Wiring Jasic 220v line to three prong dryer plug.
Results 1 to 23 of 23
    Nov 2011
    It has the European wiring with the blue, brown and yellow/green wire. I am not able to run a separate line so can I use a three prong dryer plug with no ground? The dryer uses two hots and a neutral with no ground but the welder has a hot, neutral and earth. Am I screwed or can we figure this out? I live in a rental so upgrades are not available.
    CERTIFICATIONS:
    7018M- H.V.O
    10718M- H.V.O
    11018M- H.V.O
    9N10- H.V.O
    71T-1-HYM- H.O.V
    100S1 PULSE ARC 0,035- H.O.V
    100S1 PULSE ARC 0.045- H.O.V
    ER70S-3 PULSE ARC 0.035 H.O.V
    ER70S-3 PULSE ARC 0.045 H.O.V
    ER5554- H.O.V
    Los Angeles
    Re: Wiring Jasic 220v line to three prong dryer plug.
    Blue and brown as your 2 hot legs
    Yellow/green as your ground*
    In the dryer receptacle/ plug it will be the neutral terminal*
    MM211 (Sold)
    Miller 125c Plasma 120v
    Nov 2011
    I am just a little hesitant because instead of having a hot, neutral and ground you would have hot, hot and neutral.
    CERTIFICATIONS:
    7018M- H.V.O
    10718M- H.V.O
    11018M- H.V.O
    9N10- H.V.O
    71T-1-HYM- H.O.V
    ER5554- H.O.V
    Nov 2008
    Broc is right. You are supposed to have two hots and one ground for your welder. The neutral is only really neutral if you have part of the dryer with a 110 v circuit, otherwise it is probably a true ground.
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    Smith Oxy Fuel setup
    Everlast PowerPlasma 80
    Everlast Power iMIG 160
    Everlast Power iMIG 205
    Everlast Power iMIG 140E
    Everlast PowerARC 300
    Everlast PowerARC 140ST
    Everlast PowerTIG 255EXT
    Dec 2011
    Tampa FL
    European wiring blue = neutral, Brown = hot(230v). 3 prong dryer receptacle two hot(110v each) one ground no neutral. I think you would need a transformer to boost the voltage. Also most European equipment is made for 50 hertz and American power is 60 hertz.
    Nov 2011
    The welder will work in 50/60Hz so that isn't an issue. Just to make sure we are all on the same page, 220v European power only has one hot. The same style as american 115 but double the voltage. Where as US 230v is two 115v and a neutral with a ground.
    CERTIFICATIONS:
    7018M- H.V.O
    10718M- H.V.O
    11018M- H.V.O
    9N10- H.V.O
    71T-1-HYM- H.O.V
    ER5554- H.O.V
    Nov 2011
    In other words, it is different than a miller or Lincoln 230v.
    CERTIFICATIONS:
    7018M- H.V.O
    10718M- H.V.O
    11018M- H.V.O
    9N10- H.V.O
    71T-1-HYM- H.O.V
    ER5554- H.O.V
    Dec 2011
    Tampa FL
    That is why you need a buck/boost transformer to get 230v on a single line.
    Nov 2011
    Yea I was afraid of that. Those pigs cost more than the welder.
    CERTIFICATIONS:
    7018M- H.V.O
    10718M- H.V.O
    11018M- H.V.O
    9N10- H.V.O
    71T-1-HYM- H.O.V
    ER5554- H.O.V
    Jan 2008
    Richmond, Virginia
    If the dryer circuit has only one outlet and goes straight back to a panel where the neutral and ground are bonded, then neutral is the same as ground for the purpose at hand. It's just used for a different purpose with a 120/240V circuit vs a 240V-only circuit.
    Syncrowave 250 w/ Coolmate 3
    Dialarc 250, Idealarc 250
    SP-175 +
    Lincwelder AC180C (1952)
    Victor & Smith O/A torches
    Miller spot welder
    Delaware
    You don't need anything but a PLUG. BLUE HOT, BROWN HOT AND GREEN/YELLOW GROUND there is no NEUTRAL
    HF 95136 Plasma Cutter
    2015 AHP 200X
    Tec.Mo. Wholesale Distributor and Dealer
    Consumables for the PT and IPT torch's.
    Jan 2008
    Richmond, Virginia
    Quote Originally Posted by NHMatt View Post
    ... 220v European power only has one hot....
    Hot just means it's significantly above ground potential. Since we ground in the middle, we have two "half-hots" that are 120V above or below ground. If you ground one side of a 240V transformer, you only have one "hot" that is twice the voltage. Doesn't really matter since it is AC anyway. Electrons don't read code books or pay attention to wiring conventions.
    SP-175 +
    Miller spot welder
    Nov 2011
    Sounds good to me. I'll let you know how it welds.
    CERTIFICATIONS:
    7018M- H.V.O
    10718M- H.V.O
    11018M- H.V.O
    9N10- H.V.O
    71T-1-HYM- H.O.V
    ER5554- H.O.V
    Nov 2011
    Thanks for the help guys. It works beautifully and welds pretty good. It maxes out at 120 and all I had was 1/8" 7018 but cranked all the way it was running hot so I bumped it down to 110 and it was fine. I had 6010 1/8" also that welded fine on about 80 amps. I still need a argon bottle to try the tig and tomorrow I will try the plasma setting. Not bad for $135 bucks at a pawn shop.
    CERTIFICATIONS:
    7018M- H.V.O
    10718M- H.V.O
    11018M- H.V.O
    9N10- H.V.O
    71T-1-HYM- H.O.V
    ER5554- H.O.V
    I have the same dilema. So to be clear, did you connect your blue and brown to the two hot leads of the dryer plug? That should give 220V, then which wire did you connect to the green/yellow ground from the welder? The white nuetral or the bare ground wire?
    Jun 2008
    You cannot create a neutral w/ buck/boost transformers & the machine will not care if it's 240V line to line, or line to neutral.
    Apr 2014
    Greensboro, North Carolina, United States
    The neutral and ground go to the same place. Get a continuity tester and probe neutral bus to ground bus. You will find that there is continuity. The only time this might give you trouble is with a gfci breaker/ recepticle. I know I'm too late and you already figured it out but had to throw in my two cents. I am an American after all
    Thermal arc 211i
    Ck flex-loc 150 & 130
    Clamps, saws & grinders
    Harbor freight 80 amp inverter
    west texas
    In old code 3 prong dryer plug wiring your neutral/ground is the bare wire.
    Green or green+yellow is always non current carrying earth ground as far as I can tell. Some times yellow can be ground or neutral (on some generators).
    I wired in my 220v german microwave, here in the U.S.. Same idea, just smaller wire. Just hooked a blue and brown to the lines and the green/yellow to the bare conductor, via the NEMA 6-15 plug I put on the microwave and 6-15r I put on the wall.
    old Miller spectrum 625
    Lincoln SP-135 T, CO2+0.025 wire
    Craftsman 230amp AC/DC and WP-18V torch
    Craftsman 100amp AC/DC and WP-17V torch
    Century 115-004 HF arc stabilizer
    Home made 4 transformer spot welder
    Home made alternator welder
    Los Angeles
    Quote Originally Posted by skid4u View Post
    We need to know exactly which type of receptacle you have: 3-prong or 4-prong?
    3-prong 120v/240v receptacles used for dryers are strange little beasts because the way they use the Neutral and Ground together. There shouldn't be any bare wire in these receptacles. Since the 3rd wire will carry current it can not be a bare wire and that particular neutral wire goes directly to the main panel.
    4- prong 120v/240v receptacles may have a bare wire for ground because they have a separate wire for neutral.
    MM211 (Sold)
    Jun 2008
    3-wire dryer receptacles are non-grounding dual voltage devices, it was allowed prior to the 1996 NEC to ground the frame of dryers to the neutral.
    Los Angeles
    Quote Originally Posted by Norcal01 View Post
    yes- but there shouldn't be a bare wire used, correct?
    MM211 (Sold)
    Jun 2008
    No, unless SE cable was used & it was run from the service equipment, if it was not run from the service equipment & has a bare conductor it was never compliant w/ NEC requirements. & 2-conductors w/ ground NM cable was never compliant it is always wrong & it does not matter if it was a service panel or sub panel, it's still a sign of bad workmanship.
    west texas
    Wow that's sad. I think every house I have ever lived in with a dryer hook up all had 2 conductor NM going to them. Even base housing made way after 1996.
