Can you identify this welder? Need the right connector...
Results 1 to 25 of 26
    May 2009
    Hello everyone! I'm new on the forum and just purchased my first welder. I've been using my brother's Lincoln AC225 welder for a while to fix things around the farm and to make reactive targets for our gun club. I found this machine locally and couldn't pass the price but I don't know what to use for the leads. The connections are slightly smaller than the Tweco connectors I have and don't appear to have a twist/lock built in.
    What I know:
    AC 220v welder, 50a plug
    25-295 amp continuous (high/low)
    It has a unique selector dial. You pull up on a rod to change the dial and push it down to lock the setting.
    Pictures:
    Thanks guys! I hope to be burning rod soon and will post pictures of my latest project...
    Nov 2007
    Re: Can you identify this welder? Need the right connector...
    yes it a welder
    May 2009
    Quote Originally Posted by ed mac View Post
    yes it a welder
    Sweet!
    My last one turned out to be a washing machine.
    JOEatleastthesteelwascleanSMITH
    Aug 2005
    Georgia on the GA/AL line
    Looks like a "solar" same as Century.. They made a 295 amp machine like that. The same connectors were used on the older miller dialarcs as well...
    Aug 2005
    Yeppers...
    Those be the ones. Dewayne's Roughneck, as well as the older Thunderbolts & AEAD 200 LE's also used them. I made up a set of pony leads with them for that once in awhile machine that I need to connect to my Load Bank.
    Fits the bill for me anyways!
    That is the same way I have my Dialarcs set up....
    May 2008
    Orange, TX
    Hammack pegged it. Those patent numbers reference Century Manufacturing.
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    May 2009
    Thanks guys! I'll try to swing by the local shop this weekend.
    May 2008
    Orange, TX
    I would figure you probably have one in your garage Duane......
    Not yet but I think they're breeding while I'm at work.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    May 2009
    Well I decided to clean up the rust on the case. Got out the sandpaper and spray paint. Well seeing as I can't leave well enough alone I now have it tore down, case is painted with some appliance epoxy, and I'm thinking what I want to do with the faceplate. It IS century, saw it through some of the rust. I think I am making out model 110-08, but that doesn't google and it's really hard to read through the rust.
    The transformer has a good bit of rust on it, is that going to hurt performance? I don't mind painting it if that won't make a difference. i have some hi-temp paint around here somewhere....
    Should be a good looking welder when I'm done with it.
    May 2008
    Orange, TX
    Quote Originally Posted by Joe Smith View Post
    NO PAINT! Holds in the heat. You can sand off some of the rust if you want to but it won't affect output performance the way it is.
    Looking forward to seeing some photos of the restored unit.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    May 2009
    Than here is a teaser. Top and bottom cases
    . The white is appliance epoxy (great stuff) and the black on the top is a non-skid paint. Should keep my box of rods in place if I move the unit a bit. Once everything cures I'm going to look into bolting some wheels on the bottom while I have the chance then it's back together.
    I don't know what to do with the faceplate. I want to clean up the rust but doing so means I lose all the info on there. I might just mask the important stuff (hi, low, ground) and make a new arrow for the amperage settings and cover it all in black but I don't know how well it will turn out.
    May 2008
    Orange, TX
    Looking good Joe.
    For that faceplate you could trace out a masking template of that white inset with the indication arrow and paint that area of the face plate white first and then the rest black with the masking template in place. For the lettering, get some appropriately sized individual stick on letters from a craft outlet to duplicate the component/function identifiers, instructions and machine identification. Or perhaps a stencil kit to make custom stencils to duplicate some or all of the lettering.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    May 2009
    Making progress......
    Used the selector dial and a bobbin as a spacer/roller to trace a template slighty larger than the dial. I did not include an indicator arrow, that will be a separate job that I am still working out.
    I used black primer than 2 coats of the non-skid paint that i used on the lid. I have no need for a non-skid faceplate but I like the texture better than the flat black. I also color coded the connectors to match the dial. This way I don't need the stinking high/low labels and makes for a cleaner look.
    Now I just have to put it back together. Eventually.
    May 2008
    Orange, TX
    Looking reeeeally good! Nice touch on the connector color coding.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    May 2009
    Just got it back together. Only two problems the whole time.
    1. I can't find the screws for the dial. It's holding fine but I'll have to swing by the hardware store and find some.
    2. I wired the fan to the wrong switch leads even though I noted where they went. Now as soon as it's plugged in the fan comes on. I might just keep it that way.
    Aside from some touch up this is it. However the dial looks really warn now. If I can get a new sticker for it I'll paint it with some fusion but otherwise it's what I got.
    Northern Cal., Shasta County
    Plain, simple and rugged/ What else could ya want?
    May 2009
    Columbus, OH
    The mitered case: Century
    May 2009
    I was very disappointed in my local welding shop. They did not have the connectors or any cable. They did have a good selection of rods and LOTS of tanks which is nice. So I just placed an order.
    2 connectors (lenco 10mp)
    1 crimp connector thingie
    27 feet #4 cable (25 for lead, 2 to fix craftsman welder http://weldingweb.com/showthread.php?t=30934)
    So I'll have to see how it works. Leaving for overseas next week and I want to try it out before then.
    May 2009
    Well, just got my order!
    And those are the wrong connectors They are too small.
    The LC 10-MP lists a taper size between .330 - .352 which is what my micrometer confirms. I think I need the UP 10-MP which is .364 - .385 and that means I won't be welding until I get back in a few weeks.
    Guys, thanks again for all the help. Without you I wouldn't have even been on the right track! I am putting the LC 10-MP's up for sale if anyone is interested.
    May 2008
    Orange, TX
    Keep these folks https://weldingsupply.securesites.co...wsecatalogs.pl in mind for stuff such as that. They have a very freindly return policy should you find you've ordered the incorrect item.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    It is a solar 295 amp. I know the thread is old. Solar was made by Century Mfg.
    Paul Butler
    Solar 250 amp ac/dc welder
    PowrKraft 230 amp ac welder converted to dc
    Lincoln 180 pro mig welder
    Miller 350
