Broken bolt on Exciter Cap
Results 1 to 8 of 8
    Jan 2013
    San Antonio, Texas
    Top bolt broke. Tried to drill it and use easy out to remove bolt. Then easy out broke. Pushed it in with a center punch and re drilled it. Had room for tap, so i thought. Then the tap broke off in the hole. Guess what my question is how do i get the easy out and now tap out of the bolt hole?
    Jul 2013
    NYC
    What size is bolt?
    Sal
    May 2008
    Orange, TX
    Re: Broken bolt on Exciter Cap
    Quote Originally Posted by WPSalvation View Post
    What size is bolt?
    1/4-20
    Quote Originally Posted by Texas"T" View Post
    Utilizing 20/20 hindsight, I would have started by welding a 5/16" nut on it to get it out. If the bolt was broken off below the surface I would have used a 13/64 (tap drill size) to drill it out and re-tap (using a sharp tap).
    But to answer your question as to what to do now - you've likely got your work cut out for you if you can't weld a nut on the piece of broken tap.
    Any photo(s) of the patient?
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Delaware
    Well a broken tap extractor will work
    Plasma Cutter and Welder Repair
    Tec.Mo. Wholesale Distributor and Dealer
    Consumables for the PT and IPT torch's.
    Jan 2013
    San Antonio, Texas
    thanks for the info. size is 1/4 20. where can i get a tap extractor?
    Jul 2009
    SW Washington State
    Hello Texas"T", in addition to the suggestions that have already been given, if you have access to a GTAW/TIG welding machine here is another alternative. Generally I will use stainless steel filler wire when I use this method as it resists the boiling/pin-holing that I have experienced with standart ER 70-SX rods. Carefully apply filler to the broken portion of the tap/bolt/other stuck item and once it is built-up enough you can generally grip it with vice-grips and work it out. Good luck and best regards, Allan
    aevald
    Delaware
    They have them on ebay
    Jan 2013
    San Antonio, Texas
    Thanks to everyone with their comments. i used a high strength bit and slowly drilled through it. then retaped it.
