alu sailboat buliding - Page 78
Page 78 of 78 FirstFirst ... 2868767778
Results 1,926 to 1,949 of 1949
  1. #1926
    Mar 2009
    Oslo,
    Re: alu sailboat buliding
    Quote Originally Posted by farmersamm View Post
    http://www.yachtsurvey.com/Alignment2.htm
    This info was in one of the links I posted earlier. Read them, or ignore them I guess. At least I'm learning a bit on how to build my next boat
    tnx. will read
    Sent from my S40 using Tapatalk
    Sailing the Farm - A seagypsy group of tomorrow
    Lincoln Squarwave 200 TIG
    Lincoln Powerwave S350 with Powerfeed 25 aluminium.
  2. #1927
    Apr 2013
    Quote Originally Posted by zeyang View Post
    what is acceptable prop shaft allignement ?
    A few thousandths of an inch on the outside of the flange, no need to displace shaft to mate with coupling (only lift it a bit to account for weight-sag), no rubbing between shaft and shaft alley, no pressure on the side of the shaft log, shaft log hose straight, no noticeable misalignment-induced vibration.
  3. #1928
    Mar 2009
    Oslo,
    15 mm now. plus reinforce sides. then steel plate underneath welded to a 16 mm bolt fastening to the engine
  4. #1929
    Looking a lot better than before. What are you using for engine vibration isolation?
  5. #1930
    Mar 2009
    Oslo,
    Quote Originally Posted by zipfactor View Post
    nothing. we skip rubber and tighten hard. will be noisy. as long as we manage to go up to a civilized country to change engine its ok.
  6. #1931
    Apr 2013
    No wonder it came apart! You must use vibration isolators.
  7. #1932
    How did we all miss that on the original build?
    4 out of the 5 voices in my head say "Go for it".
  8. #1933
    Not the end of the world. I've seen quite a few people that race cars use hard engine mounts and they worked fine for the application. It looks like you have quite a bit of mass with the aluminum and steel. Assuming decent welds, which I'm sure you're at a pro level now considering all the welding on the boat, I'd say you'll be fine until engine changeover in the U.S.
    Good luck and let us know when you set sail!
  9. #1934
    Apr 2013
    ...I've seen quite a few people that race cars use hard engine mounts and they worked fine...
    A diesel sailboat auxiliary is quite a different kettle of fish.
  10. #1935
    Quote Originally Posted by ezduzit View Post
    The problem with putting flex mounts on the engine is that the rest of the system, such as the the exhaust system and drive shaft, may not be able to accommodate the added movement. I'd say his odds are better to mount as was done originally (hard mounted?) to avoid causing failure of other systems connecting to the engine. He can deal with a re-engineering when switching over engines, which would be a much more convenient time.
    Solid / hard mounts on diesel sailboats isn't that uncommon, anyhow.
  11. #1936
    Apr 2013
    I have been a boat builder for more than half my 73 years, and have never seen an engine hard mounted as you describe. All are mounted using shock mounts.
  12. #1937
    An example of a properly isolated diesel engine in a boat. From q240z's refit thread. http://weldingweb.com/showthread.php...ighlight=refit
    I'd tend to agree with you zip on just getting the thing nailed down to get the vessel north where a re-power can be accomplished and proper isolation and all that goes with it.
  13. #1938
    Mar 2009
    Oslo,
    we used rubber before. it did disintegrate. in manual it says: if you want to stop noise you can if you wish use 10-15 mm oak or 3mm rubber. other option is nothing. i think bolt hard down.
  14. #1939
    Mar 2009
    Oslo,
    it seems perkins 4.236 need to be moved up. does it exist a gearbox who manage to move the shaft point down 20cm or more?
  15. #1940
    Here's a link to a vertical offset gearbox. The spec sheet doesnt give exact input to output shaft height, but it looks to be pretty close to your 20cm requirement.
    https://www.performancediesel.com/wp.../DS-ZF_500.pdf
    No idea on what gear ratio tou need, but I'm sure they make it in the vertical offset configuration.
  16. #1941
    Mar 2009
    Oslo,
    making engine bolts with steelplate underneath
  17. #1942
    Mar 2009
    Oslo,
    tnx. will check.
  18. #1943
    With an SAE #0 or #1 bell housing, that ZF 500 marine gear is as large as the Perkins 4.236 itself.
  19. #1944
    Mar 2009
    Oslo,
    engine is back in with new and much stronger engine beds. will keep us moving for awhile
  20. #1945
    Glad to hear ur back going again.
  21. #1946
    Mar 2009
    Oslo,
    all good to go. just need diesel and food then ready to head out to sea again. next leg is some 2000 nautical miles.
  22. #1947
    Mar 2009
    Oslo,
    Arrived Azores. Pretty filled up even so late in seaon
  23. #1948
    Mar 2009
    Oslo,
    leaving Horta for Scotland. another 2 weeks sailing.obligatory painting on the wall.
  24. #1949
    Mar 2009
    Oslo,
    painting ladies
