Show us what you welded today! - Page 345
Page 345 of 350 FirstFirst ... 245295335343344345346347 ... LastLast
Results 8,601 to 8,625 of 8739
  1. #8601
    Re: Show us what you welded today!
    While not today, I have recently made my welding table. 1" plate top and salvage yard I-beams for the frame. I am installing the lifting mechanism for the casters shortly when I receive my last caster - single lever for the lifting action. Leveling feet will be added at the same time. There are 2 pull out trailer hitch tooling mounts on one end of the table.
    Maxstar 150 STH
    Victor OA
    California Sunshine
    In case of doubt, speak loudly. Vlado Lubarda
  2. #8602
    Mar 2014
    It does make it rougher. Even though I do not have the skill of 5th Street or Dot, I think that may be part of what gives the welds part of their appearance.
    Using a fresh tungsten, wiping with acetone and then using the stainless wire brush to prep, I still end up with a less than ideal looking weld. I get better looking welds at home on 100% Argon.
    These items are going to be sand blasted and then painted to slow the time for corrosion since they will be on a boat.
    I have mentioned it before, but we had 8 bottles of medical grade helium several years ago. I initially tried to return some of them for credit on our account but the store would not accept them, even with the shrink wrap still on the valve. I am now down to a little over 4 bottles.
    My finance people have asked in the past why we are paying lease fees on all these tanks. I only use one bottle of HE or so a year. I still have one full sized bottle of O2 I need to use up but rarely use Oxy-acetylene at work.
    I may break out the Broco cutting torch and play with it in the future just to have some fun and use some O2.
    Pat,
    One more flow meter and a Y-connector and you can easily have a "poor-mans" gas mixing set up so you can play around with different He/Ar mixes for various aluminum welding situations. I think it'd go a long way to helping you out for the kinds of things I see you welding.
    Name:  10 16 11 004.jpg
  3. #8603
    Jan 2014
    Hallieford, VA
    Quote Originally Posted by zolimark View Post
    Good looking table. Welcome from VA.
    Jerry
    30+ yrs Army Infantry & Field Artillery, 24 yrs ago
    Miller 350LX Tig Runner
    TA 210, spool gun
    Lincoln 250/250 IdealArc
    ESAB PCM 500i Plasma
    Kazoo 30" vert BS
    Kazoo 9x16 horiz BS
    Clausing 12x24 lathe
    20T Air Press
  4. #8604
    Fredericksburg, VA
    HT2, another flow meter and "Y" is in my list of things to get for work. In the interim, I may try to do some partial pressure blending of my own.
    Millermatic 252 MIG
    Miller Dynasty 200DX TIG
    Miller Spectrum 375 Plasma
    Altas 12x36 Metal Lathe
    Bridgeport Milling Machine
    www.psacustomcreations.com
  5. #8605
    Oct 2016
    Durham, NC
    I think I'm in the right thread now! Thanks HT2!
    Made a security cover for the access ladder. 8ft tall, 20" wide. Welded end caps in.
    It's a job-shop life.
  6. #8606
    Welded on the lever arm for my weld table lift - times two.
    Maxstar 150 STH
    Victor OA
    California Sunshine
  7. #8607
    Final pics of my fly press stand before going out for powder coat.
    Maxstar 150 STH
    Victor OA
    California Sunshine
  8. #8608
    Aug 2016
    Sutherlin Oregon
    I didn't get to build much these last 2 weeks but I did get some pics
    Sent from my SM-G920V using Tapatalk
  9. #8609
    Aug 2016
    Sutherlin Oregon
    The last picture is how bad the smoke here has been for the last couple weeks.
  10. #8610
    Feb 2005
    Louisiana
    As usual, your work looks great, 5th Street Fab!
  11. #8611
    Nov 2014
    Nice work man. Wish I could work there and get as good as your getting!im 20 miles north of the fire right along the Columbia. Luckily that river is in between.
  12. #8612
    Nov 2012
    new york city
    this is my latest project. carte' blanche on overtime. a few year's ago the prison laundry got 3 new machines. i built a base for the biggest washer using plans supplied by the manufacturer. fast forward to last week when out of the blue the laundry officer discovers the remaining machines are shifting on their concrete pads.
    these are built from 4" H beams and will be through bolted with 6" fish plates and 1" threaded rods at each corner. welded with 7018 straight from the oven.
    i.u.o.e. # 15
    queens, ny and sunny fla
  13. #8613
    MS
    Quote Originally Posted by 5th Street Fab View Post
    What do you get to do when you are not building stuff?
    The only constant in life is that there are never enough chains
    The only constant in life is there is never enough chains
  14. #8614
    Jun 2016
    Not there
    Fish smoker....... Have to do the rack, fire bricks, water pan and smoke chip box this afternoon. Needs cord hangers and a nice door latch.No thermometer. I'll run it several days, oil season the inside and make a dial of actual temps.
    Fish racks but also hangers in case he gets wild and wants do do ribs or hams or...... 70 to 165 F in 3-4 minutes on 110.
    175 C(350) as fast, but on 220 .
    The thermostat is horizontal and the burners click back and forth/left to right to keep it even if the door is opened.
    1 1/2 insulated throughout. Double wall 16. The castors suck but it will seldom get moved.
  15. #8615
    Backyard heater for cool fall nights. Added flame slots today. Super clean burning no smoke to speak of.
    Sent from my SCH-I605 using Tapatalk
  16. #8616
    Nov 2014
    Is this unit going inside a coverd patio area? Seems like it would need to be indoor to be effective. Welcome to the forum btw
  17. #8617
    No it sets outside and the heat it put off is much more than a open campfire,no smoke in your face and burns incredibly complete without messing the fire at all. The three vents at the base make for a very good draw.
    Sent from my SM-T670 using Tapatalk
  18. #8618
    Jan 2016
    Quote Originally Posted by dakota3717 View Post
    those look very nice. almost a rocket stove type set up...I like that the flame and embers are kept inside the unit and the warming rack on top...what kind of tank did you use?
  19. #8619
    80gallon compressor tank.
  20. #8620
    Flames were a good addition.
  21. #8621
    Feb 2005
    Louisiana
    Looks nice!
  22. #8622
    Jul 2014
    Quote Originally Posted by docwelder View Post
    it's hard to believe they are 4" beams they look so much bigger in the picture ,I guess it is true the camera does add 6"to a womens BUTT
  23. #8623
    Nov 2012
    new york city
    Quote Originally Posted by gxbxc View Post
    it's just a 13 pound 4" h beam. any bigger and i wouldn't be able to lift it
    i.u.o.e. # 15
  24. #8624
    Nov 2014
Size:  69.7 KBhad to redesign and reweld this. It was vibrating a lot and fell off lolName:  IMG_5572.jpg
Size:  68.6 KBName:  IMG_5574.jpg
Size:  67.0 KBits got a big gap because this is the only piece of metal I could find. Gona drill it out another 16th and use 3/8 npt then rubber hose
  25. #8625
    Nov 2014
