Mobile Home Axle Conversion
Results 1 to 19 of 19
    Apr 2013
    Roxboro, NC
    Anyone ever converted MH axle hubs to a standard hub? I have 3 axles for future trailer build but I beleived they outlawed using these several years ago.
    S.E.Wisc.
    Re: Mobile Home Axle Conversion
    If the axles are tagged or stamped (for limited moble home use) the spindles are forge steel that are not precision ground with smaller bearings conversion hubs are generally not available.
    Apr 2013
    Roxboro, NC
    Quote Originally Posted by triptester View Post
    Thanks. These axles are ca. 1970, wonder how older ones were made...
    Apr 2010
    bastop texas
    Quote Originally Posted by polarred21 View Post
    I cant remember exactly but you can get old ford truck front rotors and bearing that fit great on those axles try like mid 80's
    Lincoln Power Arc 4000
    Thermal Arc Fabricator 252 i
    Thermal arc 186
    Thermal Arc 26 tig
    Tweeko 200 amp spool gun
    Hobart AirForce 400
    WP-17V-12R
    Jun 2010
    Axles are cheaper than buying parts for an older MH axle.
    Mar 2009
    Iowa
    Quote Originally Posted by blackbart View Post
    And even if it isn't cheaper, it won't be too far off. Plus, you'd have all new stuff.
    My name's not Jim....
    May 2007
    SoCal
    They would make great fence posts! Mailbox perches...material racks...
    My suggestion is to go to www.dexteraxle.com and order a new one and don't look back.
    I spent ten years working on portables (mobile offices) and 9 years on RV's & trailers. MH axles blow industrial duty chunky puke.
    Job 28:1,2
    Danny
    Jun 2013
    Pacific Northwest
    Are they actual mobile home axles? I found this article on how to identify mobile home axles.
    http://blog.easternmarine.com/traile...le-home-axles/
    (Some of the links are bad....maybe parts aren't available for mobile home axles).
    I make this point, since I purchased a commercially made trailer (70's vintage) that used what "LOOKED" like MHA. But they are not. They are called UTG axles and are rebuild-able.
    There are both types running around, just because they are 5 spoke "California" wheels doesn't mean the axle IS a mobile home axle..... Granted, tires for mobile home use say it right on there (and are cheaper) then the non mobile home tires. Something being DOT certified or some tax....(figures, $$$).
    Apr 2013
    Roxboro, NC
    Well good question and I haven't looked that hard. Here they are in my ad:
    http://raleigh.craigslist.org/pts/3927965227.html
    Jun 2013
    Pacific Northwest
    I can't really see/say. The "main" feature according to the link I gave was the backing plate was/is welded to the axle. I can see that the axle appears to have been cut and narrowed. And the leaf spring that is visible looks like it is multi-leaf. The OEM type mobile home axle is said to be a mono leaf....really thick sucker. I'd say 51% it's probably a mobile home axle, at least one is for sure....
    I can't say that mine are welded or not, but it's on a commercially made trailer.
    Here is a link of some hub/drum parts.
    http://dexteraxle.com/inc/sdetail/6768/6795
    Sep 2005
    Cave Creek AZ
    Championtrailers.com sells a conversion bearing set IIRC
    Apr 2013
    Roxboro, NC
    Also I forget to mention I did buy these off a mobile home.....
    Thanks for the links.
    Oct 2011
    Elkhorn, WI
    My dump trailer has them on it.
    Cut downs with weight tags.
    Tires did say MH Use Only when I got it.
    I have upgraded the tires to DOT approved.
    My Commercial built Hevi-Duty Trailer had 3 axles under it that looked MH but has Low-Boy 10 ply rated tires on it.
    Figure those 2 out!
    Feb 2013
    Sweet Home Alabama
    Back in the 1970s there was a company in Springville ,Alabama called Birmingham Manufacturing that built a trailer called a Totem-all Trailer the trailer came with an Industrial Grade Axle that had a cast hub that looked to be the mobile home type. However it was not a mobile home axle It was rated for regular Highway use and had a great safety factor. The tire used was, if I remember correctly , 8.00X 14.5 Light Truck Tire or Industrial tire. They built a 6 ton version (2 axle) and a 9 ton version (3 axle) . There was also a 6 hole wheel(disc wheel ) that a 14.5 LT tire would fit on. I have a 6 ton trailer now with this 6 hole wheel and 800 x 14.5 Industrial tires. AT that time we could buy this axle in various wheel width tracks. Axle used back then were Dexter, Hammerblow, and Kelsey Hayes. I dont know if the latter two companies are even open today.
    There was a distributer in Cookville Tenness called Lucky B Trailer Axle company that has since been sold and the name has been changed. I am out of town but I may have the name of the new company when I get home. One might could purchase his new axle pretty reasonable from this company. I was a partner to the owner of this company back in the early 1980s with a sister company Lucky B of Alabama. P M me if you want me to try and look up the new number or google Lucky B of Cookville Tennessee. Good Luck. richey sweet home alabama
    Aug 2008
    NO, NO,...............AND NO!!!!!!!!!!!!!!!!!!!!!!!!
    They're trash, look at the pics closely. The one of the actual axle shows the axle to be bent
    They're worth the price of scrap, AFTER YOU GET PAID TO DRAG THEM OUT OF THE BRUSH
    http://www.farmersamm.com/
    Aug 2011
    North Central Mo
    Quote Originally Posted by farmersamm View Post
    Are you seeing the reverse bow that is made into trailer house axles. If your time is worth any thing dont use axles with 14.5 tires or try to conver these type. Spend some money and have something good.
    Jun 2014
    Mesa AZ / NW AZ
    Got linked to this searching for info on my latest project acquisition. Great info, thanks.
    Have enough / know enough to be dangerous
    Jun 2010
    if you call a mobile home mover, at least in CA axles are $50 each with springs. I use them on "Park model" cabins where they get used for about a 1/4 mile and code says to leave them on. I don't use mobile home axles for anything I would tow a lot. Regular axles are cheap.
    Jun 2013
    Pacific Northwest
    The California style or Dayton or demountable type hub that uses the 14.5" rim/tires ARE available. Look at this PDF from the Dexter site for the 5500-7000 pound rated axles- page 10 of the PDF (page 65 on the PDF page )
    http://dexteraxle.com/i/u/6149609/f/...Hub_Groups.pdf
    Stick
    Forney FS 295 Vw
    Lincoln 180 AC
    Power Units
    Lincoln DC-250 w/ LN-7 Wire feed x2
    Welder/Generators
    Miller Roughneck 1E
    Miller Generweld 130
    Mig Welder
    Century 130
    Miller Passport (Blue case)
