What are the specs. for a plate test?
Results 1 to 13 of 13
    May 2013
    Central Florida
    I have some 1" thick x 4" wide steel flat bar laying around and would like to try some vertical uphill welds. The coupon can only be 4" tall because I can cut the bevel in my bandsaw. What are the specifications that would be seen on a test for something of that thickness? (Single bevel/compound bevel, bevel angle, # of passes) I will try some with 7018's and some with my 12vs running Lincoln Superarc L56 .035" with 75/25. I know that wire is probably too small for a real test but it should give me some practice. Any advice as far as technique would be appreciated.
    TOO MANY TOOLS & NO MORE SPACE
    Feb 2008
    North of Philly
    Re: What are the specs. for a plate test?
    This might be what you are looking for... I'm pretty sure this is for AWS D1.1. Note in that pict the have the backing bar ending right at the edge of the weld plates. In many cases they allow you to extend the backing strips past the ends and use them as run on run off plates. 6" is the usual size so there is enough clean material to cut out your test strips for bend tests.
    Thanks to CEP for the original pict.
    Ronald Reagan
    May 2010
    Port Orchard, WA.
    Here is a better picture of the run on and off tabs.
    Don’t pay any attention to me
    I’m just a hobbyist!
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    May 2013
    Central Florida
    Thanks, that is exactly what I was looking for. What do they mean by unlimited thickness? I'm sure some really thick stuff the procedure would be different and you would have to be recertified.
    May 2013
    Virginia
    If you can pass it you are "qualified" to weld on any thickness of metal with that particular process.
    I assume the procedure would be the same, the only differences would be the direction you stack your beads in...
    Though I've never done plate thicker than 1/2" and I am not D1.1 certified. Could be wrong.
    Jun 2013
    Northwest Arkansas
    Quote Originally Posted by Chris T. View Post
    D1.1 has 2 thicknesses certs. Up to 3/8 and unlimited. Once you are certified in unlimited, you are good to go. The only things that change are preheated and potentially bead order/count as you go up in thicknesses. But, if you are doing anything like this, you will be welding to predetermined weld procedures. These will dictate bead type, count, preheat, travel supported and volt/amp ranges.
    I an no longer certified in D1.1, but held both AWS & CWB for unlimited structural spray MIG.
    Sent from my SGH-T989 using Tapatalk 2
    May 2013
    Central Florida
    I ran a practice coupon today and I would have failed. I cut the plate in half and had one pinhole in the middle about .020" in diameter. The crown of the weld was off center which I'm assuming was due to the gun being pointed to one side. Finally the edges of the top of the weld looked like a tig weld made with no filler.
    Here are the specs,
    ●1" plate 4" long.
    >22.5deg bevel
    >45deg included angle
    >1/4" gap
    ●2" x 1/4" backing strip 6" long
    Lincoln SuperArc L56 .035" wire
    20 volts @ 225-235 ipm.
    75/25 @ 20cfh
    May 2013
    Central Florida
    Pics.
    May 2010
    Port Orchard, WA.
    Personally I wouldn't run .035 wire on 1-inch thick material. I would run 1/16-inch wire.
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Apr 2010
    Ghana
    Pics.
    Failed the visual...............excessive reinforcement, has to be 1/8" or less.............and I require stringers, no weaves.
    If i'm not mistaken D1.1 is 3/4" plate and D14.3 is 1"........I test all my guys to D14.3 standards for earthmoving equipment.
    6 Miller Big Blue 600 Air Paks
    2 Miller 400D
    6 Lincoln LN-25's
    4 Miller Xtreme 12VS
    2 Miller Dimension 812
    4 Climax BW-3000Z bore welders
    Hypertherm 65 and 85
    Bug-O Track Bug
    Pair of Welpers
    May 2013
    Central Florida
    I appreciate the comments, I might have to "justify" purchasing a roll of .052" or 1/16" wire. I'm sure I'll use it for something. Most of the time is flux core or dual shield used for structural? The next coupon I will try is the same size but with some 1/8" or 5/32" 7018. The one book I have says 7 passes of 5/32" 7018 for 1" material does that sound right?
    I'm probably being too critical for only practicing but I like to base my practice on what is seen in real world situations.
    May 2010
    Port Orchard, WA.
    Most structural shops will run dual shield wire. Outside construction for structural is self shielded flux core wire. If you think you'll be using a T-8 wires. NR-232, NR-233, and Coreshield 8 are very popular. If you can get by with T-11 wires Hobart's Fabshield 21-B is a good general purpose fab wire.
    I never gave it much thought how many passes to run, I weld until the weld is to size, or the joint is full.
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    May 2013
    Central Florida
    Thanks CEP
