Millermatic 35
Results 1 to 18 of 18
Thread: Millermatic 35
    Nov 2013
    Puyallup, WA
    Millermatic 35
    I recently aquired a Millermatic 35 (serial number HG043835). It doesn't feed wire when turned on and the trigger is pulled. I've downloaded the manual and gone throught he troubleshooting steps. I've also completed trouble shooting steps from posts I found on this site. I'm pretty confident CR1 is bad and the rest of the machine is functioning.
    The welder has the old open style CR1 and I can't seem to find a replacement model or kit that shows the conversion to a new closed sytle relay. Any information or suggestions would be appreciated.
Size:  29.1 KBName:  20131101 128.jpg
    Thanks,
    Todd
    Oct 2010
    Indianapolis Indiana
    Re: Millermatic 35
    I would think that contactor could be rebuilt, as long as the coil isnt broke....
    7A7 has a wonderful write up on how to rebuild the Maxtron 450 contactor.
    Miller Dynasty 200DX
    Miller Spectrum 250D
    Miller Millermatic 200
    Bunch of old blue dinosaurs....
    Nov 2013
    Puyallup, WA
    Re: Millermatic 35
    I like that idea. How do you test if the coil is still good?
    Oct 2010
    Re: Millermatic 35
    Should show resistance through the coil and not an open circuit (infinity).....
    I think.
    Nov 2013
    Puyallup, WA
    Re: Millermatic 35
    I checked and it has resistance. I'm searching the form for how to rebuild the contractor but haven't found it yet. Any ideas where I might find it?
    Thanks,
    Todd
    Nov 2013
    Puyallup, WA
    Re: Millermatic 35
    Thanks for the link! I'll take it apart and see how it goes. I'm sure there will be more to come in the next few days...
    Ceres, California
    Re: Millermatic 35
    You can order 122696 kit from miller or 109006 relay from miller. Adapt the wiring your self.
    The 122696 kit come with jumper wires, insulation, adapter plate. The thing to watch out for is. The wiring is different to the new relay. On the plastic box relay the top contacts are to normally closed. On the open frame they are the normally open. The moving contacts move in the opposite direction.
    May 2008
    Orange, TX
    Re: Millermatic 35
    Unless it has been updated to a "current" design, your MM35 may use the gun weld output lead as part of the trigger circuit so I would suggest unplugging the trigger leads from the 2-pin receptacle behind the side door and jumper the receptacle to see if the unit functions. If it does, you have a gun issue.
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Nov 2013
    Puyallup, WA
    Re: Millermatic 35
    I tried jumping it and no luck. I can see CR1 moving when I jumped it and when the trigger on the gun is pressed so I'm thinking that's the root of the problem.
    I'm going to try the other tests tonight. I'm guessing I have the original gun but I'm not sure (pics below). I don't see any gas but I haven't pulled the gun apart so maybe I missed it.
Size:  43.1 KBName:  003.jpg
Size:  60.3 KBName:  005.jpg
Size:  52.1 KBName:  006.jpg
    Thanks for all the help!!!
    Todd
    Nov 2013
    Puyallup, WA
    Re: Millermatic 35
    Cleaned contacts on CR1 and now the contractor closes when the trigger is pulled. Took apart the contractor and cleaned the contacts and have power to the bottom side of it. wire feed and welder still not functioning so back to the trouble shooting section...
    Ceres, California
    Re: Millermatic 35
    To get wire drive . you need to see a couple of things. First you need weld voltage at the gun. Second Circuit breaker #1 needs to be closed. This will apply power to a small bridge diode thgat supplies the DC power to the motor. Power to the motor is controlled be the setting of the yellow jacks and the speed control rheostat. Rheostat can be cleaned. Next check for a jumper plug up near the space above the rheostat. Your might not have it, It is for the spot weld timer pcb.
    If you have this plug make sure the contact are clean and tight. The cr1 relay has two sides. One side is for the motor and the other is just the contactor control.
    Depending on age of welder, the older ones had motors with fields and the newer one have
    magnets. CB2 is in the field control. If I had the first part of the serial number I could look at the right diagram . Looks like you have the miller gun that came with the welder.
    Should be able to get a gas valve and gun adapter and use a newer miggun.
    If you have the gun I think you have, the gas valve is in the handle on the gun.
    May 2008
    Orange, TX
    Re: Millermatic 35
    As ccawgc has pointed out, circuit breakers CB1 and CB2 need to be closed and passing current in order for the motor to work as well as having weld output voltage between the work clamp and transformer tap outlets.
    Other things to check are both bridge rectifiers SR2 and SR3, motor field windings (brown and white wires) on wires #33 and #34 and if there is motor drive voltage at the black and red motor leads (wires #47 and #48 respectively) when CR1 is activated.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Nov 2013
    Puyallup, WA
    Re: Millermatic 35
    First I'd like to thank everyone for the input and help! I did some more testing. I have power on both sides of CB1 and CB2. I checked wires 33 and 34 and they have power. I checked 47 and 48 with CR1 engaged and nothing. I'm thinking this means SR3 is bad. Correct?
    I pulled apart the gun and I have power. Not sure what else to check here. CR1 engages when I press the trigger as well.
    What would you guys check next?
    Thanks,
    Todd
    May 2008
    Orange, TX
    Re: Millermatic 35
    If we're both looking at the same diagram, #47 & 48 receive DC power thru SR2, CR1 and WFS rheostat R1. However, SR2 receives AC power from the main contactor W so you need to check for power thru the main contactor first. Do you have OCV between the gun tip and work clamp? If yes, main contactor W is OK.
    Potential failure points are:
    1) Main contactor W contacts bad
    2) Bridge rectifier SR2 failed
    3) CR1 contacts for wires# 50 & 47 bad
    4) CR1 contacts for motor braking wires# 47 & 53 stuck closed (arc welded)
    5) WFS rheostat R1 failed
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Nov 2013
    Puyallup, WA
    Re: Millermatic 35
    Contact on wire 50 wasn't working. All fixed! Thanks for the help!!!
