Weld a nut to a broken bolt
Results 1 to 12 of 12
    Feb 2007
    West By Golly Shelby NY
    My son says Its my answer to everything.
    2000 Cheby 5.3 V8 Aluminum heads. Last manifold broken off below the surface of the head.
    I used Alstate 275 at 71 amps I built a little tit on it, then another one,..... Till I could put a 3/8" nut on it. I welded the tit to the nut and took it out after it cooled. The one next to it only had the head broken off, so I took that one out too.
    Through this hole.
    My lucky day. I made good $ on it too.
    David
    Real world weldin.
    Feb 2007
    Moncton Nb Canada
    Re: Weld a nut to a broken bolt
    That there is pretty much the only reason my truck doesn't have headers.
    Here learning to turn down the Suck...
    Jun 2008
    Extreme Southern Louisiana
    Quote Originally Posted by Atomik777 View Post
    My '03 has STOCK exhaust and it also has a broken bolt. I am not going to mess with it til the gasket starts leaking (been 20k miles since I noticed it).
    David, if that truck has plastic inner fenders like mine the are fairly easy to remove.
    May 2009
    NY
    Glad you made some money on it. It used to be I wouldn't let a customer hang around while I did that repair. I used to sell the value, not the time. Good Job. My Kinda Job
    Lincoln Ranger 8 Lincoln 175 Drill press
    Lincoln 225 mig
    Plasma
    8 ft brake
    52" jump shear
    Aug 2008
    Dansville NY
    I have certainly done my share of those of heavy construction & farm equipment as well as cars & trucks! Some go easy and others!!!!!!
    Feb 2007
    The manifold was stock. The truck sits a lot. I gave him the price before the job. A regular auto shop would have taken off the head and probably exchanged it for a rebuilt.
    I would not do a job like that in front of a customer.... Ever...
    And sure there are days the floor is covered with nuts from failed attempts.
    David
    Real world weldin.
    Central West Virginia
    LOL yep some do some don't.. When I used stick rod for that I used tiny stainless rod.
    My most recent bolt in aluminum, weld a nut on it deal, was for a neighbor in one of those pesky lawn mower deck hubs. I didn't think the hub was worth removing the 2 broken bolts.
    Anyway welded on 2 nuts, Let it cool a bit then applied a bit of heat to the Ally hub. Got them to move slightly & gave it back to him. told him to soak them with penitrant & work them out slowly. also told him if you twist one off now, go buty a new hub. No Charge.....
    IF IT WORKS, DON'T FIX IT
    Linde-VI 253,400 & 450 w/MIG35 feeders
    CNC Table with Oxweld O/A & Hypertherm 1250G3
    Lincoln Ranger GXT 250
    Hobart-MicroWire 300
    ESAB Heliarc 161
    ESAB-Mobilemaster 2 CC/CV Feeders
    & more
    Jan 2009
    Ohio
    ive put a washer over a broken bolt and plug welded the washer to the bolt then welded a nut to the washer. that works very well too.
    Feb 2007
    Moncton Nb Canada
    Quote Originally Posted by David R View Post
    David
    Sorry, i'll clarify...Its because i figuire, with my luck, i'd snap ALL the bolts just trying to get the old maniforlds off...Long before i even got close to the headers .
    Feb 2007
    Quote Originally Posted by El_Lloydeo View Post
    Never tried that one, but I can see how it would be possible.
    Thanks for the tip.
    David
    Real world weldin.
    Jan 2009
    Ohio
    it just allows for more weld to be put around the nut. ive also taken oversized nuts and plug welded them to the broken bolt. let it cool good though before you get to crankin on it!
    If there is any stud or bolt extending out from the surface I always use a nut that will fit over the stud/bolt. Makes it easier to pour it on for best penitration.
    ESAB Heliarc 161
    & more
