How to check weld Strength
Results 1 to 6 of 6
    Jun 2005
    I have recently welded in the top section of my crew cab , this picture does not show the welds, but I was wondering what would be a good test to check the strength of the weld? Also what I could look for on the weld to insure its got good penetration?
    Jan 2005
    Snohomish, wa
    are you wanting nondestructive or destructive testing?
    CHRIS
    Jun 2005
    Since the piece is on the vehicle, which ever one would do the least amount of damage to the vehicle...
    Jan 2005
    Snohomish, wa
    well then thats nondestruc, however, there are no fesible tests for that. inspection is all you can do. send pics, top, behind, upclose, wide angle. good luck
    chris
    Northern Cal., Shasta County
    About the best you can do now is use the pieces that you either removed or have left over to replicate a little of what you've done. Then have at it, bend, pry and twist.
    Jan 2005
    Snohomish, wa
    satex,
    if you take pics of it, real good ones, I can take a look at it and give you a pretty good idea just by the appearance. Given how thin the stuff is there arent the kinda problems you have like on a bridge or something...
    Chris
