Grinding wheel for tungsten electrode
Results 1 to 25 of 30
    I bought a bench grinder just for grinding the tungsten on my tig welder. The wheel that's on there turned to powder grinding a tungsten. Is there a certain type of wheel you should use?
    Mar 2013
    Re: Grinding wheel for tungsten electrode
    I think what is more important is that you grind it on a dedicated wheel only for tungsten, use a fine-er wheel and grind the tungsten tangential to the wheel.
    Best --> Diamond wheel
    Good--> Silicon carbine (green)
    Fair/Common--> Aluminum oxide, this is your standard stone, yes it will groove, just dress it when needed. They are fairly cheap.
    Tungsten is very hard and will wear out any wheel in short time.
    SoCal-LA
    Quote Originally Posted by zkling View Post
    I think what is more important is that you grind it on a dedicated wheel only for tungsten.
    Why????
    Miller Dynasty700DX, Dynasty350DX 2ea., Dynasty200DX, ThermalArc 400 GTSW, LincolnSW200 2ea., MillerMatic350P, MillerMatic200 with spoolgun, MKCobraMig260, Lincoln SP-170T,PlasmaCam/Hypertherm 1250
    The reason I asked is I noticed some wheels Ive used in the past lasted longer. I bought this one just for my tig welder so I wanted something god just for tungsten.
    Why????
    From what I was told in welding school it will contaminate the tungsten.
    Sep 2010
    China
    Why????
    Because if you grind any type of steel on it, it will embed in to the tungsten when you sharpen it with the same wheel. I have used tungsten that has had steel ground on it before I didn't notice a difference. I was told the same in school as well.
    Miller Maxstar 200 SD
    Piperliner #10 Gold
    Jan 2011
    Phoenix Az.
    I found a little orange "bench" grinder over at Harbor Freight. Three inch wheels and a cost of $9.00. They also have a four pack of diamond wheels almost the same size. Just drill out the center hole to fit the shaft on the grinder and you are good to do.
    Oh yeah, the diamond wheels cost $9.00 also!
    Been using mine for about 3 years now...
    From the desk of Kevin Caron
    Trying to be the best me I can!
    www.kevincaron.com
    AHP Alpha Tig 200x
    MillerMatic 250
    Miller Syncrowave 200
    Apr 2010
    Quote Originally Posted by kevinacaron View Post
    You need to resize your photos smaller or it cuts off your texts also
    But yes i have been looking at one of those but could not find a wheel of that type for it you say both are available from HF...
    I have to go looky see
    Thanks
    What would SATAN do ??
    Miller Trailblazer 302 AirPak
    Miller Digital Elite
    Optrel Welding Hat
    Arcair K4000
    Suitcase 12RC / 12 VS
    Hypertherm PM-45
    Rage 3 saw
    Rusty old Truck
    May 2011
    Dallas, TX
    Why????
    Is that true or an old wives tale?
    I never understood how a softer metal could be imbedded in a harder metal. But I've always used a dedicated wheel because that's what I've always heard.
    Mar 2013
    Why????
    Contamination issues. It is usually not much of an issue at home where you know what has been ground on the wheel, but in a large shop environment, you may be putting who knows what junk onto the tungsten. I have walked up to grinding wheels that were plugged full of aluminum or other mysterious crap. and of course no dresser in sight.
    SoCal-LA
    Quote Originally Posted by dallas_ View Post
    Yeah, it is like using cheese to cut a diamond.
    Dedicated grinding wheels don't make any sense to me. So a grinding wheel rubs steel or alum onto my tungsten then grinds it right off. Cool!
    Laredo, Tx
    If I have to use the fine grinding wheel (that I use for tungsten) for something else, I always carry a "sacrificial tungsten" on hand, usually a 1/8" diameter, and grind that FIRST. That way if anything is gonna get contaminated, it's gonna be that one (usually a pure 1/8" tungsten since I have no use for it, lol). Grind that all over the wheel first, then sharpen my welding tungstens.
    First person on WeldingWeb to have a scrolling signature!
    HTP Invertig221 D.V. Water-cooled
    Millermatic 211 Inverter MIG w/ Spoolmate 150
    Eastwood 40A Plasma cutter
    Ive been using my grind everything wheel for tungsten. I scooped up a little 4" bench grinder at a auction just for my welder. How a soft material would get embedded in a harder one I don't know. Ive been grinding all kinds of crap on the same wheel I do tungsten's on and I don't know if I noticed a difference or not.
    Jul 2013
    NYC
    get a tungsten sharpener... if not, use a xmas tree dye grinder deburrer
    Sal
    Jul 2013
    NYC
    tungsten sharpener... can get a good 2nd hand deal im sure
    Sal
    Ive seen those but if you get a booger on the end of the tungsten then it wont fit in the hole
    May 2012
    For those asking how a softer metal can get embedded into a hard tungsten electrode, look no further than your aluminum oxide (or silicon carbide, or diamond) grinding wheel. Your grinding wheel is considerably harder than any metal you grind with it, yet after grinding, you will find particles of metal embedded all over the surface of the wheel: the bits of softer metal get lodged in the surface "pores" of the wheel.
    If you were to examine the ground point of your tungsten electrode under a high-powered microscope, you will see that the surface is not smooth but rough with grinding scars and ridges. If there are any other metals embedded on the surface of your grinding wheel, they will get transferred to the tungsten and get embedded into the tiny pits and ridges of the tungsten.
    Jul 2011
    Quote Originally Posted by Michaeljp86 View Post
    It is a problem with them, but it's controllable.
    The only way I get a booger like that is if I dip on steel repeatedly and don't regrind ASAP. Never with Al, cause once you dip, the parties over.
    Any tungsten with a booger that big should be snapped of anyway.
    TA Arcmaster 300
    CM3
    XMT 304
    S22P12 suitcase feeder
    X-Treme 12VS
    Optima pulser
    TA161S
    Maxstar 150STL
    Hypertherm PM45
    OP setup
    Stihl 020AVP, 039, 066 Magnum
    Jul 2012
    I have a garage sale grinder with a shaft on each side, one side has a green wheel for roughing and the other is a very fine diamond wheel for finishing, it is used just for sharpening my electrodes. A thing to keep in mind that diamond wheels should not be used dry.I rigged up a drip type wetter a plastic bottle with a old gas ball valve with a piece of 1/4" tube bent to drip on the wheel.
    Quote Originally Posted by SpyGuy10 View Post
    Just so happens I have a good microscope, maybe Ill see what I can see some time.
    Quote Originally Posted by thphtm View Post
    Good idea, Ill have a booger grinder on one side and a sharpener on the other.
    Jul 2013
    NYC
    Thats what she said... And the entry is pretty wide for tungsten, would have to be like big foot's booger
    Sal
    Dec 2015
    Yeah,
    I have a handheld tungsten sharperer that I like, since it was chaper than others and had a turret-style arrangement that doesn't need collets.
    Yeah, and if I was using a 3/32" tungsten, I could only rotate to the 1/8" size to whittle off any blob, until it would again fit into the 3/32" slot.
    But, after a while I just cut a slit onto the body of the thing, to allow the contaminated tips, regardless of how big the blob is, to be cut off with the wheel.
    That often makes things quicker too.
    Peace to you all,
    Christian Livingstone
    www.youtube.com/newjerusalemtimes
    Everlast 210EXT AC/DC (2015)
    CAT250D 200 amp DC TIG/Stick/Plasma
    Mar 2006
    Yuma, Arizona
    Quote Originally Posted by WPSalvation View Post
    Let me know when there is a 2nd hand deal to be had. I just can't seem to catch a break on a decent grinder.
    Lincoln Precision TIG 275,Undercart cooler,Foot/Finger Amptrollers
    Lincoln Hobby-Weld 110v
    Lincoln SP-200 MIG and Hi-Freq Tig
    Mar 2006
    Yuma, Arizona
    Quote Originally Posted by Drf255 View Post
    Shall we go through the "Snapping vs Cutting" argument all over again?
    Nov 2014
    I'm a detracted guy becuase I think it will make the tungsten smoother. If u use the same grinding wheel, belt or flap disk it will get beat up and not be smooth on the tungsten, we all like a sharp point on our tungstens for dc so a rough grinding from grinding a bunch of different kinds and shapes of metal will not let u get as good of a sharpened point on the tip of tungsten. Just my 2 cents. Btw I use flap discs on my 5" grinder. So could possibly be different on stone or big belt sander but dout it
    SoCal-LA
    Hey! We agree on this! You are a detracted guy!
    As my belts wear out they get finer and leave an almost polished finish. I would think the same withe your flap disk.
