Suitcase Welder
Results 1 to 25 of 32
Thread: Suitcase Welder
    Apr 2008
    Suitcase Welder
    I know, I know, it's not exactly a Miller but what the hey. It's "ho-made". I'd say it's better than a Chinese welder but every part in a Microwave Oven says "Made in China". It's putting out 42 volts, a little better than I hoped for. I don't have a way to measure the amps. Started with 6013 1/16th rods because I figured that would be about all it would do but it burns 'em right up so I'm going to try 3/32 today. The weld pic is it's first run and the first stick weld my son has ever done. We'll get better at it. Main thing is we had fun doing this and it cost just about nothing thanks to our throw away society. Thanks for the idea Llamafur.
    Jan 2009
    Kansas City
    Re: Suitcase Welder
    He-he, that's VERY KEWL!
    I'm glad to see the magnetron tube is not around. You wouldn't last long yourself if it was. Maybe you should add a statement like, "Do not try this at home, we are professionals."
    Steve
    Nov 2006
    Re: Suitcase Welder
    Ha ha ha... I'd like to see that get passed airport security as a carry-on!
    That's a good one!
    Congratulations on your build, thanks for posting it.
    Good Luck
    Apr 2009
    Tucson, AZ
    Re: Suitcase Welder
    "Yes, Officer, I weld for a living. No, all those wires and transformers in my suitcase are NOT a bomb - it's my welding machine. Why do I have to come along with you? .......... Could you get this dog to stop sniffing at my crotch?"
    Great work. Llamafur, your Instructables homemade welder strikes again!
    Nov 2008
    Re: Suitcase Welder
    nice job
    Sep 2008
    Re: Suitcase Welder
    thats cooool, bout how much does it weigh?
    Apr 2008
    Re: Suitcase Welder
    Tried 3/32 rods with the suitcase this afternoon and I think I found it's sweet spot. The 1/16 were just too small. But now on to the next problem. The damn thing really lays down a nice bead.
    Someone gave me one of those Matco made in Italy mig only welders some time ago. The gun is no good and the plastic drive mechanism is broken. It's not worth repairing. On the other hand it has a transformer about five times bigger than a microwave. I'm thinking this might make a pretty good DC stick welder. If it is DC. I guess that's my first question.
    My little Miller Sidekick Mig is DC so I assume this one would be too.
    Looking at it, it seems that if I disconnect the mig electrical parts what I'm left with is an on/off switch, a four position tap and a transformer. Nothing much else in there. I thought about just connecting my electrode holder and ground clamp to the secondary winding and go. That's about all that is involved with the suitcase deal. I'm a little reluctant though because I don't want to tear up the transformer. I figure you guys will know if this welder is DC or not, and if I'm just being stupid. I know you can buy a tombstone AC cheap enough but this is good father and son stuff. Feel free to make fun of me.
    May 2009
    Columbus, OH
    Re: Suitcase Welder
    Wonderful, 42 volts is also great too. whats going to be your first project?
    Apr 2008
    Re: Suitcase Welder
    Thanks Llamafur. We don't have a thing to do with it right now. Something will come up though. What do you think about the Matco transformer idea? I read on the Instructibles page that there was nothing wrong with using a bigger transformer if you had one.
    May 2009
    Columbus, OH
    Re: Suitcase Welder
    the output from the transformer is AC, it gets rectified to DC by a full wave bridge then smoothed out by a big capacitor.
    Jan 2009
    Kansas City
    Re: Suitcase Welder
    Quote Originally Posted by hvw View Post
    I haven't seen a schematic but.... it sounds to me that you are tapped into the secondary of the transformer, meaning that it is an AC welder. If you add some diodes and capacitors from the transformer secondary winding before going to the electrode then you would likely have a DC welder.
    And again, nice project.
    Steve
    Mar 2008
    Re: Suitcase Welder
    lets see some pic of the weld with the 3/32 rod
    May 2009
    Columbus, OH
    Re: Suitcase Welder
    Quote Originally Posted by rookie_steve View Post
    Steve
    here is a rectifier, it just needs a capacitor across the dc output.
    Central West Virginia
    Re: Suitcase Welder
    Most MIG process I'm aware of is DC. There may very well be a rectifyer in the little MIG case. Lots of the self shielding MIG wire run DC- as opposed to DC+. Doesn't matter for a DC stick machine just wire out to a couple lugs so you can switch the work & stinger leads around for either.
    Be really nice if you can incorporate the amperage adjustment in the works.
    If the Matco will still fire up really all you should need to do is connect a stinger to where the mig gun hooked up. Jumper the MIG gun trigger wires together inside the case & go welding. You might also want to unhook, remove entirely, to lighten the unit, the feed motor.
    IF IT WORKS, DON'T FIX IT
    Linde-VI 253,400 & 450 w/MIG35 feeders
    CNC Table with Oxweld O/A & Hypertherm 1250G3
    Lincoln Ranger GXT 250
    Hobart-MicroWire 300
    ESAB Heliarc 161
    ESAB-Mobilemaster 2 CC/CV Feeders
    & more
    Apr 2008
    Re: Suitcase Welder
    This is a photo of the Matco. I've removed the mig gun and wire feed control. The windings on this machine are aluminum rather than copper like the suitcase. Even though the Matco transformer is much larger it gets much hotter. Suitcase really doesn't heat up.
    The welds in pic 2 are from the suitcase. I'd like to make the Matco a DC if it isn't already since I really don't need two homemade AC welders. We undid the two large secondary wires and wired the stinger and ground directly to them. I don't know if the gizmo they're attached to in the photo is some kind of DC deal or not. I guarantee you everyone on this board knows more about welding than me so any thoughts will be appreciated.
    Jan 2009
    Kansas City
    Re: Suitcase Welder
    Quote Originally Posted by llamafur View Post
    Yup, that would be a DC welder then. KEWL
    Steve
    Jan 2009
    Kansas City
    Re: Suitcase Welder
    Hmmmm,... Llamafur has the right schematic to change this from AC to DC BUT you will need to get hold of 4 diodes (or a bridge rectifier) and oil filled tin-can capacitors that can handle the current. I would suggest something along the line of 50 to 100 ampere capacity (shoot for the high side), otherwise they will burn or worse, explode! And pay attention to polarity (+ and -). Voltage ratings (go high) and polarity should be marked on the rectifier and capacitors. They aren't cheap unless you can salvage something.
    Steve
    Apr 2008
    Re: Suitcase Welder
    Yikes! All that is probably going to mean it'll just stay AC. Way beyond my grasp.
    Apr 2009
    Springfield, Ma
    Re: Suitcase Welder
    Those aluminum plates sure look like heat sinks for diodes. post a picture showing the stuff bolted to the plates better
    -- fred
    Sep 2006
    NJ, USA
    Re: Suitcase Welder
    MIG is DC, so somewhere 'downstream' of the transformer in the Matco should be the rectifier part of the machine.
    I'll guess that the rectifier (diodes) are probably on the large flat aluminum plates above the air vent in your picture.
    But unless you rewind the Matco transformer, the output voltage is probably going to be too low for stick welding.
    Also, please be safe with all the experimenting and such. Your totally open machine does have potentially lethal electrical levels out in the open there, and having a cloth suitcase next to a sparking/spattering stick weld is possibly a way to have a flaming suitcase.
    There's a reason why welding machines are typically made with metal cases. It protects the machine and the user.
    Have fun, but be safe.
    Jan 2009
    Kansas City
    Re: Suitcase Welder
    Quote Originally Posted by MoonRise View Post
    That could be the case where the high current diodes are available in the MATCO, however, he still needs the high current capacitors that are obviously NOT in the photo. The high-current capacitors I am referring to would each be about the size and shape of a beer can. And maybe two or three of them. The diodes only roughly change the AC to DC but do not SMOOTH out the output current as it should be in actual DC current. In other words, you would have a DC voltage with a rising and falling AC current riding it, without using the capacitors. I don't know why anyone would design it without the capacitors unless it was to save money, because IMHO it would be very erratic at best. Maybe that's what they did and now doesn't work - no surprise. But it's the capacitors that cost a lot and are subject to exploding if not the correct design.
    And this all needs to be BETWEEN (in series with) the transformer and electrode. It cannot be somehow "attached" to the circuit.
    Steve
    Mar 2009
    Iowa
    Re: Suitcase Welder
    what about caps for a stereo system? they are big and handle lots of current. Don't know on the voltage though 20-24v or higher maybe? I guess I don't know what voltage is needed for stick.
    May 2007
    Okanagan Valley.
    Re: Suitcase Welder
    I love it!
    "Do you have a suitcase welder I can borrow?"
    "Of course, here!" *hands over suitcase*
    "The hell?!"
    Mar 2009
    upland, ca
    Re: Suitcase Welder
    THAT
    IS........
    SPARTAAAAAAAHHHH
    May 2009
    New Port Richey, FL
    Re: Suitcase Welder
    That is a nice little suitcase you built... The Matco has a full wave bridge rectifier mounted on the back and has an induction coil on top of the transformer. This is common in the cheaper mig welders and stick welders. The induction coil acts as an arc stabilizer and there are no smoothing caps. These work very well in my opinion if you can't find any capacitors which can cost as much as a cheap welder! You can use the Matco as a stick welder with no problem with just the bridge rectifier and induction coil, they work just fine. The caps defiantly help but are not necessary for a decent stable DC arc. The cap or caps would have to be either one 47,000 mfd 50v or more, or a bank of 2, 3 or 4 making up the same value in parallel.
    Lincoln 3200HD MIG
    Miller Thunderbolt XL 225/150 AC/DC
    Old Craftsman 35-230 ARC modified with DC Rectifier
    Harbor Freight 80amp Inverter
    Harbor Freight Easy MIG 100 Modified
    A couple MOT ARC welders
    HHO Torch in progress
