Show us what you welded today! - Page 297
Page 297 of 350 FirstFirst ... 197247287295296297298299307347 ... LastLast
Results 7,401 to 7,425 of 8739
  1. #7401
    Oct 2016
    Durham, NC
    Re: Show us what you welded today!
    Quote Originally Posted by Bls repair View Post
    Dot ,what will be the weight of the trailer with a full tank of water. Looks good.
    I have no idea. The customer wanted it in the back but we talked him out of that for safety reasons.
  2. #7402
    Mar 2017
    Some cable rails on the beach.
    Sent from my SCH-I545 using Tapatalk
  3. #7403
    First attempt at pipe. 6g position 6" sch 80 x 2" with a 37-1/2 degree bevel. This is the hot pass using 3/32 7018 at 95 amps.
    I play with sticks
  4. #7404
    Jul 2014
    That pipe being only 2" wide will heat up quick
  5. #7405
    Ontario, Canada
    Built this little hand which stacker so I don't have to struggle lifting my 250lb press brake in and out of my shop press anymore.
    Lincoln 210 MP
    Miller Spectrum 375 X-treme Plasma
    Craftex CX600 Mill (Grizzly G0604)
    King Industrial Swivel Head Band Saw
    Welding Table Build.
    http://weldingweb.com/showthread.php...%29&highlight=
  6. #7406
    Colorado Springs
    Quote Originally Posted by f150skidoo View Post
    What material did you use? I could use something like this for lifting my tool boxes.
    Sent from my XT1635-01 using Tapatalk
    Lincoln 175
    Monkey Wards 230v. Stick
  7. #7407
    Dec 2015
    Hey,
    Those handrails look great in a modern, minimalist way. I bet the house looks good too!
    I see that this is your first post, and this thread is a great place for that!
    Welcome to the forum here!
    Quote Originally Posted by Warren.howell View Post
    Peace to you all,
    Christian Livingstone
    www.youtube.com/newjerusalemtimes
    Everlast 210EXT AC/DC (2015)
    CAT250D 200 amp DC TIG/Stick/Plasma
  8. #7408
    Ontario, Canada
    Quote Originally Posted by HotRodTroy View Post
    The mast is 1.5"×2.5" .188" tube, the rest Is just off cuts of tube I had laying around. I had some 11 gauge sheet metal that I used to make the top pulley cross bar and also used the sheet metal for the forks.
    Lincoln 210 MP
  9. #7409
    Colorado Springs
    Thanks.
    Lincoln 175
  10. #7410
    Sep 2009
    Sedona, Arizona
    Looks awesome!! Welcome to Welding Web. Your welds look great. Are the vertical posts open at the bottom to let rainwater drain out as I am sure a 1/4" or more of water will collect in them from entering into the holes
    Millers
    Demmeler D28 1500x3000
    Cincinnati 1/4x10 shear
    Dodge 3500 4x4 DRW w/ a very tired 370K
  11. #7411
    Mar 2017
    Quote Originally Posted by Jimmy_pop View Post
    They are side mounted with holes drilled for drainage. That's hard anodized aluminum.
  12. #7412
    Mar 2017
  13. #7413
    Sep 2009
    Sedona, Arizona
    Thats awesome. Very refreshing to see well designed and executed fabrication.
  14. #7414
    Nov 2012
    South Texas
  15. #7415
    Apr 2016
    CA
    Quote Originally Posted by vwguy3 View Post
    The backwards ag tire caught my eye.
    The guys on RedSquare(WH forum) would like it.
    Finally got around to posting it over there.
    '65 Lincoln Idealarc 250 AC/DC
    ESAB REBEL EMP 215ic
    L-tec PCM-VPi 40A plasma
    Victor Performer O/A
    Lincoln Viking 4C 3350
  16. #7416
    SoCal-LA
    Nine of these little bastard steel prefab pyrotechnic buildings(condos we call them). All collapsible onto the floor section for transport and airlift. Hopefully tomorrow they will pick up the last three sets.
    Miller Dynasty700DX, Dynasty350DX 2ea., Dynasty200DX, ThermalArc 400 GTSW, LincolnSW200 2ea., MillerMatic350P, MillerMatic200 with spoolgun, MKCobraMig260, Lincoln SP-170T,PlasmaCam/Hypertherm 1250
  17. #7417
    SoCal-LA
    Beautiful shiny work man!
  18. #7418
    Aug 2016
    Starting the rear while I wait for lighting.
    Mark with a torch, cut with a hammer.
  19. #7419
    Nov 2012
    Land of the free, because of the brave!
    Flying pull-up bar
    Gar
    Lincoln Electric, Power MIG 256
    Hypertherm Powermax 45
    Miller Dynasty 280DX
    Smith O/A torch
    Genesis of a welding table
  20. #7420
    Mar 2015
    South Africa, KwaZulu-Natal.
    Quote Originally Posted by Dotmatriks View Post
    Here's why Dot etal. talked him out of it. I just think it's interesting and a worthy safety reminder. :
    Likes long walks in the dark & late nights by the fire with a good whine. Down to earth and easy flowing. Polished appearance. Into lots of pre-heating & satisfying the puddle. Seeks firey weld with long legs, overlapping toes, and small ripples.
  21. #7421
    Ct
    Quote Originally Posted by Gar View Post
    Flying pull-up bar
    Gar
    For doing flying pull ups?
    Demonstration please
  22. #7422
    Oct 2016
    Durham, NC
    20ga corners suck. They suck so bad.
    Don't worry, I'm a welder.
  23. #7423
    Oct 2016
    Durham, NC
    Quote Originally Posted by Reseda luteola View Post
    That is exactly right. If the customer got his way, we would have built him an accident guaranteed to happen. That is some serious bad juju.
  24. #7424
    Nov 2012
    Father/ son project. "Sitting bench" made from scrap iron, an old snowboard, and several old skateboards. Actually quite comfortable and sturdy.
    Chain is the only support for back rest.
    Snowboard is secured using (8) bolts that pass through bottom tube into snowboard binding holes.
    Used self tappers to secure skateboard back rest tube.
    Gar
    Tac welded some angle to hold back rest in place for welding chain.
    Welded some chain together, then welded it to bench to support back rest.
    Finished project.
    Smith O/A torch
  25. #7425
    Jan 2012
    West Rutland, Vermont
    Nice.
