What filler for cracked clothes dryer drum
Results 1 to 25 of 28
    Nov 2011
    SoCal
    I have an LG front load clothes dryer that has the common cracked drum weld seam. I took it apart a few years ang and welded it back up with my little MIG, but it developed another crack. The plan this time is to repair with my 200DX, but I am not sure what the best filler would be???
    The drum is stainless, but I do not know what kind. I was planning on picking up some small (.030) 308 or 309 today.
    Any suggestions?
    Oct 2013
    Belgium, Europe
    Re: What filler for cracked clothes dryer drum
    are you sure you have a stainless drum? most drums over here (in Europe) are carbon steel that are either electrolytically galvanized or have another coating, but are not solid stainless steel.
    If stainless, I'd guess it will be 316 so I would use 316L rod.
    Nov 2011
    SoCal
    It is stainless. I'll call around and find some small 316L rod.
    I will be replacing the drum as soon as I can get the money together for a new one. Until then I can't have this thing tearing up all of our clothes.
    Oct 2010
    Indianapolis Indiana
    When in doubt 309 it out....
    Miller Dynasty 200DX
    Miller Spectrum 250D
    Miller Millermatic 200
    Bunch of old blue dinosaurs....
    Oct 2013
    Belgium, Europe
    I'd put my money on 316L, for what it's worth... btw, that's only $0.02 :-)
    Nov 2013
    New York
    If it is indeed a stainless drum, I highly doubt it's 316L
    T309 filler should be just fine.
    Trailblazer 251
    Dynasty 200DX
    Suitcase Xtreme 12vs
    Carolina HV-12
    Old Delta drill press
    Victor and (old) Craftsman torches
    Mobile work out of a trailer
    ... Still acquiring my fabrication arsenal.
    Feb 2012
    S.E. Mi
    just use 7018 and polish it down if it looks like it might hang up your clothes
    Nov 2011
    SoCal
    I picked up a pound of .035, 309L and got it done. It was hard to go over where I had previously MIG'd it. I won't make that mistake again.
    Long Island
    The LG drum sure is stainless but it sure is not 316. It's magnetic. Probably 400 series, which is why it cracks.
    The real issue is that the drum rollers soften when hot. Then when the drum cools, they get a flat spot as rollers harden. Now when the machine is started, they thump until they warm up. That thumping causes the cracks. Probably from work hardening.
    What you need to do is be sure to set the wrinkle control on every load. Then make sure you do not open the door for several hours after it is done, or pause the cycle before you open the door, then resume it when you close it so the "marching ants" stay on the display. The wrinkle control turns the machine occasionally as it cools, so the rollers don't get flat spots.
    Nov 2011
    SoCal
    Thank you for the tip.
    Do they make better rollers, and should I change them when I get the new drum?
    Jan 2006
    309L is the filler for all unknown steel alloys, stainless or not. Otherwise sil-brazev(45, 50, or 56%) or silicon bronze are also good choices.
    Mar 2013
    Desert
    Quote Originally Posted by rlitman View Post
    Screw all that! You just convinced me to NEVER buy LG. I'll stick to my 7 year old Kenmore. We abuse the crap out of that machine. Slamming the door, opening it mid-cycle to remove cloths or add more wet cloths etc.... No cracks so far.
    Nov 2012
    South Texas
    I think you're supposed to use coat hanger wire for that.
    Long Island
    Quote Originally Posted by CHIEF View Post
    I do not know. Anecdotally, I have read plenty accounts of people getting drums and rollers replaced, and the thumping returns. If I were you, I would look into it, but AFAIK they do not have an upgraded roller that doesn't get a flat spot when a hot drum is left to stop on it. I'd considered making better rollers myself, but religiously using the "wrinkle care" cycle has completely stopped the thumping, so I have been problem free. A friend with a similar dryer didn't, and ended up with a cracked drum like you.
    The sad part is that LG made the claim that their dryer was the quietest in the business, because of their soft rollers that silenced the drum. But those same rollers are their downfall.
    My last response was on my phone. At a real keyboard, I can take a sec and spell out the wrinkle care setting a little better for those with the issue:
    Wrinkle care is a cycle that lasts a few hours after the drying cycle. It turns the drum a few times, every few minutes, to tumble the clothes to prevent wrinkles. Doing that also keeps the warm drum from sitting on a roller in a particular orientation for too long.
    Press the wrinkle care button so it lights up, and after the cycle ends, the "marching ants" show up on the display. And every few minutes it will do a tumble.
    Now here's the catch. If you open the door when the machine just finished, it cancels the wrinkle care cycle, because it assumes you took the clothing out.
    So what you need to do is press the pause button before you open the door. Then press it again when you close the door, so the wrinkle care cycle is allowed to finish its course. Once everything is fully cool, the rollers are hard enough to not get a flat spot, so you're good to go from then, and the next cycle, there will be no thumping.
    Quote Originally Posted by MoonshineMetals View Post
    Yeah, none of that would hurt the LG. The issue is a design flaw that is well known, but LG adamantly denies it, and gives customers complaining of the problem the runaround until the warranty runs out. Then sells them a $300+ drum (and way more for the total repair bill), that doesn't set it straight anyway.
    That's the reason I would not recommend an LG dryer to anyone. Even if I'm ok with mine, now that I've got a handle on the problem.
    BTW, for those not familiar with the issue, when the hot drum sits on the rollers and they cool with a flat spot, for the first 10 minutes or so of the next cycle as it heats up, the machine sounds like someone is pounding on it with a deadblow hammer about twice a second. That's what I mean by thumping. And that is what eventually causes the drum to crack. Why there hasn't been a class action lawsuit over this yet considering how LG has treated their customers, is beyond me.
    Nov 2011
    SoCal
    Thanks for the explanation rlitman. More all I have to do is get a new drum and train the wife on the wrinkle care setting.
    Any suggestions on where to get a new drum?
    Long Island
    Sorry, no idea. The last time I dealt with the issue was in 2009.
    I just googled it, and it looks like LG recalled cracked drums. Apparently they're replacing the cracked drum for free, but not covering labor.
    What I found says:
    "You can call LG customer service at 1 800 243 0000 for more info."
    Oct 2010
    western kentucky
    I bet the drum is 304, and got magnetic when it was cold formed..
    Long Island
    Quote Originally Posted by brucer View Post
    Nah, nothing is really formed on it, except perhaps the dimples. It is a sheet that is rolled into a cylinder, with an end cap welded on. I cannot imagine they used 304, when 400 alloys are available for so much less money.
    Long Island
    It's an old thread, but I have a new update. When my wife discovered Sunday that a piece of clothing got caught in my dryer drum, I found a crack on the welded seam near the back of the machine. Every time that part would pass a roller, the metal would flex a little and do a scissoring action. That was with an empty drum, and I'm sure that with a full load of wet clothing, it was much worse.
    Anyway, following my own advice (after pricing a drum on Amazon for $200), I called the 800 number for LG that I posted above, not expecting much help.
    They said my drum was covered for 10 years, and were providing replacement parts and labor for free (I will have had the machine for 10 years at the end of November). Their repair scheduling computer was down, so I had to call back on Monday. Well, the replacement drum arrived yesterday, and the tech finished replacing the drum a few minutes ago.
    Way to go LG for making good on this!
    While he had it open, I took some time to give it a good vacuuming, and check the rollers and belt (all still fine).
    The new drum has the same part number, but is has a Q suffix instead of a C. It seems quite a bit thicker.
    The old drum was left for me. Woo-hoo, free stainless! I'm thinking of improving my chiminea, but don't have set plans for it yet...
    As I unscrewed the plastic paddles from the old drum, inside I made an unexpected discovery. Lint pearls. Little perfect spheres of lint had formed.
    Feb 2011
    Martinez CA
    Try this, I hear it never has any problems....
    http://craftypeople.files.wordpress....shing-line.jpg
    Miller Dynasty 350
    Twenty Six Hammers
    Three Crow Bars
    Big Rock
    May 2010
    Sparks, NV
    They make great firepits.
    AHP200x; AHP 160ST; MM350P, Spoolmatic 30A; Everlast PowerTig 185; ESAB 875 plasma;Evo 355. OA
    Long Island
    Washer drums do since they're perforated, though you need to fill the hole where the hub was. The last time I had a washer die, I did this by adding some feet and using a drain grid in the middle.
    Dryer drums, not so much. They're solid hoops that are open on both ends.
    As for LG dryers, they're now good in my book. I happened to check one in a showroom yesterday, and it seems that all the new ones have the thicker/improved drum now. I guess they've gotten past this issue and with the new drum, it is really quiet and smooth running now. After it cracked, it sounded like there was a shoe tumbling around in there.
    Jan 2008
    Richmond, Virginia
    What crack filler? Orphaned socks, obviously. It also reduces the amount of potential belly-button lint in the atmosphere.
    I didn't mind fixing the rub pads and main bearing in my ancient dryer a couple years ago. But putting brake pads in the top-loading washing machine was a real bitch. I had to do a Harry Houdini trick to even get in under the tub with tools. Thought I wouldn't be able to get up off the floor when it was done.
    Syncrowave 250 w/ Coolmate 3
    Dialarc 250, Idealarc 250
    SP-175 +
    Lincwelder AC180C (1952)
    Victor & Smith O/A torches
    Miller spot welder
    Oct 2010
    Pics of lint pearls
    Long Island
