Aluminum 45ft semi trailer
Results 1 to 25 of 35
    May 2012
    Missouri
    I just got in a 45 foot aluminum flatbed trailer to do some repairs on. The customer has a small fleet of a flatbed trailers and I really want to make him happy so he brings more to me. I would like any advice from anyone who has had experience working on these. It is mostly cracks in the floor from the flexing that the trailer goes through. I just want to make sure my welds don't crack like the last guys.
    Miller XMT 304 cc/cv
    Miller 12RC w/ 15ft Tweco #4 Gun
    Miller 30A Spoolgun
    Custom Thermal Arc TA 10/270 Generator "Thermal Star"
    Smith oxy/acet-propane with weld, cut & rosebud tips
    And of course grinders, chop saws, hand tools
    b.c. canada
    Re: Aluminum 45ft semi trailer
    Show a pic of the cracked welds might help
    Oct 2009
    Palmer, Alaska
    In my experience with boats once AL has flexed enough to start cracking you will spend the rest of its days chasing them.
    Dynasty 200DX
    Passport plus w/ spoolmate 100
    victor 315c oxy/(act and prop)
    Miller digital elite
    milwaukee power tools
    Apr 2013
    NE
    Quote Originally Posted by turk View Post
    This. EVERY single aluminum semi trailer has cracks, and even when you weld them back up, new ones with start in other places, and then back where you welded. It's truly the nature of the beast.
    I've seen the corners of trailers that get abused welded up over and over again, and the stresses and strains just crack them right away.
    Jun 2007
    Drill out the ends of the cracks, and also grind out past the ends of the cracks. wire brush with a ss brush before welding between passes and when your done. Compressed air is your friend. Use what ever is a compatible filler metal, most likely 5356. If I get a dirty joint a trick is to pull your first pass, it wont boil and blow out so bad and it allows you to get some filler in. grind out that pass and wire brush it and push the rest. Most importantly, protect them airlines!
    Nothing Ever Got Done By Quitting, Never Give Up.
    Is it cracked welds or cracked planks ? If its cracked planks I would check the crossmembers for cracks or broken welds. Also check for corrosion on the bottom side by the crossmember. Pictures of the cracked areas would help a lot. Simply welding over the crack in a plank is a waste of time unless it was damage caused by loading.
    Sep 2008
    SF bay area, CA
    You're going to start fighting a loosing battle over and over again. Once they start to crack you just chase the cracks around. Its usually reached its fatigue life
    whitewater, mt.
    Yep what Dualie said. That guy with the trailers won't here of it though. He's gonna drag that trailer till it's undraggable. Just explain it to him a bit and he should be happy. Weld it and it'll crack somewhere else. Always do.
    Quote Originally Posted by Dualie View Post
    Arcon Workhorse 300MS
    Powcon 400SMT
    Powcon SM400 x 2
    Powcon SM300
    1968 SA200 Redface
    1978 SA250 Diesel
    Miller Super 32P Feeder
    Pre 1927 American 14" High Duty Lathe
    K&T Milwaukee 2H Horizontal Mill
    Bryan
    Aug 2008
    Never, AND I MEAN NEVER, have I seen an aluminum trailer that will go the distance that a steel one will.
    I've often wondered if the additional payload pays for the trailer during the service life of the trailer as compared to a good old steel one
    My old Great Dane left the factory in 1982, and it's still going down the road with no issues.
    http://www.farmersamm.com/
    May 2012
    Missouri
    I am working on the 3rd trailer from the same guy. He knows the first one needs to be replaced. Most of the cracks are from loading damage but the first trailer is loose everywhere & that is its biggest problem. The dock where they deliver is too low & has steel bumpers so almost every trailer looks the same on the rear. If he keeps paying I'll keep fixing. I have thought about putting steel x bracing between the frame of the one that is real loose.
    Miller 30A Spoolgun
    May 2012
    Missouri
    Well I have one of this guys trailers back in the shop this one almost lost a complete suspension and axle. It was totally broke off on the driver side and only about 50 percent of the welds on the passenger side have not broken. I really like people who abuse there junk then bring it to me. At least this time he has a spare trailer and I'm able to spend the time in order to fix this one correctly.
    Miller 30A Spoolgun
    Jan 2014
    Rockdale wisconsin
    Not trying to be the welding police but we perform annual dot inspections where I work and if this thing is that bad I would wash my hands of it. If he gets into an accident and dot checks that thing out. They might be knocking at your door. There's a professional trailer shop that we send all the big jobs to and they even get to the point where the say no more. There a utility and trail king dealer Just remember to cya
    May 2012
    Missouri
    This one is mostly in good shape. These were not very good factory welds. I ground all the welds i could get to. The ones that I couldn't grind well I used 6011 rods. Some after welding with 6011s I plated over with gmaw.
    Miller 30A Spoolgun
    SoCal-LA
    What am I missing here? 6011?
    Miller Dynasty700DX, Dynasty350DX 2ea., Dynasty200DX, ThermalArc 400 GTSW, LincolnSW200 2ea., MillerMatic350P, MillerMatic200 with spoolgun, MKCobraMig260, Lincoln SP-170T,PlasmaCam/Hypertherm 1250
    May 2012
    Missouri
    The main frame beams are steel. The same trailer is back in the shop again. The customer said after I fix it this time he is going to sell it. The problem it has now is all the beams & channels above the 5th wheel plate rusted through & the plate pushed up between the frame.
    Miller 30A Spoolgun
    May 2012
    Missouri
    Miller 30A Spoolgun
    Aug 2007
    Brighton, Michigan
    Osweld - you don't need the work that badly. The customer now says that he is going to sell it when he gets it back. If he does (usually these guys don't, they continue to run it ) the work trail will lead back to you and your insurance company. Once you work on something like this it becomes your liability. Don't let yours and your family's future earnings be controlled by someone who care less about proper maintenance. Think long and hard on patching his beaters without him letting you fix them properly.
    Charlie
    Jun 2011
    marlow, ok
    If this is how he operates I don't think I would touch anything of his again.
    1982 miller blue star 2E ac/dc
    Harbor freight flux core pos
    Victor oa
    Aug 2006
    St. Paul Park MN
    Quote Originally Posted by osweld View Post
    I wonder how many times I have heard that one, just fix it good enough to get rid of then a few years latter brought back by same owner for another repair of some kind.
    May 2012
    Missouri
    At least with major repairs like this one he gives me the time & money to fix it right. I won't touch a project if I can't do what really needs to be done especially if it is a safety concern.
    Miller 30A Spoolgun
    I have fixed a few of those , a ton of work . I would cut the aluminum planks back far enough, stagerring the joints on 2 or 3 crossmembers. A wood deck would be easier . Get a new kingpin which you have to size for the thickness off the plate. I would use 3-8 plate for the coupler plate. Cut all the garbage out and start over. I would check over the rest of the trailer for rusted out spots before attempting this. Many times the rest of the trailer is in good shape and the coupler is rotted because crap gets in and cant get out . If you don't have a good 60 amp plasma you will want one , since that crap wont cut very well with a torch. Also you will want to raise the front up since a lot of the work will be done on a creeper seat. Good Luck.
    May 2012
    Missouri
    I cut 2 of the planks I could cut more but I don't want to splice the wires. My 40 amp plasma did pretty good at blowing through the rust. I am putting heavier beams across but going back with the same 1/4" plate. I am going to plate over the main frame because it is very pitted around where the beams are welded.
    Miller 30A Spoolgun
    Make sure to put extra support in line with the 2 sides of the fifth wheel. Also bending the leading edge of the plate upwards helps if the trailer was dropped low. A needle scaler works better than anything for cleaning the rust and scale off the frame.
    May 2012
    Missouri
    The original inline supports were only 3/16. I am replacing with 1/4. The cross beams were only 6" 9lb wide flange. I am replacing with 12lb. I have another shop bending a plate just like the original. I realize now why people call these Transcrap trailers they are not built heavy enough in some places.
    Miller 30A Spoolgun
    Mar 2012
    Eastern Town Ship Quebec
    Our trailer are all alu ,( reitnouer , mack , alutreck ) and the only one we have to stop work on it is the fountain half steel alf alu , we have done so far only rub rail repair to the other , no integrity
    Keep the picture coming please
    I will try my best to be understood
    MY DREAM GARAGE
