Back blade repair
Results 1 to 20 of 20
    Jul 2013
    Pine City mn.
    Back blade repair
    Got this back blade years ago. Customer brought it in for repair but when I gave him a price he said just scrap it and went and got himself a new one. I fixed the pivot a few years ago so I could plow snow but I wanted to do some dirt moving this summer so I decided to fix the blade too. Here is what I started with. I had to do it in a friends machinery shed because I hadn't gotten the electricity run to my shed yet. Not the best work environment, but better than outside. I started by pulling it straight as possible with a chain and jack. Then some heat and hammer work to get rid of the crease. I didn't heat the cutting edge because I didn't want to weaken it any more than it was. I got it pretty good without.
    Jul 2013
    Pine City mn.
    Re: Back blade repair
    Next I took some 3/16"x 6" flat for bracing. One flat from the center tube out and 2 cut to fit the top and bottom to fill in and attached to the center support. I did both sides the same.
    Jul 2013
    Pine City mn.
    Took a little barring to get it into place but not bad.
    Jul 2013
    Pine City mn.
    Then welded it 100% and some finish hammer work to get the top straight.
    Jul 2013
    Pine City mn.
    Then weld in the plate that got torn out and weld the brace from the top link and some paint and it's done.
    Bemidji MN
    Jacks and chains, big hammers, torch, looks like something I'd do
    I like the bracing on the back almost as much as the color - pretty close to my WD Allis Chalmers
    Airco 300 - Syncro 350
    Oct 2011
    Elkhorn, WI
    Nice Job!
    When I did one for a customer (bent worse) I used a hydraulic jack and I-beam, only taking cutting edge off first.
    I put a piece of heavy angle iron across the bottom using 1/2" backers where you used the 3/16" box.
    I posted it on here somewhere?
    Jul 2013
    Pine City mn.
    It's case paint to match my DC and 400. lol
    May 2008
    Orange, TX
    Great mods and nice use of what you have to get the job done.
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save 2nd Base!
    Jan 2013
    Houston, TX
    Guys,
    It is not John Deere yellow so it must be Kubota orange.
    Excellent work. The few dings that are left are battle scars. Character.
    Kubota T1880 mower, RTV 900 side-by-side, L2800 tractor, John Deere 310G backhoe.
    Jul 2011
    Excellent work!
    TA Arcmaster 300
    CM3
    XMT 304
    S22P12 suitcase feeder
    X-Treme 12VS
    Optima pulser
    TA161S
    Maxstar 150STL
    Hypertherm PM45
    OP setup
    Stihl 020AVP, 039, 066 Magnum
    May 2010
    laguna niguel, Ca USA
    that came out nice
    Miller Xmt 350
    Lincoln Ln-25
    Ahp 200x
    Smith Gas Mixer AR/H
    Tig is my Kung Fu
    Throwing down dimes and weaving about
    Instagram http://instagram.com/weldor_wes
    WeldorWes@WcWeldingLLC.com
    Feb 2013
    Florida
    Nice work!!. I never cease to be amazed after I repair a completely abused and beaten down piece of equipment about how good it can look(and work) after repairing and painting.
    I love that Kubota Orange color. I wonder how my Idealarc would look that color.
    Jul 2013
    Upstate New York
    Looks good!!
    Miller Thunderbolt XL
    Hobart Handler 140
    Nice work and the welds look good! Good job on the painting.
    PlasmaCam CNC cutter
    Lathe and Band Saw
    Clamps
    Jul 2013
    Pine City mn.
    Thanks so much for all the nice comments. This was a fun job.
    Sep 2012
    Knoxville, TN
    Great fitup on the brace on the rear. Be careful, though. My impression is that most of the time, when you brace one part of an implement and not the rest of it, you just cause the next thing in line to break when you abuse it. Most likely, the customer ran this blade on way too high a HP tractor, otherwise it wouldn't be bent up like that. Don't make the same mistake, and it'll probably last you a good long time.
    What surface prep did you do before painting?
    Everlast PA160-STH
    ... and that's about it!
    Jul 2013
    Pine City mn.
    You are right about chasing the repairs around. Been there done that! It's just going to be pushing some dirt and snow around the yard on a 40 hp tractor and I know I'll have to take it easy. A for the paint I just wire brushed it to get most of the loose paint and rust off and brushed on some implement paint. I normally don't do cheesey paint jobs but since this is a user and not for my collection I did it on the cheap.
    Dec 2012
    Denison TX
    Goood job man! Now sell the sucker and make some cash!
    May 2013
    NC
    Nice work!
