Best way to fix this
Results 1 to 14 of 14
    Nov 2013
    MO
    I got a little too rambunctious with the FEL. It looks like maybe there was poor fusion and the weld popped loose between the cutting edges.
    My current plan is to:
    - Grind the old welds as best I can.
    - Clean everything good.
    - Force the bucket down on a log or some timbers to improve fitup.
    - Run a 6010 or 6011 root down both sides.
    - Cap with a few passes of 7018.
    Sound good?
    May 2010
    Port Orchard, WA.
    Re: Best way to fix this
    Quote Originally Posted by Wolfman View Post
    Sound good?
    That's what I'd do.
    Don’t pay any attention to me
    I’m just a hobbyist!
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Mar 2007
    I would weld it all with 7018 but you your on the right track
    Jun 2008
    Sounds like a plan to me using 7018. I've done a few loader buckets and the same place on yours I've added a piece of angle to reinforce it....Mike
    Mar 2007
    Quote Originally Posted by mrmikey View Post
    I have done that too but I found it can be a pain to get the angle on there just right
    Sep 2006
    Marlborough, The Peoples Republik of MA
    NS3-M and set the machine to nuclear........
    May 2010
    Port Orchard, WA.
    Quote Originally Posted by TozziWelding View Post
    .120"?_____
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Aug 2007
    yep good to go. clean it, bevel it a little if you can- 6010 root pass either 3/32 or 1/8 and triple pass 7018- shouldn't take ya more than 20 minutes
    Nov 2013
    MO
    Quote Originally Posted by Osirus View Post
    Except I don't own a welder and haven't touched one in over 10 years.
    I will be rectifying that soon.
    Apr 2010
    You got it
    What would SATAN do ??
    Miller Trailblazer 302 AirPak
    Miller Digital Elite
    Optrel Welding Hat
    Arcair K4000
    Suitcase 12RC / 12 VS
    Hypertherm PM-45
    Rage 3 saw
    Rusty old Truck
    west texas
    Maybe finish it off with some hard face rod on the leading edge.
    old Miller spectrum 625
    Lincoln SP-135 T, CO2+0.025 wire
    Craftsman 230amp AC/DC and WP-18V torch
    Craftsman 100amp AC/DC and WP-17V torch
    Century 115-004 HF arc stabilizer
    Home made 4 transformer spot welder
    Home made alternator welder
    Nov 2013
    Clean it bevel it, wrap a chain come-a-long around it and weld with 7018 . That's my 2 cents
    Miller trailblazer301g
    Lincoln sa200
    Miller251
    Miller spectrum 625
    Victor oxy-acc
    2002 Chevy duramax 3500 dually 4x4
    Nov 2013
    Iowa, USA
    Clean, bevel , and weld multiple passes 7018 sounds good started with stick now if I could get it inside the shop I would probably wire weld it . Just because wire is easier.
    Good luck
    I fixed a bucket like this cracked multiple places in the center worked ok until I quit using it.
