Foot Pedal
Results 1 to 6 of 6
Thread: Foot Pedal
    May 2009
    MD.
    Foot Pedal
    Well the time has come that i need a new foot pedal .
    The machine is a older yellow body mosfet machine ac/dc 250 amp with around a .500" 7
    pin conector with amperage adjustment on the pedal.
    What foot pedal can i get for this ?
    Do they make a smaller pedal for this machine ?
    The welder has been flawless except for the foot pedal and i would appreciate any help
    with this . Thanks, Jake
    Nov 2008
    Re: Foot Pedal
    You'd need to determine the ohms on the pedal. Do you have an ohm meter?
    Can you post a pic of your unit so we can verify which style it is?
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    Smith Oxy Fuel setup
    Everlast PowerPlasma 80
    Everlast Power iMIG 160
    Everlast Power iMIG 205
    Everlast Power iMIG 140E
    Everlast PowerARC 300
    Everlast PowerARC 140ST
    Everlast PowerTIG 255EXT
    May 2009
    MD.
    Re: Foot Pedal
    Yea lug i can get pic of the welder.
    Is there any markings on the pots that say what ohms they are ?
    Nov 2008
    Re: Foot Pedal
    On some models there were.
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    May 2009
    MD.
    Re: Foot Pedal
    Hopefully this works
    http://i1083.photobucket.com/albums/...g/DSCN1836.jpg
    http://i1083.photobucket.com/albums/...g/DSCN1834.jpg
    If i need to ohm the pedal i can i would need to know what pins to use though . I am pretty elecrically challenged but can use a multi meter
    May 2009
    MD.
    Re: Foot Pedal
    Numbers off the pot for the pedal are WTH118-1A also has 2W 2K2 on same pot
    Numbers on the amp control pot are WH30P B10K-20/3 and says hungyun.com
    Numbers on the micro switch are KW-7 15a 250v ac
    Is there a way to buy these things from you guys or ?
    I also need a plug that goes onto the machine so i can wire it .
    I've decided to build my own pedal but i need these parts.
