Wire speed vs. voltage. Which to Adjust....
Page 1 of 3 123 LastLast
Results 1 to 25 of 54
    May 2010
    Sparks, NV
    would like input from the resident experts. There is a general range for each thickness/type of weld/machine etc, But I really have not seen a good discussion, guide for dialing in the weld. Which should get adjusted and how much to get that right weld. we know voltage controls the profile of the bead and amperage controls the current or heat of the weld. but what guide/suggentions/ approaches do you use to fine tune once you are in the range? When, why, where, which one first etc.
    Assume there is no WPS for the specific weld/project... Defualt is mild steel but free to add SS or Aluminum too if you so desire, hopefully this can be and educational thread...
    AHP200x; AHP 160ST; MM350P, Spoolmatic 30A; Everlast PowerTig 185; ESAB 875 plasma;Evo 355. OA
    Aug 2004
    North Central Indiana
    Re: Wire speed vs. voltage. Which to Adjust....
    I've found door MIG settings to be a good starting point. Our MM251's door chart is off one volt. If the door chart says 19 volts we set it to 20 volts, read the weld and turn the wire speed up until we get a strong and even frying bacon sound. I adjust for good tie in heat, how weld toes are washing in.
    May 2010
    Port Orchard, WA.
    I adjust the wire speed the most. But will adjust the voltage if I want the puddle to dry up, or wet out a little. Inductance control / pinch / arc force are also nice to dry up, or wet out the puddle too.
    Don’t pay any attention to me
    I’m just a hobbyist!
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Sep 2006
    NJ, USA
    From the Miller resource "Guidelines for Gas Metal Arc Welding (GMAW)", Page 8, from the Miller website (similar info available from the Lincoln website and from the rather nice info on the ESAB "ESAB University" site at http://esabna.com/us/en/education/esab-university.cfm ):
    - general parameters is 1 amp per each 0.001" steel thickness of workpiece (short-circuit transfer mode, spray transfer runs a much higher voltage)
    - using wire diameter info to get a relationship between WFS and amperage as follows (solid wire only, cored wires are different)
    0.030" = 2 ipm/amp
    0.035" = 1.6 ipm/amp
    0.045" = 1 ipm/amp
    example: using some 1/8" thick steel and some 0.030" wire gives us ~125 amps desired (1/8"=0.125") and thus 250 ipm (125 amps desired x 2 ipm/amp = 250 ipm WFS)
    - set voltage
    low voltage = wire stubs into workpiece
    high voltage = unstable arc, excess spatter
    Set voltage midway between too low and too high, so that you get a Goldilocks JustRight voltage, set also by getting that nice 'frying bacon' sound (short-circuit transfer only).
    Fine-tune specific parameters (adjust voltage slightly if you have a that ability with a continuous control for voltage, if not pick the 'closest' voltage and then fine tune WFS/amperage only, fine tune WFS/amperage during test bead for specific machine and shielding gas being used, operator 'preference' as to how the bead is being made, joint specifics (butt joint usually needs a bit less power than a lap or fillet joint, etc), weld position (out of position usually needs a slightly lower parameter setting than a flat position), joint fit-up, etc, etc).
    Watch the puddle and adjust WFS and/or travel speed to get the desired results.
    Oh, and maintain a consistent stick-out and gun angle too.
    Simple, right?
    Unless I'm waaaaay off with the voltage setting I started with, I'll usually fine-tune just with the WFS (amperage). If I had to keep turning the WFS dial down, I may then slightly nudge the voltage control dial down a bit as well (continuous voltage control machine, if a tapped machine holpefully I'm not that far off to start with ). Blowing a hole right through the (hopefully just the test bead) piece, turn down the settings. Not quite getting enough penetration, turn up the settings. Etc, etc.
    May 2010
    Sparks, NV
    moonrise, you did mention one that I forgot. Inductance control. fortunately on my Lincoln SP250, I just select the correct wire and gas on the digital panel and it presets the correct inductance. better explanation of inductance would be nice here too.
    May 2010
    Port Orchard, WA.
    This might help.
    http://www.esabna.com/EUWeb/MIG_handbook/592mig3_6.htm
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    city of Four Flags
    Is that example stainless? Why else would you short arc with 98/2?
    Jan 2013
    ...Shoulder of Orion...
    @ southpaw - good points listed above. Would also add the following:
    * Read/digest the 'GMAW Welding Guide' from Lincoln. Available free in .pdf format at http://www.lincolnelectric.com/asset...L-56/c4200.pdf . Excellent primer on GMAW setups, electrode characteristics, shielding gases, and welding MS/SS/Al with short-circuit/globular/axial spray transfer. The tables in each section are nice supplements to the data listed on the panel of a typical MIG welder. Find myself referring to this .pdf (actually printed out a copy and bound it) over and over, especially when running a machine for the first time.
    * WFS controls amperage and heat into a workpiece, while Voltage controls arc length/shape. Increase the WFS and more electrons flow to the work piece per unit time, resulting in greater heat/fusion delivered to the work piece. Increase the V and the arc length (distance from electrode to work piece) lengthens, resulting in a wider arc. The challenge is WFS & V need to be in-sync to maximize the performance for a given diameter MIG wire. 'MoonRise' and CEP are spot-on.
    May 2010
    Sparks, NV
    ManoKai, your last sentence is what i was getting at with this thread, when dialing in that final setting which way works best for each person. do they adjust volts first or IPM. etc, how much of a change to one before adjusting the other.. MY SP250 is kinda trick that way in that on auto I can adjust either the voltage or IPM on the fly with the on gun trigger. once the IPM changes past a certain point it automatically starts adjusting the voltage. I think it works the other way around too but not tried that... Again I'm shooting for "trade secrets" if you will from guys that do tons of MIG welding that will help out the hobbist
    May 2010
    Port Orchard, WA.
    Quote Originally Posted by vwguy3 View Post
    It doesn't say, I took it as for mild steel. Don't know why anyone would use 98/2 except for spray transfer.
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    May 2010
    Port Orchard, WA.
    I don't know if anyone can explain it with the type written word. I know, I have to see and hear the weld to know what to change.
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Sep 2006
    NJ, USA
    OK, how about this.
    Step #1 - check material thickness
    Step #2 - check door chart or manual for suggested parameter settings
    Step #3 - based on joint fit-up and type, make SWAG about whether to turn settings (mostly WFS, sometimes a little bit of voltage adjustment as well if using a continuously-variable voltage machine) up or down slightly
    Step #4 - make test weld
    Step #5 - adjust parameters as desired after/during making test weld. Usually just WFS adjustments for fine-tuning, unless original parameter SWAG was waaay off. Blowing hole right through, turn things way down (check door chart or manual for next lower suggested settings and adjust as needed). If you get no arc and the wire stubs into the workpiece and just pushes back the gun, make sure you have the workpiece clamp attached and attached well. If no nice 'sizzle' sound, turn up voltage slightly and leave WFS alone and try again. Too much spatter and/or the bead looks 'burnt', then turn down the voltage a bit.
    Watch the puddle and listen to the arc.
    May 2010
    Port Orchard, WA.
    Quote Originally Posted by MoonRise View Post
    OK, how about this.
    I stand corrected!
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Jan 2013
    @ MoonRise - 'zactly. Watch n Listen. Nice step-wise protocol. Gun'a start using it myself. Ha! Mahalo.
    Bemidji MN
    OK, how about this.
    This is what I do as well - only better stated than I would have done
    I always start with the door settings and adjust only if needed.
    Those Miller guys tested the settings to be "pretty close"
    Airco 300 - Syncro 350
    city of Four Flags
    I thought the same thing.
    This post is exactly why I think Autoset is NOT a good thing for noobies,you never learn to set the machine yourself.I do undersatnd that Autoset is aimed at the person that has never welded and makes setting the machine easier with limited skills.
    Aug 2008
    Sudbury, Ontario
    Since I started out mig welding with a millermatic 200 which has a stepped switch for voltage control, I usually set the voltage first and then dial in the wire feed speed to suit, guidelines from miller are ballpark but are seldom dead on for me.
    SA 200
    Idealarc TM 300 300
    MM 200
    MM 251
    30a Spoolgun
    Precision Tig 375
    Invertec V350 Pro
    SC-32 CS 12 Wire Feeder
    Oxweld/Purox O/A
    ArcAir
    Hypertherm Powermax 85
    LN25
    May 2010
    Sparks, NV
    OK, how about this.
    Unless you are Deaf then the whole listening thing goes out the window.. though i tend to feel for the smoothness of the gun...
    May 2010
    Port Orchard, WA.
    Listening to a weld is very important to me. I remember the first time I couldn't hear a weld. I got dispatched out of the hall to a Kaiser Aluminum can plant. Got signed in, went out on the floor to start working. It was so loud in that plant we had to scream in each others ear to be heard. Fitter said to start welding on a conveyor, I had to stand on the top step of an 8-feet step ladder and reach as far as I could to make an over head weld. When I struck an arc I was really set back by not being able to hear the weld. I thought there was something wrong with the welder.
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Hellinois
    My LN-25 and my Super S-32P do not have door settings.
    Great thread, I've always wondered what others do but forget to ask. I start with the settings from the Miller app on the iPhone, and I usually adjust the WFS to fine tune.
    How would you handle, in GMAW, the old saying for SMAW, comparing it to a woman? "If a woman is standing (high weld bead), and you want her to lay down (flatten the bead), you need to get her hot (turn up the heat).
    "Stick-man"
    Sep 2005
    Cave Creek AZ
    Set your voltage for material thickness being welded, then tune it with wire speed. It used to be a l lot easier with the tapped machines, as you had more limited voltage control, usually a tap every 2 volts. Now with better controls, it kind of muddies the waters on what to adjust. I generally just set the voltage, tune the wire speed, weld and look. Tune as needed.
    Los Angeles
    When you can snatch the welding rod from my hand , you have learned all that you can and it will time be to leave the temple
    MM211 (Sold)
    Miller 125c Plasma 120v
    Aug 2008
    Sudbury, Ontario
    grasshopper
    SA 200
    Idealarc TM 300 300
    MM 200
    MM 251
    30a Spoolgun
    Precision Tig 375
    Invertec V350 Pro
    Oxweld/Purox O/A
    ArcAir
    LN25
    Aug 2008
    Biggest reason I sold my MM212 and got a MM252. Didn't like Autoset or the tapped settings. I wanted the digital numbers to help understand what was going on.
    May 2010
    Port Orchard, WA.
    You wouldn't believe how many certified welders I've had work for me over the years who could not set their own machines. Had one certified welder tell me polarity means nothing, it is just a wife's tale.
    I've taken several tests when I walked into the test booth there was duct tape over the gauges. First part of the test was to set your machine within manufacturer's specs. If not, test over you go home right then and there.
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
