Circle cutting with oxy acetylene
Results 1 to 21 of 21
    Jun 2013
    Euroa australia
    Hi I've guys I've been oxy cutting for a year now and have never had to cut a circle. Tonight I had to for my BBQ project. When I did it the molten slag would come behind the hole I cut the way round not causing it to cut all the way through. Just wondering if anyone has any tips to help me. Thanks in advance
    1 270 wia weldmatic mig welder
    1 Abel arc welder
    1 188 bossweld arc and tig welder
    1 cigweld comet o/a set
    Costa Rica
    Re: Circle cutting with oxy acetylene
    How big is the circle and how thick is the material ?
    Bubble gum
    Tooth pix
    Duct tape
    Black glue
    GBMF hammer
    Screw gun --bad battery (see above)
    Costa Rica
    Bubble gum
    Tooth pix
    Duct tape
    Black glue
    GBMF hammer
    May 2010
    Port Orchard, WA.
    Burning is burning, doesn't matter what direction you're going, flat, over head, it doesn't matter. I think your travel speed was to fast, or your tip to small.
    Here are some tools that really help to make nice circle cuts.
    Don’t pay any attention to me
    I’m just a hobbyist!
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Nov 2006
    Wilmington, De
    In the 70's my former employer purchased a torch with a motorized head. You set the size, then fired it up, and let it do it's thing. You didn't have to follow the torch and drag the hoses in a circle. You held the torch steady and let it cut.
    Apr 2012
    Flat lands of Colorado, where the wind blows
    my version
    May 2013
    Virginia
    When I cut a circle, if it's 2" or less, I draw it out, then start in the center and circle the torch around, pretty much burning away everything on the inside until I get to the actual lines.
    If it's a little bigger, I still start in the center, then move over to just inside of my line and trace it around. Die grinder to the inside edges and a file to finish.
    I've been meaning to put together a guide of some sort but I hardly ever cut circles anyway.
    Jul 2012
    San Marcos TX
    Here is a pretty cheap tool made for this, I dont have one I just saw this and bookmarked for later.http://jcaent.com/Page_2.html
    Costa Rica
    . I made a Lazy Susa...Ok, a Lazy Doug that I rigged up. The torch sits in a saddle(3/4 angle welded on a stick of 3/16 x 1). That gets held to the table w/a welding magnet. Fire it up/adjust. Hold it in the saddle, pull the trigger and turn the work piece on the Lazy Sus.....Doug.
    Little crap I just drill some holes and then freehand or use pieces of cut off tube-pipe or old drops.
    Bubble gum
    Tooth pix
    Duct tape
    Black glue
    GBMF hammer
    Costa Rica
    Farmboy that rig looks good. QuickNeasy !
    Bubble gum
    Tooth pix
    Duct tape
    Black glue
    GBMF hammer
    Oct 2007
    Hendersonville, Tn.
    I'm with akabadnews about having to cut out all of the circle if it's a small hole I'm trying to get. On the other hand, if it is a small disc I am trying to cut out, I generally have to start further out from the actual desired diameter laid out for the disc, and make a large kerf, or even cut it twice sometimes. It seems that the trouble comes from the fact that all the cutting is being done in a small area, so the heat builds up quickly and that tends to keep the kerf zone too hot, and so the slag remains molten and fuses back into the kerf slit.
    But if you are not even cutting completely through the thickness of the material, then either your torch tip is too small or you are moving too fast (insufficient preheat time). If it comes down to insufficient preheat time, you can use the old timers trick of running a few circular passes around your marked circle to heat up the material before you actually start cutting a kerf.
    May 2013
    Virginia
    Invest in a plasma cutter too.
    Jun 2013
    Euroa australia
    The circle has a 10cm diameter an it is 1/8 inch material
    Jun 2013
    Euroa australia
    My tip is a number 8 the second smallest tip you can get in australia. I have the next size up as well
    Jun 2007
    You could have been going too slow too.
    Nothing Ever Got Done By Quitting, Never Give Up.
    I like to drill a small hole 1-8 or 3-16 right on the cut line then go from that point. It really helps on heavier plate,{over 1 inch thick } to get the cut going without blowback.
    May 2010
    Democratic People's Republic of North Koreafornia
    Quote Originally Posted by Grtpain View Post
    I bought this JCA circle cutter and I have to say, keep your money! It's poorly made and the fittings or attached components are extremely loose. This in turn makes the tool cut a very sloppy and crooked circle. I was thoroughly disappointed with this tool.
    Lincoln Power Mig 216
    Lincoln AC/DC-225/125
    Miller 625 X-Treme Plasma
    Forney 95FI-A 301
    Victor Journeyman O/P
    Milwaukee
    Dayton
    Makita
    Baileigh
    NRA Life Member
    GOLF
    Sep 2006
    Marlborough, The Peoples Republik of MA
    This is how I do it
    Nov 2013
    Thanks tozzi for your input. I've learn so much from this subject and your pics. Thanks again.
    Oct 2007
    New Hampshire
    Here is a link to a cool motorized oxy-fuel torch with circle cutting capability from Koike Aronson. They used to make one similar to this for a plasma torch...although they discontinued that one.
    Link to video: http://www.koike.com/portable-soluti...auto-plus.aspx
    Jim Colt
    Mar 2008
    Georgetown, Texas
    That's pretty cool but I didn't see a price Jim. Have any idea how much it is?
