Questions about welding 1/4" SS with Mig
Results 1 to 9 of 9
    Oct 2012
    Austin, Texas
    I've had a request for stools I make to be built with stainless steel bar instead of cold rolled steel for use outdoors. I have never welded stainless and have a Millermatic 175. Material will be 1-1/2" x 1/4" stainless bar stock.
    I know I need to use 308wire and tri-mix gas. The gas is expensive!
    Any changes I would need to make on my welder settings?
    Any other tips or suggestions? I'd like to have the option of welding stainless but I'm not in a position to buy and learn how to TIG at the moment.
    Sep 2005
    Cave Creek AZ
    Re: Questions about welding 1/4" SS with Mig
    Spend the money and get the gas and the wire, but try a test piece before you commit to the job. The flat bar will warp a lot, so make sure you can correct it, and give it the right finish first. Also, you may have trouble cuting the SS with the tools you have, so be prepared for some other new equipment. 304 that I buy is enerally pretty tough to work. The 316L I used on a project was a bit easier to work.
    Oct 2012
    Austin, Texas
    The material will be 304. I have an evolution raptor cold saw, hadn't thought about cutting it. I also have to drill holes with a step bit. Of course I will do some testing first...thanks for the tips.
    Feb 2011
    North Georgia Mountains
    Be sure to use the SS blade on that saw, NOT the mild steel blade.
    Oct 2012
    Austin, Texas
    Thanks, hadn't thought about that either.
    Oct 2007
    Vandalia, Ohio near Dayton
    Keep your stainless stock away from mild steel, grinding dust, anything that will contaminate the surface. I'd even suggest buying a stainless brush and grinding wheels just for this project. Cover your workbench with a sheet of aluminum or even plywood, if that's all you've got, to keep the stainless from picking up mild steel that will start rusting.
    Stainless has half the thermal conductivity of mild steel, so it will hold onto welding heat longer and warp more. You may need more clamps, fixturing, etc to keep everything true. Or you may have to come up with a good way to straighten out anything that moves. depends on where and how you're welding...
    think about beveling your weld joints so that MIG wire has someplace to go. 1/2" material will give you some room to bevel without worrying about burning through. Beveling and the right settings will give you welds that need less cleanup. There's a balance between the right machine settings for half inch material, the size of the bevel, and the amount of distortion you'll get. might take some experiments to dial it in just right; if it's worth the effort.
    A coating of clear paint, once your stools are all finished, will go a long way towards keeping the stainless bright and corrosion free. Remember, stainless is just corrosion resistant, not corrosion proof. Bird droppings, and other environmental contaminants can still start the corrosion process, even on stainless steel.
    Oct 2012
    Austin, Texas
    Thanks for the info, welding 1/4" and not 1/2". I'll have to experiment with clamping in my jigs. I already have a bench that is MDF and not steel as I work in mostly bare steel and the steel welding top scratches my work too much.
    Oct 2012
    Austin, Texas
    One more question about this set up. Any issues with the welder or gun liner when I switch gases or wire out? I will mostly be welding mild steel, but swaping out to stainless every once in awhile.
    Feb 2011
    Martinez CA
    Gas won't require any changes other than the material selection, but the liner is selected by wire size and may need to be changed
    Miller Dynasty 350
    Twenty Six Hammers
    Three Crow Bars
    Big Rock
