Bench top bluing tank stands
Results 1 to 4 of 4
    Apr 2009
    Colorado
    I finally got around to welding this thing up. The stand holds 2 tanks, one for a hot cleaning solution and another for boiling water since I only do rust bluing here at the house. The tanks measure 40" x 6" x 6" The double burner was made up by a buddy and runs off of propane. One I get my garage re-arranged, I'll build a rolling table for the stand to sit on.
    I set of burners on under the stainless tank.
    Almost forgot, 1 1/4" by 1/8" angle iron with a Lincoln 100HD and .035" fluxcore.
    David
    Oct 2007
    Irvine, CA
    Re: Bench top bluing tank stands
    If you pipe in a bit of air you can get a cleaner flame. Otherwise that looks pretty great. Simple and effective.
    Apr 2009
    Colorado
    65535, the jets have a mixers built in to them. I need to adjust them a bit more. They work quite well and will boil four gallons of water in very short order.
    I had originally bolted the stand together but wanted to weld it in case I decide to run hot salts bluing through it instead of rust bluing.
    After I give it a coat of high temp black, it will be good to go.
    David
    Aug 2008
    Isn't it a real pleasure when everything turns out nice and square
    Looks good
    http://www.farmersamm.com/
