2G Pipe?
Results 1 to 25 of 32
Thread: 2G Pipe?
    Jan 2006
    In A Nice Comfy Chair
    2G Pipe?
    Was looking at a post somewhere around here about a member that's having a bit of trouble doing a 2G pipe weld..
    Now I have never had to do this at any time as a test but have run into this situation at times so I did a little research and came up with the notion that it has to be done with the pipe "up"..
    Not sideways like laying it on a bench..
    I was tempted to use the positioner but that's cheating I guess so I just did it on the bench the way it is..
    They mention a 3/32" gap and a bevel..
    I took my subjects to the small lathe and dressed up the ends and had a go at it..
    The pipe was 2 1/4" with a 3/16" wall..
    Pics below..
    One more post..
    ...zap!
    I am not completely insane..
    Some parts are missing
    Do not attempt.
    Jan 2006
    Re: 2G Pipe?
    Amps..Anywhere between 80-150...
    Filler..040 70S-2
    So give it to me straight..
    ...zap!
    Do not attempt.
    Jul 2011
    Re: 2G Pipe?
    I don't know S about pipe, but you really must be bored today. I thought you got all the fun jobs?
    There are no problems. There are only solutions. It's your duty to determine the right one.
    Hobart Handler 210
    Airco 225 Amp MSM Stinger
    Oct 2011
    Northeast, PA
    Re: 2G Pipe?
    Looks like you got some suck back on the root. The pic above the one with a dime on it..
    I would've ran stringers after the hot pass, but that's me..
    Feb 2010
    Ocean Springs, MS
    Re: 2G Pipe?
    The root didn't fuse into the wall of the pipe in a lot of places, try a bigger gap one where your filler will slide through the gap easily. Make the inside of the pipe where the root will tie in shiny like inside the bevel. Other than that it looks good
    Jul 2011
    North,Ga
    Re: 2G Pipe?
    From my research, it's either no land to 1/32-1/16 at the most except for big diameter,heavy wall pipe. The gap is really the welders preference unless stated otherwise. Usually no amp control. Some guys like to feed wire through the gap and the watch the puddle and the root form from the inside,they don't really watch the arc,using a large gap like 3/16 ... This way they know for sure that the root has enough buildup inside. I would try it again with no land or very little and push more filler in while letting the heat of the puddle not the arc melt the filler using an 1/8" gap,grind out your tacks as you go as well....
    Lincoln pro mig 180
    Lincoln Square Wave Tig 300/wp 20/home built water cooler
    Victor, Purox, Harris, O/A welding/cutting setups
    Vintage Craftsman drill press
    Vintage Craftsman/Atlas 12"x 36'' lathe
    7''x 12'' w/c band saw
    Everlast 140 st
    Oct 2011
    Jacksonville Florida
    Re: 2G Pipe?
    Quote Originally Posted by justinT View Post
    What he said. You didn't get enough reinforcement in the inside either. And I KNOW that you know that the steel needs to be clean before tig welding
    Airco Ac/Dc 300 Heliwelder
    MillerMatic 200
    Miller Maxstar 150STL
    Jan 2010
    steamfitters lu 322 so. nj
    Re: 2G Pipe?
    where to start? need longer coupon's, 6'' long min. clean rust and millscale from inside and outside,2g caps are stringers not puddle cap, need to slow down travel speed on root! lay wire in joint and walk over wire lightly pushing wire into molten pool( surface tension) good luck!
    Jan 2006
    Re: 2G Pipe?
    Quote Originally Posted by SquirmyPug View Post
    The outside is as clean as it gets..A lathe will do that for ya.
    The inside?
    I just played the game like everyone else.
    This was not a test..Just screwing around.
    ...zap!
    Do not attempt.
    Oct 2011
    Re: 2G Pipe?
    The inside?
    ...zap!
    The lathe will clean the bevel, but you need it clean about 1/4" past that. I usually clean 1/2" past the bevel. The inside needs to be cleaned also, leaving millscale and rust inside it makes it hard to get proper fusion and reinforcement.
    I know you can weld, open root is just allot different to weld than what you usually do.
    MillerMatic 200
    Sep 2006
    NJ, USA
    Re: 2G Pipe?
    2G, check.
    But ???
    It's not "pipe".
    2" pipe is 2-3/8 "OD, not 2-1/4". Wall thickness on Sch 40 2" pipe would be 0.154", and Sch 80 would be 0.218". 3/16" is 0.1875".
    Next, here's the critical evaluation, done to pipe welding codes/standards/guides.
    Fail.
    Failure to clean 'pipe' minimum 1" back from the joint, inside and out.
    Failure to use the minimum required number of tack (four minimum per AWS D10.11, three or four minimum per AWS D10.12 if using pipe clamps to hold pipe in position).
    Failure to get adequate root penetration. I think that's the 'biggest' problem here.
    Filler used was too small, per Code/guide (D10.12 says 3/32 filler for pipe, AWS B2.1-1 standard WPS for GTAW 3/16 - 7/8 thick says 1/16 or 3/32 or 1/8 filler).
    Cap pass looks like it might be a little under-filled (camera angle or lens distortion?).
    Hey, it ain't easy to do pipe. Open root, small diameter, relatively thick-walled pipe at that.
    Jan 2006
    Re: 2G Pipe?
    A little more R+D and I'll be OK...
    ...zap!
    Do not attempt.
    Jul 2011
    North,Ga
    Re: 2G Pipe?
    How about some heavy wall 1 7/8" tube... 6g
    Lincoln pro mig 180
    Everlast 140 st
    Jan 2008
    Re: 2G Pipe?
    gap?we don need no stinkin gap...
    Oct 2010
    The Netherlands
    Re: 2G Pipe?
    what others said and use longer coupons ...3'' each
    and when you get bored try it without a foot pedal and in 5G
    www.becmotors.nl
    yup, I quit welding.. joined welder anonymous
    Sep 2012
    WV
    Re: 2G Pipe?
    Just a little tip. Feed more wire. you want to be flush or above on the inside with all the walls broke down. dont be afraid to feed the wire. On a 2g dont try to cap it with one pass unless it is very thin pipe. catch the bottom bevel with the first cap pass and stack the till you grab the top bevel with no under cut. good luck
    Feb 2008
    North of Philly
    Re: 2G Pipe?
    Quote Originally Posted by MoonRise View Post
    2G, check.
    But ???
    It's not "pipe".
    Fail.
    Hey, cut the "new guy" some slack....
    NOT!
    Ronald Reagan
    Dec 2012
    Denison TX
    Re: 2G Pipe?
    Start with larger pipe. Its easier...or so I hear from all the advanced tig students at school.
    Dec 2003
    Fairfield,CT
    Re: 2G Pipe?
    I still bet that Bi*ch don't leak. LOL.
    www.tjsperformance.com
    Dynasty 300 DX
    HTP 240
    Miller Bobcat 225G
    LN-25
    Bpt. Mill/DRO
    4' x 8' CNC Plasma Table
    Instagram: tjsperformance
    Jun 2011
    Princeton, NJ
    Re: 2G Pipe?
    I think the others have covered it fairly well, but the main problems here are the suck-back on your root and the use of a weave for a horizontal weld. .040" filler is way too small for that weld. Try 3/32", push it into the puddle pretty aggressively on the root pass and again on the 2nd (hot pass) to prevent the suck-back. A horizontal weave is not acceptable in any code I've seen, so try switching to stringers all the way out. The other part mentioned is to feather your tacks out with a grinder as you work your way around on the root and ensure that they are fully fused into the root pass. When you're done it will look almost like you ran a pass from the inside. ASME doesn't specify a minimum number of tacks.
    Hellinois
    Re: 2G Pipe?
    Enough comedy. Now for an important question........
    Correct me if I'm wrong, but I always thought it was a 1966 dime???
    "Stick-man"
    Jan 2006
    Re: 2G Pipe?
    I have a '66 and a '69...
    All depends on what dime comes out of it's SPECIAL holder first....
    ...zap!
    Do not attempt.
    Nov 2008
    Re: 2G Pipe?
    do alot of heavy wall tig/stick work in the plant. I personally like 1/16" landing on any piping with a wall 1/2" or smaller, 3/4" and up wall thickness i find a knife edge to work best as shes such a big heat sink even with the blankets on her keeping interpass temps. Although i must say ive never had the luxury of using a pedal during any of my pipe work in the plant or in the shop for that matter. Over the years you just learn to use your filler, base material, and travel speed to control the head input. Rather than dipping quickly which it kinda looks like you were doing, what i teach my apprentices when there first starting out is to " start on the tack and heat it up, weave up to the top bevel and just catch the landing point the tungsten at the filler and add 1/2" or so of rod, weave back down to bottom bevel and quickly back up and repeat. When you get more control over this method you can start concentrating more on staying in the middle of the root opening to gain speed, but you always are able to climb a little higher on that bevel to lose some heat if you need
    Jan 2006
    Re: 2G Pipe?
    I appreciate all the input/suggestions but remember I was just screwing around when I did this..
    Next time.......(Whenever that will be)......I'll make ya proud of me.
    ...zap!
    Do not attempt.
    Oct 2010
    Bethel, CT
    Re: 2G Pipe?
    I'm more concerned with the fact that in the last picture you are using a tape measure that reads fractions.
    Didn't you give the young mister Stukus a hard time for not reading a caliper correctly?
    kidtigger24
    They think I’m crazy, but I know better. It is not I who am crazy. It is I who am MAD!
