304 Stainless signs.....rusting! - Page 2
Results 26 to 50 of 63
    Apr 2013
    Re: 304 Stainless signs.....rusting!
    The shot blasting is the most likely cause of this. Its effect is just the opposite of highly polishing, which is what is done to yacht hardware for best appearance.
    Also some imported grades of 300 series stainless exhibit much more problems with rusting.
    Electropolishing might be an affordable fix.
    Dec 2011
    Tampa FL
    304 stainless often turns brown like your signs from materials in the vicinity of it. I think i would clean them and then have them chromed. Just my 2 cents
    Feb 2012
    Sparks, NV
    Just my two cents worth; Ive noticed a difference in GERMAN stainless vs India, Pakistan and China stainless. Also, German stainless is non magnetic at least in my xperiance whereas, the others are magnetic.
    Grand Rapids, Michigan
    That typically depends on the grade of stainless. Ex: 400 series vs. 300 series.
    Craig Montgomery
    M&L Fabrication, LLC
    https://www.facebook.com/pages/ML-Fa...8228829?ref=hl
  5. #30
    Feb 2012
    Sparks, NV
    Quote Originally Posted by montgoc3 View Post
    I think you just answered Mr Colts question.
  6. #31
    Apr 2013
    Even 316 is much more corrosion resistant than 304
  7. #32
    Jan 2011
    Australia
    Jim....I just finished some 304 signs myself and, although the customer wanted a brushed finish, I went with an electro-polished satin which, hopefully will prevent tea staining.
    I think you guys need to rethink the finish or, powder coat for the desired effect.
    CIG 320SP pulse mig
    Mitech ACDC315P
    Samson 510 CNC plasma table
    Hypertherm 85
    Etc, etc.
  8. #33
    Sep 2010
    southwest VA
    Blast, blow off, acetone rinse, and clear powder coat. A super-durable clear would probably be good since they're outdoors in all kinds of weather:
    http://powder365.com/store/index.php...roducts_id=179
  9. #34
    Nov 2014
    You have posted the same thing in like 5 different threads. I think most of us get it. And this thread is old
  10. #35
    Jul 2013
    Well, since someone revived the dead thread...
    How did Hypertherm fix the signs?
  11. #36
    Should have cut it with water insted. The heat from the plasma depletet the plats of chrome. This is the reson why we use higher grade fillers when welding stainless.
  12. #37
    Oct 2007
    New Hampshire
    If that was the case only the plasma cut edges would have rusted. The signs were reblasted in a shop that only handles stainless. It has been a couple years and they all still look great. No clearcoat.
    Cutting with an abrasive waterjet would have made signs with a tighter tolerance, not at all necessary. They still would have needed shot blasting for the desired finish.
    Jim Colt Hypertherm
    Quote Originally Posted by Northern Sweden Weld View Post
  13. #38
    city of Four Flags
    Huh?, the post before yours is from 2013.
  14. #39
    East Tennessee
    Quote Originally Posted by vwguy3 View Post
    I think the said poster got the boot for trying to push his product.
  15. #40
    Jul 2013
    Jim Colt Hypertherm
    Thanks for the update. I always like learning solutions to problems that have worked for other people.
  16. #41
    city of Four Flags
    Quote Originally Posted by Showdog75 View Post
    Well that makes sense.
  17. #42
    Oct 2007
    New Hampshire
    I don't think so....I am the original poster on this thread. Was looking for advice....which I got a couple years ago when it was first posted! Not sure where you see a product being promoted?
    Jim Colt
  18. #43
    Dec 2009
    Stevens Point, WI
    A rough surface will hold debris. If the signs are outside it is possible that it collected enough junk from rain to rust. With pretty much any metal the smoother the surface the more resistant to "stuff" it is. This is especially true with stainless, if the sign was polished it would resist rust much better.
  19. #44
    Feb 2014
    Iowa
    Jim Colt
    There was a poster posting the same stainless finishing equipment in all kinds of threads. They posted here as well, thus the old thread revival. It appears the administrators removed him and his posts, leaving voids in the conversation.
    Miller Dynasty 350
    Miller CP300
    Miller CP200
    Lincoln Idealarc 250/250
    Smith torch
    Lagun FTV-2
    Kent 13x40 TRL lathe
    Bunch of other metal cutting tools
  20. #45
    Mar 2009
    Jim, Showdog was referring to "the said poster" that VW was referring to.
    Some d-bag scammer posted the same thing on several old threads. The mods removed him and deleted his posts. And now here we are stirring up 3 year old stainless steel dust! And the damn sign will probably start rusting again!! Thanks a lot you scammer guy who got deleted and left us with this to deal with to start off 2017!!!!!!!
    We all know you're legit Jim Colt.
  21. #46
    Mar 2009
    Quote Originally Posted by Teggy1 View Post
    Well thank you Teggy1 for beating me to the punch by 9 minutes and ruining everything I thought so hard on to try to put into words!!!!!!!!!!!!
    2017 is just not going to be my year from the looks of it. First the scammer guy confusing every body. And now Teggy1 ruining my post by posting the exact same thing I was going to say!!!!
    [edit: I'm really not mad at Teggy1. This whole post was in jest. No one take anything seriously. No hard feelings. Except for the scammer guy. And rust.]
  22. #47
    Feb 2014
    Iowa
    Quote Originally Posted by Pipeliner View Post
    No worries man!
    I'll try not to do it again.
    Miller Dynasty 350
    Miller CP300
    Miller CP200
    Smith torch
    Lagun FTV-2
  23. #48
    Nov 2014
    That guy push his luck too far. Must be a rookie
  24. #49
    Apr 2016
    Thessaloniki Greece
    What is Stainless Steel in few words. (rust problems)
    Stainless steel is an alloy of iron which contains at least 10% chromium (Cr).
    This addition of chromium defines the unique properties [stainless, corrosion and heat resisting].
    The chromium content of the steel allows the formation of an invisible, corrosion-resisting chromium oxide film on the steel surface.
    If damaged mechanically or chemically, this film is self-healing, providing that oxygen, even in very small amounts, is present.
    A common form of rusting stainless steel is after the stainless steel has been exposed to very high temperatures (400-850°C) or (750-1550°F).
    If this happens, sensitization can occur which is where the carbon and the chromium bond together in the stainless steel and form carbides.
    These carbides situate themselves at the stainless steel grain boundaries, and the grain boundaries become deficient of chromium.
    With lower chromium concentrations at the grain boundaries, the chromium oxide protective film can become discontinuous and start rusting.
    The best solution is to polishing the overheated and the nearby areas using suitable abrasive brushes and polishing pastes.
    This process is able heal the points of chromium oxide film that they has damaged.
    At reality we do a very thin and smooth grinding/cleaning of the carbon carbides (that has come out at the surface from overheating).
    So, removing the tiny steel particles we help the chromium oxide film to be able again, to self-healing the stainless steel.
    Chemical Composition
    Stainless Steel AISI 304
    Carbon 0.08% max.
    Manganese 2.00% max.
    Phosphorus 0.045% max.
    Sulfur 0.030% max.
    Silicon 1.00% max.
    Chromium 18.00-20.00%
    Nickel 8.00-10.50%
    Stainless Steel AISI 316
    Carbon 0.08% max.
    Sulfur 0.030% max.
    Silicon 1.00% max.
    Chromium 16.00-18.00%
    Nickel 10.00-14.00%
    Molybdenum 2.00-3.00%
    Happy New Year
    Bill
  25. #50
    East Tennessee
    And?...
