Show us what you welded today! - Page 346
Page 346 of 384 FirstFirst ... 246296336344345346347348356 ... LastLast
Results 8,626 to 8,650 of 9590
  1. #8626
    Mount Tabor VT
    Re: Show us what you welded today!
    Quote Originally Posted by gxbxc View Post
    it's hard to believe they are 4" beams they look so much bigger in the picture ,I guess it is true the camera does add 6"to a womens BUTT
    If you can't tell those I beams from a woman's butt. they may need to add a color to the flag, and a letter to the GLBTU pride flag.
    Sorry, I couldn't stop myself.
    Willie
  2. #8627
    Nov 2014
    PDX Pacific NW
    Quote Originally Posted by That Guy There View Post
    Moto: seems like the first weld had no penetration?
    How do U come up with that? The weld took the base metal with it, meaning good penetration. If there were no pen u would be able to see the bottom of the weld.
  3. #8628
    Mar 2014
    Attachment 1720191had to redesign and reweld this. It was vibrating a lot and fell off lolAttachment 1720201Attachment 1720211its got a big gap because this is the only piece of metal I could find. Gona drill it out another 16th and use 3/8 npt then rubber hose
    Clearly, that needs to be re-padded and gusseted.
  4. #8629
    Nov 2014
    PDX Pacific NW
    Quote Originally Posted by HT2-4956 View Post
    There wasn't much room to put a gusset. I should have tried supporting the tube further down the end but never did. Just Gina run it like this then a rubber hose this time if I want it to lube my chain again. Should be plenty good like this,
  5. #8630
    Nov 2014
    PDX Pacific NW
    Ran a tank through it today and seems to seal good this way. I've been spraying Pam on the chain latley. Name:  IMG_5583.jpg
Size:  66.7 KBName:  IMG_5584.jpg
  6. #8631
    CT
    We need to make a new thread named "show us what you welded a couple days ago"
    Anyway here's something I welded a couple days ago, it's a claw for an excavator
    Sent from my SM-J327T using Tapatalk
  7. #8632
    Sep 2011
    Jasper TX
    Pat,
    One more flow meter and a Y-connector and you can easily have a "poor-mans" gas mixing set up so you can play around with different He/Ar mixes for various aluminum welding situations. I think it'd go a long way to helping you out for the kinds of things I see you welding.
    Attachment 1718371
    What causes the gases to mix? Seems to me that the bottle with the highest pressure is the only gas that's going to flow? Am I missing something?
  8. #8633
    Mar 2014
    Quote Originally Posted by Fast Leroy View Post
    Leroy,
    The first stage of a flow meter drops "tank pressure" down to some smaller set psi value (I'm guessing in the 30 to 40 psi range) before it gets to the tube portion where you fiddle with the knob to set "flow". Tank pressure and flow are two different things. Where the two gases come together at the "Y" they're both basically at the same "pressure" just at a different "volume" (flow). From there just the turbulence in side the hose until it comes out the tig torch "mixes" them together.
    Does that help?
  9. #8634
    Apr 2011
    Nice job,when I mount a thumb on a boom I weld the thumb base solid to a sacrificial plate which is stitch welded to the boom, saves the boom from damage in event of operator error.
    REAL TRUCKS DON'T HAVE SPARK PLUGS
  10. #8635
    Mar 2014
    Phil,
    Your stick welding is looking pretty nice. I remember around a year a go you practicing a vertical up test plate in hopes of getting some certification paper work. Did you ever get any?
  11. #8636
    Nov 2014
    PDX Pacific NW
    Nice looking padding. Looks like it would be a it would be difficult to use if the thumb is stationary. When clamping stuff like big piece of concrete u need to be pivot the thumb if u wanna rotate the bucket at the same time.
  12. #8637
    Nov 2014
    PDX Pacific NW
    Phil,
    He needs to send me the metal test piece to be bent first but looks like he will pass no problem after little practice
  13. #8638
    Mar 2014
    And this is your professional opinion as a CWI? For that matter have you yourself ever passed any stick welding certification tests?
    Forgive me but I'm just trying to figure out why it is you feel "qualified" to hand out this type of advice to others.
  14. #8639
    CT
    Quote Originally Posted by Old Skool View Post
    Thanks, I was looking at the welds on the thumb itself and it looks like it would fail before my welds, looks like 1/4" fillet welds.
  15. #8640
    CT
    Phil,
    Thank you . I never went through with that, work kept getting in the way, and honestly most of my work will never need a cert so I may not get one. I was wanting to get into the structural stuff but 90% of my business is railings and fencing so I might just concentrate on going in that direction with my business instead of trying to specialize in too many things.
    All that practicing definitely helped my stick welding though, I noticed quite a difference now from what it was a couple years ago
  16. #8641
    CT
    It is stationary, a friend of mine has one that connects to the joint of the bucket and opens and closes with the bucket. It's pretty cool
  17. #8642
    Nov 2014
    PDX Pacific NW
    I wouldn't be the one qualifying him if that's what your thinking which it sounds like. Just trying to be nice and help out others that's all. Not that difficult to chuck the coupon in the bender crank it over and look for cracks and splits.
  18. #8643
    Nov 2014
    PDX Pacific NW
    It's so worth it to have that setup. Is that your machine? What are picking up? We used to do house demo a lot and the operator was so good he was pulling out the 2x4 and they would be perfect still. And he could do it almost just as fast. And get stuff done. I ran them everyday too but mainly the truck driver. Lots of fun
  19. #8644
    Sep 2011
    Jasper TX
    Leroy,
    Does that help?
    Yes, thanks.
  20. #8645
    Jul 2014
    Phill did you get a new welding truck and not tell use ??
  21. #8646
    Fredericksburg, VA
    Riser block for a hitch on a friend's lawn tractor
    Millermatic 252 MIG
    Miller Dynasty 200DX TIG
    Miller Spectrum 375 Plasma
    Altas 12x36 Metal Lathe
    Bridgeport Milling Machine
    www.psacustomcreations.com
  22. #8647
    Pa
    His welds look solid.
  23. #8648
    Aug 2016
    Sutherlin Oregon
    Hey thanks everyone. Moto it is nice to weld all day you learn so much on material I could never afford. That sucks about the fire that close. The nearest one here was probably 30 miles away but there are 3 or 4 fires surrounding us so the smoke just sits here.
    Blocker I'm always building things but the last couple weeks it's just been either small parts or doing repair welds. Lots of spool gun work. Which I hate haha. Nothing picture worthy though
    This one's from today haha oops do not add filler straight to the tungsten!
    Sent from my SM-G920V using Tapatalk
  24. #8649
    Mar 2016
    Minneapolis MN
    Light fixture for the corner of my house above new concrete steps. Gang box welded inside - 60 watt digital bulb, will be on 24-7. I'll add the diffuser (wasp preventer) and paint light grey rustoleum today - wish I had more time to powder coat.
    Name:  raw light fixture.jpg
  25. #8650
    CT
    Haha, no, I still have the same truck (for now at least)
