Ranger 8 - ONAN 16hp - Battery not charging
Results 1 to 5 of 5
    Apr 2013
    I got a Ranger 8 with ONAN 16hp engine . 2 cylinder
    It works great but the battery is not charging.
    With the engine working to its maximum idle, I got 12.2/12.30
    I changed the voltage regulator (for a cummins original), I got a new battery,
    the stator seems to be fine - I tested it and shows continuity
    and it's not grounded.
    Everything seems to be fine and I don't know what else to look for.
    I'd appreciate some advise.
    Thank you.
    May 2008
    Orange, TX
    Re: Ranger 8 - ONAN 16hp - Battery not charging
    If that voltage reading is at the battery, I would check the engine harness plug to make sure the terminal connections are good. Common failure point.
    Depending on engine spec#, stator resistance is either .06-.10ohms or .10-.19ohms.
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    4 out of the 5 voices in my head say "Go for it".
    Jun 2008
    Check it like Duane said.
    If it's the same setup as a lawntractor charging system disconnect the regulator and check for AC voltage coming from the stator, should have 'round 25VAC± at a fast idle. Could have lost the magnets from the flywheel.....Mike
    May 2008
    Orange, TX
    I thought about the magnets too Mike but if they came loose I suspect the stator would be toast and show shorted to ground, open or both.
    Still, if everything else (except AC output) checks out, time to pull the flywheel.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Apr 2013
    Everything is working now.
    I checked and found that the B+ wire was cut. I connected it and that was it.
    Thanks!
