Aluminum to Galvanized Steel?
Results 1 to 17 of 17
    Jul 2006
    MSP
    I am looking for a solution to joining Aluminum to Galvanized Steel. Whether it be welding, brazing, explosion cladding, friction stir welding, thermal spraying. Each piece would be 2MM thick and needs to withstand thermal shock from -40 to 120 degree Fahrenheit. If money were no object how would you suggest joining these two metals. I know a major problem with these two metals is the galvanic corrosion that takes place between them but are there any other major issues besides dissimilar melting tempuratures? Any suggestions would be great.
    Jan 2008
    Fond du Lac, Wi
    Re: Aluminum to Galvanized Steel?
    Elastic urethane adhesive? Perhaps with mechanical fastening as well? The CoE for those materials are so different it may cause more issues than corrosion initially.
    Feb 2006
    Epoxies can work if there is sufficient mating surface and overlap, ie sleeve to put one into another. The other option is mechanically fasten; good old nuts and bolts or rivets.
    Jan 2007
    UK
    http://www.aws.org/w/a/wj/2005/06/038/index.html
    Other manufacturers may give the process a different name, EWM for example call it 'coldarc'. You did say money was no object
    Mar 2007
    Deltaville, VA
    As Rojo mentioned:
    Bolts, Nuts, and Washers
    Syncro 250 DX
    Dynasty 200 DX
    MM 251 w/30A SG
    HH187
    Dialarc 250 AC/DC
    Hypertherm PM 1250
    Smith, Harris, Victor O/A
    Smith and Thermco Gas Mixers
    Oct 2007
    Yuba City, CA
    First step is to question the designer
    Quote Originally Posted by TiFreak View Post
    This is a great example of the need to question the designer, when they've specified
    something that is impossible, close to impossible or at the minimum--wholly unpractical.
    For all you & we know, the designer obviously didn't give this any thought, he/she
    just specified 'weld it'........without having any clues as to what's involved.
    (Those who create problems with their ideas, as opposed to solving/anticipating/finding
    solutions---are neither designers or engineers......simply ignorant wannabees )
    Blackbird
    Mar 2009
    Chicago, IL
    I've used explosion bonded strips in the past. VERY effective!
    Here's a European company that makes them, although sometimes it is hard to find.
    http://www.triplate.com/?pagina=triplate_solution
    http://www.smt-holland.com/
    A pic from their website
    Silver solder using OAW. Try to obtain a grade that melts below the melting point of the aluminium,
    GTAW and copper lithium filler might work also on DCEN. You need to work this though to obtain good fusion.
    In both cases, strip the galv off first.
    Good luck.
    May 2006
    Augusta, GA
    TeddCo
    HTP Microcut 400 & Invertig 160DC
    Smith Dual Guard MD-510 OA Rig
    Lincoln SP135+
    Hobart Stickmate LX 235/160
    I also really want to know the best suitable electrode to weld galvanized steel with aluminium
    Jan 2006
    In A Nice Comfy Chair
    Quote Originally Posted by dechiben View Post
    Does NOT Exist.
    ...zap!
    I am not completely insane..
    Some parts are missing
    Do not attempt.
    Dec 2015
    Western New York State, USA
    Does NOT Exist.
    ...zap!
    i have seen various products that will join just about anything but more likely closer to being a solder or brazing rod not technically a welding rod. never say never and do not be surprised if it is very expensive per pound. and i have no ideal how strong or duable like shock resistance and corrosion resistant it is
    http://muggyweld.com/super-alloy-1
    this company sells tig filler metal for aluminum to steel
    http://alumasteeltigrod.com/
    Sep 2014
    there is no welding rod period that works on aluminum to steel. You can solder, mechanically fasten it or use explosion or friction stir welding.
    Sep 2014
    that welding rod also says it's low strength.
    Dec 2015
    Quote Originally Posted by iongar View Post
    there is no "welding rod" that is a alloy of aluminum and steel. it is a solder or brazing rod that often can be tig welded so it acts more like everdur or silicon bronze filler. you do not melt the aluminum or steel only get hot enough for the filler to flow and stick. none the less it often can be applied with tig
    some alloys are like $50 or $100/lb and outside in rain and salt the corrosion ability might be very limited. Intergranular stress corrosion i have seen with steel handrail and certain chemicals. after many years a weld can get brittle where a good yank on handrail and the weld breaks off. when originally welded it was 10x stronger. literally the chemicals attack the weld by soaking into metal and effecting metal deep inside the weld. just saying any joining methods needs long term testing if anybody will care if joint fails
    also some alloys are zinc or tin or cadmium based. obviously cadmium was popular many years ago before its toxic effects were appreciated.
    Jan 2008
    Richmond, Virginia
    Syncrowave 250 w/ Coolmate 3
    Dialarc 250, Idealarc 250
    SP-175 +
    Lincwelder AC180C (1952)
    Victor & Smith O/A torches
    Miller spot welder
    Sep 2005
    Cave Creek AZ
    Does NOT Exist.
    ...zap!
    I just wish that all those people that buy a cheap welder and have a go at it knew that.
