posted by farmersamm View Post
    Prolly the same stuff, different wrapper!!!
    Aug 2008
    That nose knows the good stuff
    He ate the dog food
    Jun 2008
    Central California
    Isn't that what HF is for? You let him get used to doing it on something in the shop that you don't care about, but yell at him for it every time anyway, then one day hook the stinger to it, have the HF turned on, stand by the foot control, and just wait for him.......
    Dec 2008
    Battle Ground, WA
    As long as he doesn't crap on my ground lead and pee on my Harley tire, I will keep him around! Friends still are amazed that I like this little fur ball?
    Back to welding, I think I will weld up a dog dish holder that won't tip over? Better yet if I just weld all the cans together in a circle they won't tip, right farmersamm?
    least
    AK Bush pilot,
    victor torches
    Miller110v mig
    Hypertherm PM-45
    MM-252 (new 2/09)
    Nov 2008
    Seguin, Texas
    Hi UltraChop...
    Gee Man, I remember when every movie with a Harley in it had the owner with some kind of snake wrapped around his neck, and the guy or girl was a vicious, killer or everything that walked or moved on earth. With that little white poock on your bike, I've lost my childhood illusions ! He-he Nice looking little tamale filling though !
    You should have at least put in a couple of "Grr's" here and there in your post ! He-he
    Regards,
    Ed VA
    Dec 2008
    Battle Ground, WA
    Ed,
    You must be thinking of the girls I hung out with before I got married to the sweetie I have been with for the last 31 years? She wanted me to get another German Shepard----GRRRRRRRRRR
    Tim
    least
    AK Bush pilot,
    victor torches
    Miller110v mig
    Hypertherm PM-45
    MM-252 (new 2/09)
